820-00239-A , turn on, no image or backlight
  • rui4892
    • Mar 2017
    • 51
    • Portugal
    hello forum. i need help how to solve this problem.
    PPVCC S0 CPU 0V , after 3 seconds 1.04V stable for 10 seconds , then 0V
    L7430 4 ohm 0V , 0.7V after 14 seconds and remains stable
    L7520 4 ohm 0V , 0.7V after 14 seconds and remains stable
    L7410 4 ohm 0V , 0.7V after 14 seconds and remains stable
    L7210 7 ohm 0V , after 3 seconds 1.04V steady for 10 seconds , then 0V
    L7220 7 ohm 0V , after 3 seconds 1.04V steady for 10 seconds , then 0V
    L7270 12 ohm 0V, after 4 seconds 1.05V, after 11 sec 0.875V and remains stable
    L8000 205 ohm 0V, after 4 seconds 1.02V and remains stable
    L8050 140 ohm 0V, after 4 seconds 1.01V and remains stable
    L7900 300 ohm 0V, after 4 seconds 1.20V and remains stable
    L7960 70 ohm 0V, after 4 seconds 0.95V and remains stable
    L7700 after 4 seconds 1.05V and remains stable
    L7030 after 4 seconds 13V and remains stable
    L8410 always 0V
    L3500 always 0V
    L7660 always 3.3V
    LB700 always 0V
    L9400 always 2.7V
    plate consumption
    0W , after 3 seconds 17W with fluctuations up to 20W , after 10 seconds it has a consumption of 9.5W
    historic:
    the display was replaced about a few months ago due to it being broken.
    small evidence of corrosion on the Q4201 has now been re-soldered and cleaned.
    thanks.
  • mon2
    • 13936
    Re: 820-00239-A , turn on, no image or backlight
    Is the unit stable without the display ?
    Start with checking the voltage of PPBUS_G3H = F7000 (fuse), pin # 2. What is the voltage here ? Is it steady ON upon power up ?
    • rui4892
      • Mar 2017
      • 51
      • Portugal
      good morning, first of all my thanks for your prompt help.
      without the display the voltage on pin 2 of the F7000 is 13.0V and stable.
      initially 0V, after about 4 seconds it is stable at 13.0V.
      thanks.
      • twonk9098
        Lenovo Legion 5 high fan spin turns off after 34 seconds
        by twonk9098
        I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
        I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
        I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
        I have tried a few new bios but exactly...
        07-14-2024, 11:19 AM
      • Zilicon
        NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
        by Zilicon
        Greetings everyone.
        Please I need help with the above monitor.
        Below is the summary of what happened and what I have done:
        The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
        The backlight driver IC is 0b3350cp.
        I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
        11-07-2023, 09:12 AM
      • helpmepleasethanks
        Thinkpad T440P bios repair after WIFI whitelist mod
        by helpmepleasethanks
        As per the the rules, here are the specifications of my laptop :
        • Make and model number : Thinkpad T440P
        • Serial number (S/N) : PB-03A7V7
        • Model type - Model (MTM) : 20AW-S2N800
        • Bios version : 2.50 (not 100% sure, that's what I remember)
        Here is the problem, and the events leading to it :
        1. Upgrade screen, keyboard, trackpad, RAM and CPU
        2. Reboot and use the laptop for a bit : everything is working fine
        3. Shutdown (no power) and upgrade WIFI with unsupported chip (AX210)
        4. Boot up the device : bios warning, as expected
        5. Shutdown the device again (no power)
        6. Connect the 8-pin clip of a CH341a
        01-09-2025, 12:09 PM
      • liquidzorch
        Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
        by liquidzorch
        Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
        10-18-2024, 05:19 PM
      • Rick_1234
        by Rick_1234
        Good evening, gentlemen.
        Things I tried
        06-22-2024, 04:44 PM
