Dell Precision 7510 charge battery and left side board problem.
  • Andreasbest
    • Aug 2014
    • 1175
    • Hellas ( Greece )
    #61
    Re: Dell Precision 7510 charge battery and left side board problem.
    Ok i just desolder PU101 but still 20Ω
    Should i proceed with PU1001?
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      #62
      Sure, wont hurt to try.
      • Andreasbest
        • Aug 2014
        • 1175
        • Hellas ( Greece )
        #63
        Desoldered PU1001 too, still 20Ω on both jumpers pins.
        • Spider1211
          • Oct 2019
          • 532
          • Mauritius
          #64
          Post resistance to ground value on all all coils.
          • Andreasbest
            • Aug 2014
            • 1175
            • Hellas ( Greece )
            #65
            PL101 185Ω
            PL100 several ΜΩ (not stable)
            PL301 60Ω
            PL700 several ΜΩ (not stable)
            PL701 ~300KΩ
            PL1401 7.8Ω
            PL1400 7.8Ω
            PL201 ~370Ω
            PL1202 5Ω
            PL1201 5Ω
            PL1200 5Ω
            PL1700 2.4Ω
            PL800 66Ω
            • Spider1211
              • Oct 2019
              • 532
              • Mauritius
              #66
              Hmmm, try checking circuits connected to 5VALW. Refer to page 4 and 67, check the load switch IC such as UZ26.
              • Andreasbest
                • Aug 2014
                • 1175
                • Hellas ( Greece )
                #67
                Check for resistance to GND, correct?
                • Spider1211
                  • Oct 2019
                  • 532
                  • Mauritius
                  #68
                  Easiest way in my opinion would be to just unsolder it and check both sides. Taking uz26 as example, measure resistance on pin 1,2 to ground then 13,14 to ground.
                  • Andreasbest
                    • Aug 2014
                    • 1175
                    • Hellas ( Greece )
                    #69
                    Removed UZ26 still 20Ω to GND.
                    Pin 1 & 2 20Ω to GND
                    Pin 13 & 14 (right above pin 1 &2 if i measured correctly) show infinity.
                    Keep in mind PU101 and PU1001 are still desoldered.
                    • Spider1211
                      • Oct 2019
                      • 532
                      • Mauritius
                      #70
                      Had an almost similar issue a while back. In my case it was a dead Core voltage controller and a USB protection IC. Try removing PU1100 and see if that changes anything.
                      Last resort would be to inject voltage on the 20Ohm line. Although not much current would flow, at 5V about 250mA to be expected. Might not be enough to get hot but something might get warm.
                      • Andreasbest
                        • Aug 2014
                        • 1175
                        • Hellas ( Greece )
                        #71
                        After desolder of PU1100 i got 85Ω on all pins mentioned above, no more 20Ω.
                        Is this resistance normal?
                        • Spider1211
                          • Oct 2019
                          • 532
                          • Mauritius
                          #72
                          By all pins you mean +5V_ALW, correct? Does both side of PJP102/3 still show same value or are they different now (pin1 is one value and pin 2 is different).
                          Still low but 85 is better than 20, so atleast that's some progress. Try checking different IC connected to +5V_ALW. Stuff like PU200, PU1200, PU1201, PU1400, PU1401, PU1402, PU1600, PU1700, etc.
                          Try resoldering everything back except PU1100 and see if its still 85Ohm. Then try removing the above mentioned IC and check if resistance increases(unless someone can provide a better approach). If you have a similar donor board, check what the resistance should be or maybe check the forum if someone with a recent post has a similar model and if they can provide the resistance value.
                          • Andreasbest
                            • Aug 2014
                            • 1175
                            • Hellas ( Greece )
                            #73
                            Yes i mean both pins of both jumpers have the same value, 85Ω.
                            Should i try with voltage inject or with 85Ω it will now work?
                            Last resort is to start desoldering what you suggest in order.
                            Damn, what a mess :p
                            • Spider1211
                              • Oct 2019
                              • 532
                              • Mauritius
                              #74
                              Just as a precaution, check if there is no solder bridge remaining after you disoldered pjp102/3.
                              Dont inject voltage if the driver chips are desoldered, at 85ohms (injecting 5V max) not much would happen anyway.
                              Well, since removing pu1100 (vcore related) changed resistance from 20 to 85 I'd suggest starting around vcc core chip first (pu1200, etc)
                              • Andreasbest
                                • Aug 2014
                                • 1175
                                • Hellas ( Greece )
                                #75
                                Okay, so i solder back everything (except PU1100) and cleaned up very well the jumper pins.
                                Now i have 80Ω on upper pins of both jumpers, bottom pins (the ones that are connected to PL102) have very high resistance.
                                • Andreasbest
                                  • Aug 2014
                                  • 1175
                                  • Hellas ( Greece )
                                  #76
                                  Just desolder PU1200, now resistance on upper pins of both jumpers increased to 90Ω, still low.
                                  Should i desolder PU1201, PU1202?
                                  • Spider1211
                                    • Oct 2019
                                    • 532
                                    • Mauritius
                                    #77
                                    Sure, try and see what happens. If no change, resolder all ICs and replace PU1100 with a known good chip and recheck resistance value. Around 120-170 Ohm should be OK for that rail.
                                    • Andreasbest
                                      • Aug 2014
                                      • 1175
                                      • Hellas ( Greece )
                                      #78
                                      Ok, so far PU1100 is confirmed faulty
                                      The PU1200 is ok? 10Ω resistance increase is normal?
                                      • Andreasbest
                                        • Aug 2014
                                        • 1175
                                        • Hellas ( Greece )
                                        #79
                                        Hello!
                                        Removed all PU1200, 1201 & 1202 but resistance still stuck at 97Ω.
                                        What do you suggest next?
                                        • Spider1211
                                          • Oct 2019
                                          • 532
                                          • Mauritius
                                          #80
                                          Resolder everything back except those that caused resistance to increase when removed. I would replace those, especially PU1100.
                                          Once you have resoldered and replaced necessary parts, measure resistance again. Then resolder the PJP jumpers. If it is still within 90ish ohms, try to power on and see what happens.
                                          • Stephen
                                            A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
                                            by Stephen
                                            Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
                                            05-29-2025, 10:35 AM
                                          • ravi_1617
                                            HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
                                            by ravi_1617
                                            Hello to all ,
                                            I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
                                            Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
                                            on external VGA port image is perfect /normal , Attached image...
                                            07-25-2025, 12:07 AM
                                            DELL Precision 3630 Precision i7-9700 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3630 boardview and Precision 3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:44 PM
                                            DELL Precision 3630 Precision E-2274G Specification for Upgrade or Repair
