A1707 lcd question
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    A1707 lcd question
    This is not a logic board related issue. LCD was swapped out and verified the good one works.
    So heres the deal, the LCD we have is not cracked, and the backlight turns on. BUT, there is no image on this specific LCD. There is no flexgate because the backlight is turning on. Its just the backlight turning on and the screen is not cracked. I replaced the LVDS connection on the LCD and it still has the backlight turning on. Does anyone have an idea how to repair these in order to get it to display the full image? note the LCD again is not broken or cracked or has the Flexgate issue. I think I see this online as a common issue sometimes in these LCD models. Thanks for anyone that has experienced this and has a solution.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • mon2
    • 14677
    Re: A1707 lcd question
    Backlighting is with 2 lines of interconnect. Hot and ground.
    Video display involves numerous lvds lines.
    This could still very well be flexgate related.
    There is a youtube video where the tech repairs the flexcable that is the root cause but it is not the best solution.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Can you link me to this youtube video. I would like to attempt to repair this LCD and I am capable of so.
      sigpic
      • mon2
        • 14677
        Suspecting a connector or trace break in the flex lcd cables since a different lcd works. Do inspect the connectors on the non-working lcd.
        Review this lengthy (no pun) process:
        https://youtu.be/A3hUg3KjfYI
        Guessing that the lcd cables can be sourced offshore. Update this thread if you attempt this fix.
        • janoszw
          MacBook Pro A1707 Graphics issue.
          by janoszw
          Hi, I'm having a problem with my MacBook Pro A1707.
          There are graphics glitches all over the screen.
          I took a screenshot, so it's not a screen issue, but either the graphics card or VRAM chips.
          Has anyone had this issue before? I don't want to replace unnecessary components.
          The system is otherwise quite stable, it's just a visual problem.
          Thanks....
          03-31-2024, 04:18 PM
        • tomtom67
          Macbook Air A2337 not turning on - ISL or CD issue?
          by tomtom67
          Have an A2337 here, which suffered some serious coffee damage. After cleaning C5220 fell from the board, so I replaced it and after lifting the ISL I found pad C5 was also partially corroded, first reballed the original ISL (no power), and then replaced it from a donor.
          I now get 5V / ~10mA stable on the charger, and found the CHGR_GATE_Q2 (GATE_Q2 on the ISL) doesn't get activated (Q1 does).
          Is this an ISL or a communication issue (perhaps with the CD3217s)?
          10-01-2024, 07:11 AM
        • slimmy182
          MacBook Pro 15" 2016 820-00281 no backlight. Another flexgate issue?
          by slimmy182
          Hello, I bought this machine from a friend. It's a 15 inch MacBook Pro 2016 model, logic board 820-00281. He said that the screen would go off if open more than a certaing angle but it's perfect working whit an external display.
          The backlight screen remains stay off even if I open just a little the lid, so I never see backlight work, but I can confirm that LCD show images as using a torch I can see it on the screen. It seems also that camera is not rocognized as the keyboard backlight stay off and touchbar have full brightness.
          Is this a classic flexgate issue? I...
          10-19-2022, 12:44 AM
        • sofles
          Macbook a1707 2017 model 820-00928 GPU issue
          by sofles
          Hello there
          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
          11-21-2024, 05:25 AM
        • Stephen
          A1707 MBP 15” Battery issue
          by Stephen
          Got a MacBook Pro 15” A1707 with an odd issue.
          Battery is charging, shows normal state 48 a cycles and keeps charging however when we unplug the charger it dies immediately, took the battery out and put it back in and it stayed on then it died again later after 15 mins with it not being plugged in. The battery was at 63% but it's reading normal state and the battery looks good. When I unplugged it and reseated it it started working again. But what's off is it then dies and won't turn on. I'm leaning towards the battery yet it's in normal state condition and charges fine but won't...
          12-21-2022, 05:48 PM
