help! for this "ic" JD ED G21
  • karlox
    • Dec 2017
    • 138
    • México
    Help to detect the code of this integrated..
    thanks a lot...
  • mon2
    • Dec 2019
    • 14670
    Re: help! for this "ic" JD ED G21
    Can you post the details of the logic board ? Brand / model / markings on the PCB ?
    • piernov
      • Jan 2016
      • 4439
      • France
      https://www.badcaps.net/forum/showpo...84&postcount=2
      https://www.google.com/search?client...+ym%22+richtek
      • karlox
        • Dec 2017
        • 138
        • México
        • karlox
          • Dec 2017
          • 138
          • México
          Thanks, it's a hp dv4-5000, I keep fighting with this logic, changing some resistors damaged this integrated.
          • Max Leo
            Model A1398 (EMC 2909) adapter unable to read or detect
            by Max Leo
            i connect with this adapter unable to read or detect do i have to do something or short something to read the bios...
            Yesterday, 07:58 AM
          • electomech-fixer
            First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
            by electomech-fixer
            I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
            I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
            09-15-2025, 01:42 AM
          • pabloroggeri
            Lenovo V360, no detect battery
            by pabloroggeri
            Hi friends!
            It does not charge or detect the battery. At first it didn't start, I programmed the BIOS with the file that is in this forum and it turned on but it doesn't detect a battery. I need to try another bios that is not the one that is already published in the forum, I suspect that the one I recorded is corrupt, or incompatible in some detail and that is why it does not detect the battery. I did all the measurements on the charguer integrated circuit and they are all ok. I think the problem comes from the data BUS side. It is for this reason that I need a different...
            07-28-2022, 08:18 AM
          • tikanot
            msi GP63 gtx not detect and keyboard mistake
            by tikanot
            Hello i have a msi GP63 and the gtx 1060 is not detect in the bios and not detect in windows , i have flash the vbios with programmer and same mistake, i have the ec do mistake with keyboard key not work or keyboard not work , i know i have to chance the ec but it's possible the ec do the gtx not detect in bios and in windows? i have check the voltage of the vga and it's good the die of the gpu is little hot at used
            04-21-2022, 10:01 AM
          • BoB4js
            Pioneer PDP-427XD TV part Cap details Pls'
            by BoB4js
            I have a Pioneer PDP-427XD TV, not many hours on it. Bought second hand, I think it must have been a TV used in a meeting room, as it was like new when we got it. No manual, but worked out most of it.
            The Problem I have now is it went out with a crack noise, then a blinking LED, if I remember it had 6 flashes.
            I had a look and after a bit of hunting around (very frustrating as TV shuts down after a few seconds), I found a Capacitor on the Scan Assy Top Board had cracked and tried its best to meld down. Now, as it happens, I can get to this capacitor, but not the others...
            04-21-2022, 04:10 AM
