MacBook Air 820-00165 shutting down when trying to boot
  • ACS-Repair
    • Feb 2021
    • 204
    Re: MacBook Air 820-00165 shutting down when trying to boot
    Sorry Simplebeans... I don't know how I missed that. Good you have it working.
    • ACS-Repair
      • Feb 2021
      • 204
      Nice work @Simplebeans! I tried this on mine with no luck. Maybe it deserves another look.
      • No Lan
        [Macbook pro A1708] [Boot loop] [Trackpad ?]
        by No Lan
        Hey everyone,
        Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
        Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
        Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
        05-24-2025, 03:09 PM
      • twonk9098
        Macbook Pro mid 2015 battery required to boot?
        by twonk9098
        I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
        The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
        This model has the newer trackpad which is not clickable when turned off.
        At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
        If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
        12-10-2024, 06:51 PM
      • veedo
        Macbook A2442 820-02098 boot and display issue
        by veedo
        Hi All
        I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
        Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
        I found component UD290 ( SF0101-I2C) little...
        04-01-2024, 06:06 AM
      • PITERPENY
        Macbook A2251 no boot
        by PITERPENY
        The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
        01-05-2025, 03:11 PM
      • baglaivlad
        MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
        by baglaivlad
        Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
        Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
        01-09-2024, 09:55 PM
