MacBook Air 820-01521 Backlight
  • eli302
    • Nov 2021
    • 27
    Re: MacBook Air 820-01521 Backlight
    I believe EDP_BKLT_EN comes from U0500 but I don't think I can test for it as it is a soldered on chip. Or should I try something else?
    • mon2
      • Dec 2019
      • 13829
      Yes, you can monitor @ R8442. Check both sides of R8442 for the logic level for this pin. Just in case, if R8442 is damaged then the logic level will be present on one side of this 0 ohm resistor but missing on the other side.
      What is the voltage reading ?
      See attached.
      • eli302
        • Nov 2021
        • 27
        Both sides of R8442 are reading 0V.
        • mon2
          • Dec 2019
          • 13829
          This voltage implies that the backlight has been instructed to remain OFF.
          When the lid is open and logic board booted, apply a flashlight on the front face and around the perimeter from front sides. Can you see any of the usual graphics on the display panel?
          • eli302
            • Nov 2021
            • 27
            Yes you can see everything with a flashlight.
            • mon2
              • Dec 2019
              • 13829
              Very good. Remove this resistor (R8442). Keep it in your toolbox for now.
              Then meter in resistance mode. Check the resistance to ground for the backlight enable pin. This is the side of the resistor that mates directly to the backlight IC.
              Confirm there is no low resistance on this pad.
              Then solder a wire from the resistor pad that connects to the backlight IC enable pin. The other side of the wire to +3v3 anywhere on the board.
              This is only to test if the backlight circuit works if the enable is manually changed to a logic '1' = +3v3.
              • eli302
                • Nov 2021
                • 27
                Bklt_en_r the resistance starts at 1.67 then climbs to 3.3 then drops. This is over about a 15 second time frame.
                • eli302
                  • Nov 2021
                  • 27
                  ^in 20M setting.
                  • eli302
                    • Nov 2021
                    • 27
                    After I solder the jumper, completely reassemble and test the screen?
                    • mon2
                      • Dec 2019
                      • 13829
                      Yes. Confirming again that your manual logic '1' state is being applied onto pin #2 of R8442 (NOT pin # 1). Be sure of this as the other logic will be trying to send out a logic '0' and we do not wish to assert our +3v3 onto that pin.
                      See attached.
                      Moving forward, the PCH component drives this backlight ENABLE pin.
                      Given that the backlight ENABLE pin = '0', there may be a sensor issue for the lid open function.
                      Measure and post the voltage readings for:
                      IPD_LID_OPEN
                      LID_OPEN_LEFT
                      LID_OPEN_RIGHT
                      Take these measurements with the lid open. If the logic board is out of the enclosure, then the raw board should reflect the same 'open lid' status.
                      • eli302
                        • Nov 2021
                        • 27
                        No backlight still. The voltage is steady at 20.1V and the current ranges from ~1.5 to 1.77A.
                        • eli302
                          • Nov 2021
                          • 27
                          PPVOUT_S0_LCDBKLT_F is at 0V
                          • eli302
                            • Nov 2021
                            • 27
                            I believe the issue is between R8400 and Q8400. Everything but pin 6 on Q8400 is at 0V.
                            • mon2
                              • Dec 2019
                              • 13829
                              Did you mean pin #4 ?
                              If you have voltage @ fuse F8400, pin #2 then the voltage should be arriving on pin #4 of Q8400. Please confirm and note the location of pin # 1 of the mosfet.
                              Post the voltage readings on R8450 (to ground) and R8451 (to ground).
                              So red meter probe on the resistor (any side is ok) and black meter lead to ground. Meter in DC 20V scale is ok.
                              We want to be 100% sure that the I2C interface for the backlight (ie. SCL & SDA lines) are not stuck. These resistors should be about +5v on each part. Please confirm.
                              These 2 pins (SDA & SCL) are used to increase / decrease the LCD brightness as desired by the end user via software or keyboard presses.
                              Using the next higher voltage scale (>20V DC mode),
                              measure and post the voltages for ISNS_LCDBKLT_P and ISNS_LCDBKLT_N. The voltage readings should be very close to each other for this test.
                              After this suspecting that the backlight IC may be faulty.
                              • eli302
                                • Nov 2021
                                • 27
                                I'm back working on the board.
                                • eli302
                                  • Nov 2021
                                  • 27
                                  I have to resolder my jumper wire but R8450 is reading 5.13V on both sides.
                                  • eli302
                                    • Nov 2021
                                    • 27
                                    Do I need to resolder the jumper cable to continue testing? Or should I resolder the resistor?
                                    • eli302
                                      • Nov 2021
                                      • 27
                                      So before I took off the jumper R8451 read 5.13V then dropped to 0V after testing. Now it's at 5.13V on both sides consistently.
                                      • eli302
                                        • Nov 2021
                                        • 27
                                        I did some test using repair.wiki as a reference and it's pointing to the CPU being bad. Should I try anything else before ending this repair attempt? Or can I do a CPU replacement with this model and it be reasonable with a hot air and soldering rework station?
                                        • Constantinos
                                          Macbook Pro A2442 820-02098 No image but has backlight
                                          by Constantinos
                                          Hi all
                                          I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                          He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                          Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                          Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                          From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                          08-24-2024, 09:48 AM
                                        • francescoranchi
                                          MacBook Pro A1909 LCD (no backlight)
                                          by francescoranchi
                                          Hello Everyone,
                                          I'm looking at purchasing a used LCD from ebay for my macbook A1990 2018 15inch which LCD I cracked. Since new / used but working displays cost around 500$ , I found a Grade A+ LCD display for A1990 which has a good price of 110$ but has no backlight.
                                          I would need just to make sure that what I know/my reasoning is correct:
                                          - No backlight means flexgate issue, therefore changingthe flexcable would be enough (I can microsolder to fix the flexgate problem, done it a few times already)
                                          - Seller confirmed its a LCD issue, and not an issue with the...
                                          12-04-2023, 06:46 AM
                                        • tommy97
                                          Apple MacBook A2337 - No backlight
                                          by tommy97
                                          Hi guys, I've got MacBook Air a2337 with no backlight. Once while testing it displayed with the backlight, however after restart problem come back.
                                          The laptop was tested with fully working screen.
                                          PP5v_BKLT_A/B 5V
                                          PP5v_BKLT_D 5V
                                          PP5V_S2 5V
                                          PP5V_SW_LCD 0.4V
                                          P5VS2_PWR_EN 1.8V
                                          P5VS2_BST_R 8V
                                          P5VS2_SW 5V
                                          PPBUS_5VS2_VIN 5V
                                          PPVOUT_LCDBKLT - Doesn't short 0V
                                          FP800 - Both sides 12v
                                          BKLT_EN_R & BL_PWR_EN - around 1.8v
                                          LP800 0.014V On both sides (should be 12? / no short)
                                          UC300 & UP800 Replaced...
                                          12-02-2024, 08:26 AM
                                        • tommy97
                                          Apple MacBook Pro A2485 - No backlight
                                          by tommy97
                                          We're working on an A2485 MacBook with no backlight after liquid damage. The damage occurred near the backlight IC (UP800). We've checked all the nearby resistors and capacitors, and everything seems fine. We replaced UP800 from a donor board.
                                          However, UP830 was also liquid damaged, and after cleaning, resistor RK830 came off. Unfortunately, I can't find its value, and the schematic doesn't indicate it as a critical component.
                                          Would anyone have insights or a way to confirm the RK830 value?
                                          Thanks in advance!
                                          03-17-2025, 12:22 PM
                                        • Stephen
                                          A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
                                          by Stephen
                                          Hello, got a weird MacBook Air here
                                          board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
                                          08-23-2023, 09:12 AM
