MacBook Pro A1502 -keyboard and mouse doesn't work
  • zmeutz
    • Nov 2016
    • 82
    I have an MacBook Pro A1502 that keyboard and trackpad stop worked suddenly, no water contact ... mother board cleaned ...
    If I reset SMC keyboard and trackpad works for a little time ... not every time ...
    This happen when SMC doesn't work correctly, had this before, but doesn't work anymore not after reset to work ...
    Can be something else or to try to replace SMC?
    Thanks!
    Stefan
  • mon2
    • 14599
    Re: MacBook Pro A1502 -keyboard and mouse doesn't work
    Try to reseat the interface cables and/or replace the trackpad cable.
    • zmeutz
      • Nov 2016
      • 82
      Same, I replaced cable and reseat keyboard…
      Should I try to replace/ reball smc?
      • rotceh_dnih
        • Jun 2020
        • 43
        I'd just try a known good or new trackpad cable first , its a known issue on the 1502's.
        Going straight for the smc is kinda like cutting off a finger when you got a splinter in your toe.
        Another way to test is with a linux install , something about it using usb V's i2c or spi iirc, If it works on linux then its almost 100% a cable fault.
        A1502 need's to see the trackpad before the keyboard will work in macos.
        • zmeutz
          • Nov 2016
          • 82
          As I said before I tested with a known good flex from other one… and same thing.. reseat flex and same…
          Solved by replacing trackpad.
          Thanks for help!
