HP Omen 17 (fm08086 Battery blown fuse)
  • Arkanggel10
    • 17
    • Portugal
    Hi all, i have this laptop with message of blown fuse.
    i already opened the battery and i am assuming that this "FS1" its the fuse. correct me if i am wrong please.
    seaching info about this smart fuses i have read somewhere that to check them we do continuity test on the longer side pins. the multimiter beeps on the test.
    i have 14.6v and the closest 18650 pins from the cable, but on the actual cabe conector 0V.
    can someone help me to test the battery any further to fix my problem?
    thanks in advance to all
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: HP Omen 17 (fm08086 Battery blown fuse)
    mostly battery controller make blown this fuse when is something with battery,
    • Arkanggel10
      • 17
      • Portugal
      thanks for your help.
      to bridge it can i solder the pin from top with the bottom?
      • piernov
        • Jan 2016
        • 4439
        • France
        Don't mess with batteries, especially bridging fuses, firefighters have enough work as it is.
          • 21881
          you made my day, thanks
            • 21881
            Joking aside don`t mess with batteries they are dangerous,fuses should never be bridged. As you had continuity the fuse is probably ok, i`m not sure if resettable fuses are used in batteries.Two of the light coloured wires are SCL and SDA ,if you have a scope check them .The battery has most likely reached the end of its serviable life. The only way to really test a battery is with a hardware battery tester,there`s a few on the market
            • mosfetratus
              Sure Not
              • Feb 2019
              • 174
              • Resistron
              you can easily check voltage on each cell.
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • zioricci
                BMS laptop battery, fuse link blown ?
                by zioricci
                I replaced the cells of a Toshiba satellite battery that was almost 100% charged but the voltage was 0V at the ends of the connector.
                I tried to reset the BMS by short-circuiting the positive pole of the battery pack with the positive pole of the connector but without success.
                In the meantime I bought a new battery but looking at the battery pcb, I found this fuse
                https://ibb.co/Hqfw35L
                https://ibb.co/mCP4LT9
                resting on a mosfet probably as a protection against overheating. I found this fuse resting on...
                05-23-2023, 08:25 AM
              • mkdj
                ASUS X571 no power : battery issue?
                by mkdj
                Mark and model: ASUS X571
                Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                Tests already made:
                - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                - I have removed...
                07-14-2025, 09:16 AM
              • techfreak9356
                Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                by techfreak9356
                I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                09-14-2023, 11:10 PM
                HP OMEN OMEN by Desktop PC - 870-240na OMEN 870 i5-7400 Specification for Upgrade or Repair
                This specification for the HP OMEN OMEN by Desktop PC - 870-240na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-240na boardview and OMEN OMEN by Desktop PC - 870-240na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                09-12-2024, 03:44 PM
