Lenovo L560 will not power on after reading BIOS
  • adil12
    • Sep 2020
    • 12
    • United Kingdom
    can you please help me with Lenovo L560. I only connected the Programmer to read BIOS file and save it, then the laptop will not power on again. I did not flash the bios or anything I only saved it to my pc.
    4 laptops L560 the same issue after connecting the reader they will not power on. no lights on keyboard or power DC JACK as if its dead.
    I tried different charger ( 4 chargers) i tried with the ram and also the COMS battery or holding the power button for 30sec but no power at all.
    Would appreciate any advice.
    Thank you
  • tahc81
    • Nov 2019
    • 42
    • Slovakia
    Re: Lenovo L560 will not power on after reading BIOS
    Hello, maybe you have set the programmer to 5V...?
      • 21853
      What model is your programmer is it a CH341A ,black pcb version
      • lamdy
        • Jul 2013
        • 11
        • Japan
        I am using MinPro100E, my L560 also not boot after read/write BIOS onboard.
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
        • grimacelord
          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
          by grimacelord
          Hello there.
          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
          History:
          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
          I searched for this error online and discovered...
          03-15-2023, 03:29 PM
        • to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
          by to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
          I have opened the laptop and identified the main BIOS chip...
          10-24-2025, 01:35 AM
        • mkdj
          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
          by mkdj
          Dear all,
          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
          Here the steps I have taken to fix the laptop:
          - downloaded latest BIOS from Lenovo Website...
          10-18-2025, 03:43 AM
        • iulik17d
          Intel Arc A380 videocard power limit remove - BIOS needed
          by iulik17d
          Hello everyone!
          The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
          The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
          01-10-2025, 02:33 PM
