Laptop DC Socket removal
  • knad
    • Apr 2010
    Hi everybody,
    I am new to this forum.
    I don't know whether this is the correct place to post it.
    Anyway my problem is ;
    I am trying to replace the DC socket of a laptop motherboard, the model being Medion MD96630.
    Even though I have only got very basic soldering skils I have so far replaced a dozen of laptop DC Sockets.
    But I have never encoutered this type of soldering.
    The solder around the pins look yellowish and the amount of solder used is less than with other normal solder joints.
    I tried to remove the socket with my normal 30W and 60W soldering irons but it did not help.
    My question is;
    Is this a different type of solder (maybe with copper? )?
    Or is it a coating or glue on top of regular solder?
    How do I remove this solder?
    Thanks in advance,
    KNAD
  • smason
    • 1652
    Re: Laptop DC Socket removal
    I've done a few myself and never had a problem.
    Could be it's lead-free solder (which I have also not encountered yet) which from what I hear needs more heat. I'm sure others will chime in.
    • knad
      • Apr 2010
      Thanks for your response.
      I was also thinking this is lead-free solder. But lead-free solder should melt below 250C ?
      My soldering iron is rated upto 380C. And Itried several soldering irons including one upto 450C.
      I bought some lead-free solder (99.3Sn) to try and my soldering iron can easily work with this solder.
      I am a part time computer technician and this laptop(infact two of the same model) came from a computer shop who said it is too difficult replace the socket. I thought they mentioned it in general but I realize now it in particular this case.
      I hope somebody will be able to explain this.
      • knad
        • Apr 2010
        Just a update,
        I could not desolder the socket by any means.
        Finally I got myself some jewellers diamond coated drill bits and a dremel and drilled the holes out. It worked perfectly.
        New experience to add to my socket repairt skills.
        Anyway I am now ready for any type of socket repair LOL!
        • severach
          • Aug 2007
          • 1055
          Drilling can remove the plate through. Drilling should only be used as a last resort.
          sig files are for morons
          • insomnia
            • Jan 2010
            • 17
            ye i agree dont get found of drilling method cause it will come back to haunt you
            • Mario
              • Sep 2007
              • 64
              What i have done in the past with thoose hard to desolder DC jacks are to heat them up with a heatgun. Just tape the SMT chips around it and pull the DC jack out carefully. The ones ihave most trouble with are the Dell DC jacks
              • Krankshaft
                • Jan 2007
                • 2328
                Use Chipquik they come off in seconds.
                • NxB
                  • Feb 2009
                  • 1595
                  The yellow stuff is flux. The copper is just thick in that part of the board, thats why it won't come off. I vote for the smd rework gun.
                  Place board upside down, heat, watch the jack fall.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    If you're not careful with your aim you could watch some SMD components fall too .
                    • infringer
                      Badcaps Member
                      • Sep 2009
                      • 244
                      • United Frickin States
                      use a heat barrier of some sort always ...
                      Anyhow correct it is flux great stuff but at times it does suck I have took a dremel to headphone jacks in mp3 players cut them off and desoldered and poked out what was bad before with a paper clip.
                      For desoldering basic tools are desoldering iron, desoldering braid, heat gun, smd workstation, and chipquck? Never used chip quick thanks for the advice...
                      Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
                      • acedogblast
                        by acedogblast
                        11-02-2024, 05:13 PM
                      • Geomih
                        CPU socket replacement soldering profile
                        by Geomih
                        Hi All - I am hoping someone can help with some pointers (complete noob here!)
                        I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
                        My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
                        The simple stuff like a small memory module isn't a big deal because there are
                        12-11-2023, 11:07 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • Glaval
                        Sony OLED XBR-65A8G 4 flashes
                        by Glaval
                        Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
                        01-23-2025, 04:04 PM
                      • Geeker007
                        Friend messed up my laptop motherboard while working on my bench
                        by Geeker007
                        Hi All,
                        So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                        So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                        I have not tried putting...
                        06-16-2025, 01:40 PM
