it is doing the same with the cd3218 or with the raa489900 ... it is doing the same now ... with those changed so ...
Macbook Pro M1 X A2484 820-02100 short on PPvin_5vusbc23 line
by rilleyHello everyone,
I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
And the resistor L4004 is literally burned.
From what I see from the schematics, it does not affect any other rails, only the connection to the display... -
by som_b1hello. I'm at a dead end. So, when flashing through dfu, I got an ssd error. I removed all the nand chips and u9000 u9080. As a result, I got 5 volts of consumption and everything is shorting - that is, it seems that all the contacts on the nand chips and yu9000 yu9080 are shorting to each other. Maybe there are a couple of units somewhere that don't short. and I don't know where to look next.
help09-12-2025, 04:14 AM -
by rouninHi everyone,
🛠 Original Issue
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
I HAVE A MACBOOK PRO A2141 820-01700 THIS BOARD IS PP2V5_NAND_SSD1 SHORT TO GROUND THEN I CHECK ONE SIDE U8600 IS SHORT THIS SIDE IS ONLY ONE CHIP U8600 OTHER SIDE
PP2V5_NAND_SSD1 IS OK AND U9100 U9200 U9300 U9400 IS ALSO OK Will removing the U8600 fix the board or will I have to install a new one
Link to boardview --> https://www.badcaps.net/forum/troubl...91#post1449091 -
by ktmmotocrossHello.
I have this HP Omen 17-an108nc that show 3long and 2 short/memory error/ led blinks on Caps-lock after capacitor short on 5V line.
Come with one shorted capacitor on 5V line. After replce it just blinks memory error. i flash main and EC bios but still the same. I have all voltages on start, cpu fan spining, but onli capslock blinks and no picture
any hint? - Loading...
