I have my Lenovo ThinkPad P51 20HH laptop with a dead backlight.
It's a Xeon E3-1505M v6
The picture is visible on the panel with the help of a flashlight. So it's looking like the backlight is dead i guess...?
I've tested the one fuse next to the 40-pin on the MB that i can find, and that hasn't blown, it has continuity... So i'm wondering where else it has fuses? Or what else it could be?
I sadly didn't get photos when I've had it opened. And it's busy processing photogrammetry stuff at the moment. As it's otherwise works great with an external of course. But if needed i could crack it open and get some.
The story:
The 4k panel one day developed a corrupted 1 inch strip over towards the left side, top to bottom... But if i tapped the bezel it corrected... I live with this for a few weeks i think... Eventually i needed to take the bezel off and poke the silver mesh tape covering the panels driver board at the bottom, and it would correct it. (wowzers it's hot!)
But sadly one day it wasn't playing ball... I remember that i'd been tapping the driver board and also the top cover near the hinge of the laptop, under which the LCD cable is routed, and the panel then went totally black.
So seeing the 1 inch corrupted strip, i assumed the panel was dead, so got a new one from Aliexpress. It came and looked perfect/identical. But it didn't work. Then ordered the cable, but when that came, it didn't work. I do not remember disconnecting/connecting the panel with the battery in place, but i may have... I gather that's a backlight fuse popper... But only later did i try looking to see if it was working, but without a backlight...
So i have a new panel, new cable and a display that i can see is there with the help of a flashlight.
Anyone have any ThinkPad wisdom that may help?
Thanks in advance!
Rich.
The story:
Thanks in advance!
Rich.
