Backlight dead on ThinkPad P51 20HH?
  • cheeseandjamsandwich
    • Sep 2019
    • 8
    I have my Lenovo ThinkPad P51 20HH laptop with a dead backlight.
    It's a Xeon E3-1505M v6
    The picture is visible on the panel with the help of a flashlight. So it's looking like the backlight is dead i guess...?
    I've tested the one fuse next to the 40-pin on the MB that i can find, and that hasn't blown, it has continuity... So i'm wondering where else it has fuses? Or what else it could be?
    I sadly didn't get photos when I've had it opened. And it's busy processing photogrammetry stuff at the moment. As it's otherwise works great with an external of course. But if needed i could crack it open and get some.
    The story:
    The 4k panel one day developed a corrupted 1 inch strip over towards the left side, top to bottom... But if i tapped the bezel it corrected... I live with this for a few weeks i think... Eventually i needed to take the bezel off and poke the silver mesh tape covering the panels driver board at the bottom, and it would correct it. (wowzers it's hot!)
    But sadly one day it wasn't playing ball... I remember that i'd been tapping the driver board and also the top cover near the hinge of the laptop, under which the LCD cable is routed, and the panel then went totally black.
    So seeing the 1 inch corrupted strip, i assumed the panel was dead, so got a new one from Aliexpress. It came and looked perfect/identical. But it didn't work. Then ordered the cable, but when that came, it didn't work. I do not remember disconnecting/connecting the panel with the battery in place, but i may have... I gather that's a backlight fuse popper... But only later did i try looking to see if it was working, but without a backlight...
    So i have a new panel, new cable and a display that i can see is there with the help of a flashlight.
    Anyone have any ThinkPad wisdom that may help?
    Thanks in advance!
    Rich.
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    Re: Backlight dead on ThinkPad P51 20HH?
    Thinkpads have atleast 2 lcd fuses. And they are always near the lcd connector but might be on the other side of the board. So you would need to take out the board and just take a look.
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      Connect the old screen and measure the signals on the screen board test points, 19V, 3.3V backlight enable, and backlight pwm (should be 3.3V too on full brightness) signals. If some of the siignals is missing, first check fuses (19V and 3.3V) on the screen board, if the fuses are OK, but some signal is missing, then you can check the motherboard. Finding the cause of backlight fault is a pretty simple job.
      Become a Badcaps supporter
      Thanks to all supporters.​
        • Sep 2019
        • 8
        F6 & F7 it looks like (thanks to SMDFlea for supplying the Schematics! https://www.badcaps.net/forum/showpo...43&postcount=2)
        And yes, F6 is on the backside. I've tested F7, and it had continuity...
        Thanks!
          • Sep 2019
          • 8
          I have a few days of processing work to do and then i'll open her up and connect the old panel as suggested. The panel has marked test points i guess?
          The schematics suggest it's F6 & F7 on the motherboard for the lcd/backlight fuses. I know F7 is ok, it had continuity when i had her open last time. It was right next to the connector.
          I'll report back when i have a break in processing jobs and get her open.
          Thanks!
            • Sep 2019
            • 8
            i've cracked her open tonight and F6 seems to be blown... If the white SMD to the immediate left is the fuse...
            It doesn't have any markings, like F7 does (P)...
            Am i correct in assuming this is the fuse?
            I've attached a few microscope pics.
            To test on the bench, i just need the heatsinks/fans on, ram and the DC-In connector to power it up i guess?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Yes F6 is a fuse. You can get similar fuse at the back of screen(if you have any damaged/broken).
                • Sep 2019
                • 8
                That's a very handy little trick to learn!
                I found 3 fuses on my old, dead panel.
                But OMG aren't they so amazingly tiny!
                I'm working with a USB microscope, with more lag than you can shake a stick at. So it was horrendous trying to get it in place. I got the old F6 fuse off using the big blob of solder trick, as i only have a simple soldering iron, with a smallish tip. But putting the new one into place took me ages. It ain't pretty, but it's electrically correct. Must get an optical microscope, and sharpen my tweezers...
                The fuse then had continuity and no shorts to ground, so all good...
                After i'd gotten her back together with some new paste and pads, and then the hilariously horrifically long initial seemingly 'dead' screen/laptop ram check (64GB!) (gets me every time... patience......) i finally saw the lovely red Lenovo logo.
                Many thanks to all that helped!
                • triplefour
                  SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                  by triplefour
                  TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                  tcon is built into mainboard.
                  Only one cable goes to panel boards.
                  there is a cable from one panel board to the other that links them.
                  cost cutting measure that results in us having harder time to diagnose.
                  removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                  used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                  07-28-2022, 07:59 PM
                • maneatingmonkey
                  Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                  by maneatingmonkey
                  I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                  There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                  03-27-2024, 07:17 AM
                • KYBOSH
                  Samsung UN50TU8000 - Dead Panel Forensic Questions
                  by KYBOSH
                  I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                  When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                  When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                  Later I checked for shorts on the panel PCB boards but could not find anything.
                  When I took a look with the FLIR i noticed the 2 resistors...
                  08-10-2024, 08:39 AM
                • Maxpower3
                  Brand name and Model Type for Lenovo error 2202 product name is invalid
                  by Maxpower3
                  Info for error 2202 LenovoThinkPad models and type
                  Extract from ThinkPad Maintenance Utilities Configuration File
                  plnsrv.ini Version 1.01
                  Some information that may be useful
                  There must also be missing models, add them to the list if you know of any.
                  Code:
                  brand name
                  20B1=ThinkPad Edge E445
                  20B2=ThinkPad Edge E545
                  20BC=ThinkPad Edge E145
                  20BM=ThinkPad X140e
                  20BL=ThinkPad X140e
                  20A3=ThinkPad X230s
                  20AH=ThinkPad X230s
                  20AK=ThinkPad X240s
                  20AJ=ThinkPad X240s
                  02-21-2024, 10:27 AM
                • howardc64
                  Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                  by howardc64
                  Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                  • Backlight on, no image
                  • Disconnect right buffer board (view from front), left side display comes on
                  • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                  • Buffer board is pretty simple
                  Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                  07-11-2025, 04:04 PM
