XPS Slooooooow charging after blown diode.
  • down1nit
    • Oct 2016
    • 29
    XPS 9360 | LA-D841P
    Schottky blew on dc in. I repaired the traces, replaced the diode, checked diode mode, and tested with no batt. Powered on just fine first time. For good measure tested all the other passive components that lead to the power IC and all seems fine. Tested with battery and the battery is now charging, adapter is recognized, but the battery charges only 2% per 20 mins or so. Urf. Gave it time since it could have been sitting for months for all i know.
    Same slow charge rate. Replaced the power IC since it's visibly in line with the exploded diode and it actually charges a bit faster, but not much. Usually I'll see amps ramping up after a half hour or so, but this one sat 100% stable taking 200mA and no more for a full hour.
    Current sense on battery side seems OK. It's possible the battery is just bad. Ordered a new one but I'm wondering if I'm thinking about this right or if I missed a data line step or something.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3697
    • slovakia
    • hard-enduro
    Re: XPS Slooooooow charging after blown diode.
    replace current sense resistor on battery side. check all mosfets on that line for good resistance or base shortage
    • drscoot
      HP X360 convertible battery blown fuse error, not charging
      by drscoot
      HP Modelnumber: 14-dh0061nb​
      This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
      The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
      I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
      And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
      All these 3 batteries are charging...
      12-15-2023, 05:54 AM
    • iyas132
      Corsair RM 750 blown schottky diode near ES1DF
      by iyas132
      Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
      Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
      My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
      Can anyone help me identify the component...
      12-30-2024, 01:34 AM
    • MrSparkle91
      Help with a blown Diode (Lenovo 15ith6h)
      by MrSparkle91
      I have recently gone to clean my laptop and noticed a bad Diode that's gone poof. I have also located it on the schematic also.
      Whilst I'm good at repairing stuff in general, I would like some kind insight into what I'm working with here and the Diode I would need.
      I have checked the whole laptop and suffer no issues usability wise, which is why I was shocked to find this, but am I right in thinking this is power voltage related?
      Thanks in advance....
      08-01-2025, 10:30 AM
    • Scoff
      HP Probook 470 G4 - Power and Charging Problem
      by Scoff
      Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
      Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
      07-03-2023, 09:28 AM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
