Pegatron D15D Rev 2.1 faulty smd - can be identify ?
  • jimmiscom
    • 22
    • greece
    hello to all.
    can anyone knows more details from the smd of the photo.
    i search on the internet with the numbers shown on the component but i didnt find anything. it burned and i want to replace it.
    thank you
    • 21928
    Re: faulty smd - can be identify ?
    Originally posted by jimmiscom
    hello to all.
    thank you
    laptop model number ? motherboard model number ?
    • khaahk
      • Dec 2013
      • 815
      • Estonia
      https://www.badcaps.net/forum/showthread.php?t=90619
      3F=
      • jimmiscom
        • 22
        • greece
        thank you so much for your support. the smd is from a Turbo-X laptop. for the motherboard you can see the photo. i dont know more about this motherboard.
        it was given to me from a friend as not working.
        i google also for the schematic of this motherboard but the only thing i can find is some bios files. can anyone help also for the schematic?
        thank you again for your great support.
          • 21928
          Schematic requests go here: https://www.badcaps.net/forum/forumdisplay.php?f=41 .Don`t bother requesting it though,as its not available.
          The board is a Pegatron D15D .Look at the Typical Application Circuit in the richtek datasheet,look for the four high side and low side mosfets on the board and test those.Before replacing the IC check the resistance to gnd for short on pins 3,8,13,18 after the old one is desoldered.
          • svidaurreta
            • Apr 2022
            • 11
            • rio negro
            Re: Pegatron D15D Rev 2.1 faulty smd - can be identify ?
            Can someone identify that component for me and what measurement does it have? Thank you
            • mon2
              • Dec 2019
              • 14673
              The pads and placement look like bulk caps.
              The larger PCB track area = GROUND.
              The other side of these pads = probably a power rail.
              Check the voltage of that power rail and suspecting it to be 3v3 or 5v0.
              Based on this assumption, you can place bulk caps onboard rated for the peak voltage of 6v3 and capacitance that is available to you - perhaps 22uf / 47uf for each. Need to confirm the body size of the pads so we can confirm if it is 1206 (appears to be) - perhaps were tantalum style but ceramic caps will be fine here.
              Start with the voltage check.
              • eniac22
                Pegatron D15D shorted capacitor
                by eniac22
                i have a laptop Pegatron D15D with shorted capacitor at 19V line, schematic is not available and i wonder if can tell me with what value can replaced ? the value of next by capacitor is 10uf.
                02-06-2024, 03:53 AM
              • splash221
                Identification of SOT89-5 component in keyboard – key line control, 5 pieces on the PCB
                by splash221
                Good morning,
                Please help me identify an electronic component. The component is in an SOT89-5 package with leads as shown in the photo. It is used on a keyboard board and controls the operation of a specific key row. There are five identical components on the PCB, and whenever I swap one with another, the corresponding key row stops working — so I conclude the component is faulty.
                The keyboard is a SteelSeries Apex Pro (US). I cannot find a boardview or schematic online. I have already searched AllTransistors, AllDatasheet, etc., and found several candidate types (voltage...
                10-03-2025, 11:35 AM
              • kosmo
                Turbox D15D Pegatron D15D Rev 2.1 power on no video.
                by kosmo
                Hello friends, i have this motherboard it turns on without video, so the measurements is :
                i have voltage in basic coils 5v,3v,ram 1.35,cpu 1.67,1.0v. cpu is cold and i have 0.1530 stable consumption.
                It8528E :
                1. PM_RSMRST 3v.
                2. KBC_PWRBTN 3V to 0v to 3V.
                3. PM_PWRBTN 3V it doesnt go to 0v when i press button.
                4. VSUS_ON 3v.
                5. SUSC_EC# 3v.
                6. SUSB_EC# 3v.
                7. CPU_VRON 3v.
                8. PM_SUSC# 0v. instantly rises to 2.2v (1sec) and drops to 0 when i plug in the charger.
                9. PM_SUSB# 0v. instantly rises to 1.2v (1 sec) and...
                04-14-2021, 06:27 AM
              • JarzabekPZ
                HUAWEI Matebook D15 Bom-WDQ9 - faulty onboard RAM
                by JarzabekPZ
                I have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
                08-08-2025, 03:40 AM
              • thesame
                DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                by thesame
                Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                02-27-2024, 04:31 AM
