Macbook A1708 / 820-00840-A / No boot
  • GfilipeZ
    • May 2021
    • 43
    • Portugal
    With the Logic Board connected to the DC source, in the USB-C adapter it gives 19.75V and the current is mostly at zero volts and from time to time it peaks at 0.035A (for about a second).
    I was able to find the source of the anomaly, that is, the PP1V_S5G rail is shorted.
    I know it's not advisable to inject voltage, but that's what I did and with the help of an infrared camera I saw that the processor is the only component to heat up.
    With this, is it correct to conclude that the source of the short is in the processor?
    Best regards.
  • mon2
    • 13995
    Re: Macbook A1708 / 820-00840-A / No boot
    Ouch! I think so but wait on others to chime in.
    What voltage did you inject?
    We repaired the same logic board with the same current draw a few weeks ago - 8 hours later on the review (no microscope), found the issue was due to the ISL9239 not communicating over SMBUS. The ESD diodes caked up and caused a haul down on the SDA / SCL lines.
    Do you have PPBUS_G3H ? We did not. Then replaced the ISL9239 and one of the mosfets. Neither helped. Then cried a bit and almost thought of start drinking but calmed down and logically traced all parts for the ISL.
    In our case, the voltage on the SMBUS line - SCL I believe was too low. The SDA was @ 3v3. Removed the part and the board came back to life.
    Arrow has the tiny tiny tiny parts for the ESD TVS function.
    Fairly sure that Apple had a design weakness on this logic board where the display connector (backlight voltage to be exact) would short to the CPU rail causing this destructive event.
    Review these:
    https://boards.rossmanngroup.com/thr...shorted.52266/
    • mon2
      • 13995
      Do review this excellent webpage:
      https://repair.wiki/w/A1708_2016,_20...ar_MacBook_Pro
      My post is the last one
      • GfilipeZ
        • May 2021
        • 43
        • Portugal
        Review these:
        I injected 1.5V and 200mA. I started with 1V and 100mA, but it wasn't enough to see which component went into overload (heating) first.
        First I detected that the voltage drop on L7030 was not stable at 13V. It was constantly varying between 0.4V and 1.15V.
        Then I checked on the U7000, which also had various input and output voltages fluctuating.
        As I couldn't find any reason for this behavior or short circuit, I went to check the behavior of the U1900. It was here that I found the PPVIOE_PCHCLK (2) line shorted (caused by the short in the PP1V_S5G voltage).
        I'll review your post and the other link you shared.
        As soon as possible I will give feedback.
        Thank you very much.
        • No Lan
          [Macbook pro A1708] [Boot loop] [Trackpad ?]
          by No Lan
          Hey everyone,
          Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
          Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
          Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
          05-24-2025, 03:09 PM
        • unimatrix93
          Macbook Pro A1708 no boot/charging
          by unimatrix93
          Hello everyone, I have a MBP A1708 with the following problem: Not turning on, only the fan starts to spin for a few seconds then nothing. No chime, nothing. CPU gets warm, All voltages are present on the board as far as I measured.
          If I do SMC reset, it does the fan spin procedure, but otherwise it's doesnt reacts to the power button.
          Two things I managed to pin point:
          Battery voltage is 2.2V, very dead wont charge even If I leave it on the charger.
          And after following this wiki (https://repair.wiki/w/A1708_2016,_20...ar_MacBook_Pro) I...
          11-13-2023, 02:13 AM
        • twonk9098
          Macbook Pro mid 2015 battery required to boot?
          by twonk9098
          I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
          The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
          This model has the newer trackpad which is not clickable when turned off.
          At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
          If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
          12-10-2024, 06:51 PM
        • veedo
          Macbook A2442 820-02098 boot and display issue
          by veedo
          Hi All
          I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
          Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
          I found component UD290 ( SF0101-I2C) little...
          04-01-2024, 06:06 AM
        • PITERPENY
          Macbook A2251 no boot
          by PITERPENY
          The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
          01-05-2025, 03:11 PM
