asus pro PU551L no power
  • poweron
    • May 2019
    • 371
    • italy
    hello, this asus is missing the + 3v and i + 5v, the 19v are present what can I control?
    Thank you
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • reessi
    HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
    by reessi
    I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
    It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
    What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
    I have checked these lines in diode mode and they seam normal -> 600.
    I have checked to see if they come on for even a fraction of a second...
    07-15-2025, 09:14 AM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • ShadowAi
    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
    by ShadowAi
    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
    03-15-2024, 10:46 AM
