HP 250 display chip hot on power button press and no power/fan spin/display
  • vettouch
    • Sep 2020
    • 68
    • Nigeria
    I have HP 250 laptop which recently developed intermittent shutdown. I disassembled the laptop motherboard and found out that the display chip gets very hot, and the system eventually won't come on or its fan spin or display anything. Please, professional assistance is needed. Thanks.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 250 display chip hot on power button press and no power/fan spin/display
    Schematic is available in the forum as long as your mb is INVENTEC 6050A2493101 . If this is your mb check Q567 voltage on Pin1/3/4 after turned on. You mean PCH by saying "display chip"?? . Is that getting hot without even turning on?? If getting hot without turning on, verly likely PCh is bad. Btw, this series mb's are all nearing "end of life" for PCH.
    • vettouch
      • Sep 2020
      • 68
      • Nigeria
      @mcplslg123. My mb is PALWONN 88 M3 E230435. The chip is labelled US1 (maybe PCH). Yes, it is getting hot without turning on. Sorry, I am a newbie. Thanks for your assistance.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        There should be some other marking as well. maybe its OSAMU_xxx mb for which schematic is not avlbl. Can you post a clear photo of the chip getting hot without turning on. What is the marking on chip??
        • vettouch
          • Sep 2020
          • 68
          • Nigeria
          @mcplslg123. View of board. I am sorry, if I am not giving the best information as to get your professional assistance sir. Thanks
          • fauzanmint
            • Jun 2018
            • 82
            • Indonesia
            this usually indicates a fault with the chipset
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Ok so its OSAMU2_HPC mb for which schematic is not available. The chip marked with arrow is indeed PCH. If its getting hot without even powering on, there can be 2-3 reasons
              01.3V rail is shorted. You can measure the resistance on 3V coil. Its located near PCH.
              02.VS voltage is being transferred without turnig on-so you need to findout the mosfet/IC for dc-dc transfer.
              03.PCH itself is shorted.
              To start with, measure resistance on 3v coil and if it shows low resistance, remove the coil and again measure resistance on both sides of the coil.
              Give these feedback and we may be able to pinpoint the fault
              • vettouch
                • Sep 2020
                • 68
                • Nigeria
                @mcplslg123. (1) I don't really understand how to set my metre to be able to read resistance on coils, though I know how to read voltages. (please, assist me in this regard). (2) I don't know how to find MOSFET/IC for dc-dc transfer. (3) How do I know when the PCH is shorted? I've tried these and have not been able to succeed, hence, late feedback. Thank you, Veteran.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  For resistance, you need to set your meter in Ohms mode.
                  • vettouch
                    • Sep 2020
                    • 68
                    • Nigeria
                    Okay, I found that one of the coils (a little close to PCH) shorts when on board and doesn't short when off board. Same coil also showed 6.67 ohms. Can it be causing my woes? Thank you, Mentor.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      You need to measure resistance on both pads of the coil while its removed. Perhaps you are measuring only one pad.
                      • vettouch
                        • Sep 2020
                        • 68
                        • Nigeria
                        Yes, I did measure resistance on both pads and eventually got 6.67 ohmns on both of them.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          If the resistance measurement is correct, you have a shorted PCH+ shorted 3V regulator. May be even kbc is shorted. If you have bga rework machine, you can try removing the pch. Elase get in touch with some professional repair shop. The cost of repair will be almost close to a new replacement mb. So i'll suggest look for a replacement mb as long as its available and not expensive.
                          • vettouch
                            • Sep 2020
                            • 68
                            • Nigeria
                            No, I don't have BGA Rework machine, but I have 8032A++ Hot Air Gun. Getting new motherboards here is difficult. I have before now watched some videos where PCH was removed using BGA, but I don't know where and how to procure it to aid my work. Thanks, Mentor.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              It cant be done with 8032A. So you need to get a bga rework machine for future work as and when possible. Unfortunately, i cant offer you any other solution.
                              • vettouch
                                • Sep 2020
                                • 68
                                • Nigeria
                                Thank you so much for your assistance.
                                • acedogblast
                                  by acedogblast
                                  11-02-2024, 05:13 PM
                                • DynaxSC
                                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                  by DynaxSC
                                  Hi
                                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                  08-04-2025, 12:20 PM
                                • Bonaventure Vigil
                                  ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                                  by Bonaventure Vigil
                                  Dear All,
                                  Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                                  At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                                  12-12-2024, 10:22 AM
                                  DELL XPS 9380 Notebook 13 Specification for Upgrade or Repair
                                  This specification for the DELL XPS 9380 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9380 boardview and 9380 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9380 Notebook...
                                  09-06-2024, 09:12 AM
