Universal Battery Analyzer tool NLBA1
This topic is closed.
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    #41
    Re: Universal Battery Analyzer tool NLBA1
    Originally posted by testpoint
    actually you do not need to buy so expensive tool, just prepare a EV2300 adapter, pay 10 USD to UBRT, they will unlock the battery for you, I just unlock two thinkpad T460 batteries with bq40z696a chip.
    I love to see a tutorial how tu use the tool for unlocking laptop battery where to buy and where to get the software.
    Regards
    Steve
    • rediii
      h???, spurrrn
      • Mar 2018
      • 507
      • somewhere in europe
      #42
      Regards
      Steve
      same! =)))
      • mon2
        • 14995
        From a quick review - it is $10 per battery to unlock from UBRT? Surely this cannot be this difficult to unlock?
        • testpoint
          • Feb 2021
          • 9
          Originally posted by mon2
          Thanks @testpoint. Did not know about this tool.
          sometimes they can help you, but they said it is NOT a fixed service, they just think it is a demo for you.
          • testpoint
            • Feb 2021
            • 9
            Regards
            Steve
            EV2300 is a TI tool, maybe need 60 USD; but the market appear many EV2400 product made by Chinese vendor (copied version), it is quite cheap, maybe 20 USD in China;
            the software, driver, all from https://ubrt.com.ua/
            if you are luck, they will help you.
            • testpoint
              • Feb 2021
              • 9
              I also according my chip search from Google, then found the UA guy can unlock every battery, but, he just want to sell their software for service shop, each year 800 USD, and, if he like, he can remote login your PC, help you reset the battery (in PF state), actually, this is a good business since the laptop use the poly Li battery (made in China), as before, almost all the laptop use the Li-Ion battery, this one's quality is quite good, you never heard any battery cell voltage to 0 even you place the battery not in the laptop for two years, but now, the poly battery is quite poor, the self discharging current maybe is higher, then you take out the battery for several months or put in stock for several months, the battery cell's votage may drop to zero, then the voltage dropped to low than a threshold value, the controller chip will lock the battery, even you disassemble the battery, use the DC charger connect to the B+ and B-, full charge it, the controller also not release its lock, then you only need some tool to unlock (reset) it.
              • Stevedb
                Stevedb
                • Feb 2018
                • 624
                • Belgium
                #47
                800 usd is a lot off money .then you can better use NLBA service.
                That will be cheaper I think.
                • testpoint
                  • Feb 2021
                  • 9
                  yes, if 800 USD, it is quite high, no one will fix one battery to spend 800 USD, but, if 10 USD, you can try
                  • mon2
                    • 14995
                    Or try their service and monitor the SMBUS traffic to learn how they achieve the unlocking.
                    • testpoint
                      • Feb 2021
                      • 9
                      when you the software, will connect to internet check your login name, if can not get the authentication, then your software only can worked in demo mode, may not reset or change the info for battery, just read ?
                      • Indunil555
                        • Jul 2021
                        • 28
                        • Sri Lanka
                        #51
                        I want to know how to change the battery design capacity. We want to increase battery health. how to balance design capacity and full charge capacity ?
                          • 22424
                          Ask at the NLBA1 support forum
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                          • mkdj
                            by mkdj
                            Mark and model: ASUS X571
                            Tests already made:
                            - I have removed...
                            07-14-2025, 09:16 AM
                            Bauer tool battery pack charging with a HERCULES charger modification
                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                            05-06-2023, 12:17 PM
                          • techfreak9356
                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                            by techfreak9356
                            09-14-2023, 11:10 PM
                            NVDC charger configuration...
                            11-05-2024, 03:28 PM
