Pioneer PDP-427XD TV part Cap details Pls'
  • BoB4js
    • Apr 2022
    • Scotland
    I have a Pioneer PDP-427XD TV, not many hours on it. Bought second hand, I think it must have been a TV used in a meeting room, as it was like new when we got it. No manual, but worked out most of it.
    The Problem I have now is it went out with a crack noise, then a blinking LED, if I remember it had 6 flashes.
    I had a look and after a bit of hunting around (very frustrating as TV shuts down after a few seconds), I found a Capacitor on the Scan Assy Top Board had cracked and tried its best to meld down. Now, as it happens, I can get to this capacitor, but not the others on the same board. There are others the same, but it means removing loads of screws and shielding to get to them. A bit of a nightmare! However, I have found out the capacitor number and part number, though not type, voltage etc.
    Can anyone help with this? Details below:
    FROM BOAD: Scan B Assy Top Board:
    Capacitor No: C2741. (I think 2751 and maybe all between may be the same value).
    Part Number: ACG1125.
    If I could find out the details of this capacitor, I can change it.
    I did contact Pioneer UK, but no reply!
    I think it is worth replacing the capacitor, the TV has an excellent picture.
    I might be able to get a board, but I think the TV would need to be set up again, I don't have the equipment.
    If anyone knows Capacitor type, value, Surface mount, no details on capacitor or board except C2741.
    The capacitor has a crack and as soon as it arcs the TV power supply shuts down and blinks. So I think if I replace it the TV should run, if it has another fault it will go to TV heaven.
    Thanks for any help in advance.
  • lotas
    • Jan 2016
    • 4786
    • Russia
    Re: Pioneer PDP-427XD TV part Cap details Pls'
    C2741, c2751 - acg1125 - (0.22 µf/250 v)
    • BoB4js
      • Apr 2022
      • Scotland
      Thank-you lotas, very much appreciated.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • grimacelord
        Pioneer VXS-D902S Reciever - Filter Capacitor Question
        by grimacelord
        I have a Pioneer VSX-D902S receiver that I am trying to replace the 2 large 8200uF 80V filter capacitors on.
        I have already removed the capacitors and ordered replacements, but I made a mistake in ordering. The original capacitors are Pioneer ACH1202 80v 8200uF and have 4 pins. The capacitor replacements I bought are Nichicon 80v 8200uF and only have 2 pins.
        I was wondering if I could still use my replacements even though they only have 2 pins. Obviously I'd have to extend the pins of the capacitor to allow them to reach and fit through the...
        01-12-2023, 02:40 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
