Using the same 600 ohm meter scale setting, touch the meter probes together. What is the resistance in ohms?
A2337 new M1 MacBook Air problem Logic Board related, no video backlight 820-02016
Just checked it and it fluctuates but always comes down to 0.1-0.3 before then randomly going up again.
I also just saw that there is a component missing that is in the schematics: CP830, it is already missing on the first picture and the board did not have previous work done.Comment
First of all, happy new year!
I doubt it is the meter but I cannot find any shorted capacitor, I took off the 14 capcitors from both sides and they all are okay. The resistance still is at ~3.7 ohms.
How would you proceed now?Comment
Thank you! Happy New Year to you as well.
Flux and remove the diode @ DP800. Take a picture of this part for proper orientation when you solder it back onto the board. There is a polarity to diodes.
After the part is removed, test the resistance to ground on each side of the diode pcb pads. We are trying to isolate the parts on the board to locate the source of this short. That is, is the short before the diode or after the diode?Comment
So I removed the diode and the resistance to ground with respect to the anode (upper pcb pad) is in the hundreds of kOhms and rising. The resistance to ground wrt the cathode is 3.6 ohms, so the same as before when we measured the suspicious capacitors.
I had a look which components could also lead to a short resistance path. It seems like there is a resistor (RP832) and some more very small capacitors that are possible candidates.
Thanks for your patience with me, how would you proceed now?Comment
I was able to remove it on the second tryâŚ
Still 3.7 ohms wenn measuring from ground to the pcb pads where the capacitors were.
Update: I checked the schematic again and figured it could be a capacitor next to JP600, using the microscope I saw some âspider webâ pattern on the bigger one and took it off.
The resistance now is 3.4 ohmsâŚComment
At this stage, the LCD is disconnected, the backlight IC is isolated so it is down to the cluster of remaining caps.
To confirm the IC isolation, measure the resistance to ground of CP830 (this is a no stuff capacitor but we can use the SMD pads for measurement). This test should be of a high resistance. Confirm it.
Then we are back to the voltage injection again to hunt for who is causing this short. Based on that we should be completely isolated, it is ok to increase the voltage on the injection to say 2 volts or more. Double check all work before proceeding but the guilty party is within the cluster of remaining caps in this cluster. The resistance is fairly low and the part will heat up with the proper injection.Comment
Thanks again for your ongoing help and patience, I like to think I am getting somewhat better at this but that would be all to you.At this stage, the LCD is disconnected, the backlight IC is isolated so it is down to the cluster of remaining caps.
I can confirm the IC is isolated 150 kOhms at CP830 wrt ground. The LCD is disconnected, although the connector is still on the logic board.
I will check the boardview again to see which capacitors are left and try to find the short using voltage injection and alcohol. I will report back what I find (or donât find)
I checked every capacitor that is left in the backlight out multiple times injecting up to 3.5V. Nothing changed, no cap dried noticeably faster than the others (that is.. they all did not really dry at all).At this stage, the LCD is disconnected, the backlight IC is isolated so it is down to the cluster of remaining caps.
When swapping the side I also swapped the probes by accident and therefore injected with the red probe to ground.. could this have caused damage?
The only thing I noticed after injecting voltage is that the resistance now is at 4.2 ohms so a tiny bit higher.
Do you still suspect the remaining 9 capacitors?, if so should I try it with even higher voltage?Comment
Perhaps. Not sure but let us continue to confirm either way.When swapping the side I also swapped the probes by accident and therefore injected with the red probe to ground.. could this have caused damage?
Suggest to carefully flux and remove the balance of the 9 caps to hunt down the shorted component. Respectively, restore each back onto the board if found to be not shorted.Comment
I started removing caps and the first one directly seemed to add on to one low resistance path. It is a tiny 0201 resistor (CW196) and removing it immediatly increased resistance to 6.1 ohms.
I do not have a clue how much resistance there should be, so I would not know when to stop. It is probably safe to assume this did not resolve it and I continue removing caps?
As for the reassembly I will probably ask somebody more experienced to solder the 0201 and 0402 caps and can only put the bigger ones back. I also decided to buy replacements for all caps I removed because some looked dodgy and they are a couple cents each. They will arrive in a couple of days.Comment
Just weighing in here, I've had a lot of these units, and yes, keep removing those caps one by one; eventually you'll probably find one with a crack on the underside. They can be sneaky!YouTube Repair Videos - https://www.youtube.com/user/19PLD73
FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbvComment
First of all thank you for your quick visit, flex and your videos. You are the reason I tried looking up what it could be in the first place, I did not know you are around here as well, what a lovely surprise.
I cannot thank you enough for your continuous support. Reading the original thread I thought âlets give it a try with this quality help, it might workâ and I sure learned a lot and had plenty fun.
I removed everything. There still is a low resistance path somewhere. At some point, while removing the last caps the resistance went down to 5.4 ohms again.
Judging by the boardview there is only the tcon connector (the port on the board, I removed the connector cable) left within the circuit.The pins look fine, I donât know if there is still a chance to find and fix it.Comment
If the LCD connector has not been reworked then it is not the fault. There are a lot of caps on this backlight rail. Hate to ask but can you post a list of the caps you have removed in this process? Suspecting that someone has been missed and is the guilty party. For example, the caps in the DESENSE area have been removed?
These are in section F = Backlight Desense Capacitors.Comment
Sure, that is completely fair.
Top side:
CP867 - CP873
CW194, CW195, CW196, CW18D, CW18B, CW18A
CP600 - CP604
Bottom side:
CP860 - CP866
CW18F, CW18E, CW18C, CW197
Also DP800 and RP831 are still off and CP810 and CW1A8 I removed earlier by accident. These are still off as well.Comment
Just checked your example, those should be the five caps next to the display connector CP600 - CP604. I compared my board to the boardview in flex and had all components in PPVOUT_LCDBKLT marked. The caps in there are all off. If there are other caps, that need to be removed they are still on.If the LCD connector has not been reworked then it is not the fault. There are a lot of caps on this backlight rail. Hate to ask but can you post a list of the caps you have removed in this process? Suspecting that someone has been missed and is the guilty party. For example, the caps in the DESENSE area have been removed?
Edit:
I also checked each pcb pad under my microscope after I removed the last caps and looked for solder bridges but there werenât any. If you want I can make some photos of the areas I removed the caps from. Maybe I am missing something.
If it is not a component I forgot to remove, do you have an Idee what else it could be?Comment
Yes, I spent quite a bit of time here in Badcaps, have been here for many years now ( Just don't post a lot ).
Starting to worry that your board might have an internal short at the rate it's going; based on that cooked off inductor in the original posts it might have happened, hopefully not. Looks like Mon2 is guiding you though. Best of luck.
by ledbylightHi all!
This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more
, and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
11-04-2024, 06:36 PM -
by GuestHello all!
Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it.... -
by obelix24I'm working on Macbook air a2337
It's stuck on 5V.
I've replaced both CD3217B12 IC's and U8100
When i connect USB-C ampmeter i'm getting 5V 0.01 - 0.4a and restart ampmeter and again ....
I tried to connect to another mac and i'm not able to get it to DFU.
history is that this macbook just died randomly and owner was not able to start it again.
PPBUS_AON is 12.3V
i'm missing PP5V_S2 - 0V
According to repair wiki i've checked https://repair.wiki/w/MacBook_Air_A2...current_draw_c... -
by mkdjHello everyone,
About me, my goal and the equipment I (don't) have:
I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
About my issue and my goal:
A friend of mine has a MacBook Air M1 A2337 that does not... -
Hey, I have a macbook air M1 A2337 i replaced the display on using an AM display from MobileSentrix for a customer they returned because the camera wasn't working i tried another display from mobile sentrix still no camera, updated the software still nothing, i just took a display off our store macbook and no display still calibrated it using self repair and still no camera, so I have come to the conclusion its a board issue, any else ever encounter this, or any ideas on where to look on the board for shorts or anything.
- Loading...
