Macbook Pro 13" 820-3115-B (help for LVDS line components)
  • poldo
    • Mar 2020
    • 33
    • italia
    Happy New Year to all,
    I have a 2012 macbook pro 13 motherboard 820-3115-B with the following problem (due to water damage): it starts up normally but does not go on screen. I checked the LVDS CONNECTOR line and found the following damaged components:
    L9004: FERR-120-OHM-1.5A 0402-LF
    L9008: 120-OHM-0.3A-EMI 0402-LF
    In the repair I would prefer to replace the adjacent capacitors as well: C9010 and C9015: 0.001UF 10% 50V X7R-CERM 0402.
    On Mouser I tracked down the following components respectively for:
    L9004 with the following component:BLM15EG121SN1D
    C9010 and C9015: with the following component: X7R0402HTTP102K
    but for the L9008 component: 120-OHM-0.3A-EMI 0402-LF I have great difficulty finding a compatible product.
    I ask you if you could confirm the choice of the components I identified and help me in the search for the L9008 component.
    Thank you in advance for your attention.
    I am attaching an image of the scheme in question.
  • mon2
    • Dec 2019
    • 14271
    Re: Macbook Pro 13" 820-3115-B (help for LVDS line components)
    These are all jellybean parts. Any 0402 sized part that can pass the current can be used for the ferrite bead without concern.
    It is ok to use BLM15EG121SN1D for each of the ferrite beads.
    Also check Arrow - they are very good at carrying such parts. If needed, send me a PM and can try to drop ship the parts from Arrow. They should be pretty cheap for each.
    https://www.arrow.com/en/products/bk...tv/taiyo-yuden
    * will be ideal for L9008
    or just purchase:
    https://www.arrow.com/en/products/nc...nic-components
    * rated @ 2A so will work for both the L9008 and L9004 locations
    and use Samsung for the capacitors:
    https://www.arrow.com/en/products/cl...ctro-mechanics
    We have free shipping worldwide. Send a PM if you need help. Unless the customs is evil in your area, they should allow for such a low cost order to enter without extra fees. We can test the waters.
    • poldo
      • Mar 2020
      • 33
      • italia
      Ciao lun2,
      grazie mille per i vostri suggerimenti e indicazioni.
      Purtroppo ho provato ad acquistare i prodotti che mi consigliate su Arrow ma รจ richiesta la partita IVA che non ho.
      • mon2
        • Dec 2019
        • 14271
        Hello Mon2,
        thank you very much for your suggestions and directions.
        Unfortunately I tried to buy the products that you recommend on Arrow but the VAT number is required that I do not have.
        Send me a PM and let us see if it can work with our Arrow account.
        • poldo
          • Mar 2020
          • 33
          • italia
          or just purchase:
          * sarร  l'ideale per L9008
          o semplicemente per l'acquisto:
          https://www.arrow.com/en/products/nc.. .nic-components
          * valutato a 2 A, quindi funzionerร  sia per le posizioni L9008 che per L9004
          These two in Italy are not available
          • mon2
            • Dec 2019
            • 14271
            You are right about the VAT. If we change the shipping address to Italy, then the form presents a need for the VAT #.
            Can you order from Digikey ?
            • mon2
              • Dec 2019
              • 14271
              Digikey options:
              https://www.digikey.com/en/products/...121TL/14563833
              and for the capacitors:
              https://www.digikey.com/en/products/...C7411/11676257
              1000pf = 0.001mf (uf)
              • poldo
                • Mar 2020
                • 33
                • italia
                Repair Update:
                The damage suffered by this card is the result of a liquid leaking onto the laptop.
                After discovering that the L9004 ferrite bead was burnt and a square was blown, I proceeded to replace and rebuild the square and the track.
                I also replaced the adjacent C9015.
                Furthermore, the L9008 also seemed to be discontinued and I proceeded to replace it along with the C9010.
                I am attaching a photo of the completed repair.
                The result was positive, LVDS line restored.
                Thanks to mom2 for advice on the correct components to replace.
                • poldo
                  • Mar 2020
                  • 33
                  • italia
                  Now the laptop has other problems:
                  It does not charge the battery and the charge LEDs do not work.
                  I ran Apple Hardware Test online and found the following errors which I show in the picture.
                  • mon2
                    • Dec 2019
                    • 14271
                    Good job on the repair !
                    Review the following:
                    < see attached >
                    Post the voltages on the battery connector - pins 1-9. Connect the battery for this test.
                    • poldo
                      • Mar 2020
                      • 33
                      • italia
                      Hi, how much do you advise me to inject?
                      • mon2
                        • Dec 2019
                        • 14271
                        Sorry for the misunderstanding.
                        No voltage injection. Measure the voltage on the battery connector with your multimeter - pins 1-9.
                        Red meter probe on pin #1, black on ground.
                        Then repeat with #2 pin and ground, etc.
                        Then post the measurements here for a review.
                        • poldo
                          • Mar 2020
                          • 33
                          • italia
                          pin01= 0V
                          pin02= 0V
                          pin03= 0V
                          pin04= 0V
                          pin05= 0,009V to 0,030V (in a continuous cycle)
                          pin06= 0V
                          pin07= 0,132V
                          pin08= 0,132V
                          pin09= 0,132V
                          • poldo
                            • Mar 2020
                            • 33
                            • italia
                            I state, low battery for a long time.
                            • mon2
                              • Dec 2019
                              • 14271
                              Pins 4 and 6 are of concern on this connector.
                              Remove the battery and check the voltage of pins 4 and 6 again.
                              If still 0 volts, disconnect all power. Meter in resistance mode (2k scale).
                              Then red meter probe to pin #4 of this connector, black meter probe to ground.
                              What is the resistance?
                              Then repeat for pin # 6 and ground.
                              Post your measurements.
                              • poldo
                                • Mar 2020
                                • 33
                                • italia
                                I'm sorry, I just wanted to tell you that the measurement I took was performed without the power supply inserted.
                                With the power supply inserted and the laptop switched off, the values change:
                                pin01= 0V
                                pin02= 0V
                                pin03= 0V
                                pin04= 3,44V
                                pin05= da 0,009V a 0,030V (in ciclo continuo)
                                pin06= 3,44V
                                pin07= 0,132V
                                pin08= 0,132V
                                pin09= 0,132V
                                • poldo
                                  • Mar 2020
                                  • 33
                                  • italia
                                  pin04= 270KΩ
                                  pin06= 288KΩ
                                  • mon2
                                    • Dec 2019
                                    • 14271
                                    The new voltage and resistance checks are good for the SMBUS interface.
                                    With the battery & adapter connected, check the voltages on mosfet @ Q7055.
                                    This is the battery mosfet. Check the voltage of:
                                    source (1-2-3)
                                    gate (4)
                                    drain (5-6-7-8)
                                    If the battery is detected by the logic board, then this mosfet should be ON to charge the battery.
                                    Q: Can you boot normally to the Mac OS desktop ? Once you are there, what does the System Preferences -> Battery Health report ?
                                    Does it show any of the details for your battery ? If yes, then the SMBUS is communicating with this battery pack OK - this will be a good start.
                                    • poldo
                                      • Mar 2020
                                      • 33
                                      • italia
                                      sorgente (1-2-3) = 12,31V
                                      gate (4) = 12,28V
                                      drain (5-6-7-8) = 0,132V
                                      • poldo
                                        • Mar 2020
                                        • 33
                                        • italia
                                        If I boot with hd, the laptop shuts down when it tries to load the operating system.
                                        If, on the other hand, I try to download the operating system from internet recovery mode, the laptop does not turn off but i get the following message: Internet Recovery Error -1007F
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue โ€“ Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck โ€” hoping someone here can shed some light.
                                          ๐Ÿ›  Original Issue
                                          The machine initially wouldn't negotiate 20V over USB-C โ€” stuck at 5V.
                                          โš ๏ธ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
                                        • gomonx
                                          Macbook Air M1 (820-02016) over voltage 3.2V at line PP1V8_S2
                                          by gomonx
                                          Macbook Air M1 (820-02016) over voltage 3.2V at line PP1V8_S2 (from PMU BLUK3)
                                          I have replaced the ic u8100 but still the same problem. Where should I check next?...
                                          06-14-2024, 01:07 AM
                                        • tobeend
                                          Bypass mdm macbook m2 ventura
                                          by tobeend
                                          1. RESET MACOS WITH IPSW
                                          a. Power off MacBook, press and hold the power button to enter Recovery
                                          b. Open Disk Utility, remove Macintosh HD
                                          c. Reboot, connect to the network to Activate Mac.
                                          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                          e. Release the other keys, but keep holding the Power key for another 10 seconds
                                          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                          05-26-2023, 07:18 AM
                                        • fricosu007
                                          Macbook Pro M1 X A2484 820-02100 short on PPvin_5vusbc23 line
                                          by fricosu007
                                          Hello friends, today i got an A2485 820-02100-A in a desd state, found visual short on PPVIN_5VUSBC23 line, removed tantalum capacitor, installed same same value from other donor board, now there is no short on any of the rails but when i plug either magsafe3 or usbc inget 5v stable with 0.00 amps drown, no cycle, just these steady values, board is not in dfu mode, checked with magsafe and with usbc. Only value that i find on the board is ppdcin_aon which is 5vโ€ฆ i dont get 3,3 aon, 3v8 aon .. all missing, where should i start looking please !...
                                          05-10-2024, 09:40 AM
