A1707 MBP 15” Battery issue
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Got a MacBook Pro 15” A1707 with an odd issue.
    Battery is charging, shows normal state 48 a cycles and keeps charging however when we unplug the charger it dies immediately, took the battery out and put it back in and it stayed on then it died again later after 15 mins with it not being plugged in. The battery was at 63% but it's reading normal state and the battery looks good. When I unplugged it and reseated it it started working again. But what's off is it then dies and won't turn on. I'm leaning towards the battery yet it's in normal state condition and charges fine but won't hold the power when disconnected. Any idea guys
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • mon2
    • 14334
    Re: A1707 MBP 15” Battery issue
    Battery is crap and the charge counter has been tampered with. Try a fresh known good battery from Mobile Sentrix or plan b is Amazon. Both will take it back if there is an issue.
    MS would be my first choice.
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Thanks mon was leaning towards MS. We have an account with them so. Thanks again
      sigpic
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • code share
        Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
        by code share
        I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
        Here's what I've tried so far:
        • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
        • Booted successfully on AC power only with the battery disconnected
        • Visual inspection of the battery — no swelling, burn marks, or connector damage
        • Battery
        04-21-2025, 12:50 PM
      • huzo
        HP ELITE X2 1013 G3 weird battery issue
        by huzo
        Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
        01-31-2025, 12:09 AM
      • Simone Vergani
        Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
        by Simone Vergani
        I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
        To assist with troubleshooting, I'm attaching two power circuit schematics:
        • Power
        03-05-2025, 02:25 PM
      • ahmarzo
        Acer laptop battery draining issue
        by ahmarzo
        Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
        Help me to diagnose this issue as there is no shortage in the inputs MOSFET
        08-02-2025, 06:39 AM
