Panasonic Toughbook CF-52 IC Identification
  • adiserwis
    • Nov 2013
    • 14
    Could someone please identify the burned element on CF-52MK3 board?
    Not much information on those boards and don't have spare one at the moment
    Thank you in advance
    • 21479
    Re: Panasonic Toughbook CF-52 IC Identification
    Post the silkscreened motherboard part number,there might be a schematic available, and post the part number on the chip.
    • adiserwis
      • Nov 2013
      • 14
      Thanks for reply,
      Motherboard is CF-52MK3 DFU1912ZA (1)
      Chip is almost completely burned, only readable part is "ADM2"
      • mon2
        • Dec 2019
        • 14592
        ADM = Analog Devices.
        Wonder if this is a charge-pump style RS232 transceiver @ 28 pins?
        Did this laptop feature a RS232 serial port ?
        • adiserwis
          • Nov 2013
          • 14
          Hi, yes, it has RS232, and yes, I believe you're right about it.
          My problem is, there is few and they all unfortunately
          start with ADM2
          • mon2
            • Dec 2019
            • 14592
            Ok. Check ADM213 - see attached datasheet and confirm the caps to the RIGHT side of this IC. Trace their pads with a meter to confirm they match the attached datasheet. Common part to source.
            Fairly sure that your blow IC is:
            ADM211EARZ
            or
            ADM213EARZ
            Both are of the same pinout but behave differently during shutdown of the part. During a shutdown, the 213 device remains active to wakeup the host PC with a mouse movement or external serial device.
            I would suggest for you to source 1 of each of the following for testing:
            https://www.digikey.ca/en/products/d...11EARZ/1007300
            https://www.digikey.ca/en/products/d...213EARZ/820157
            Was this the only problem with this logic board? If yes, use a hot air tool to remove and replace this part. Or have your local cell phone repair shop to do the same.
            • adiserwis
              • Nov 2013
              • 14
              It looks like after all it is ADM213.
              Placement of caps checks out according to datasheet.
              Thank you very much for your help
              • aa10aa10
                Panasonic Toughbook CF-33 mk1 BIOS repair
                by aa10aa10
                Good day,
                I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                01-21-2025, 06:13 AM
              • AquaMan Ua
                Panasonic toughbook CF-19 help connect the HDD directly. Need a SATA pinout.
                by AquaMan Ua
                Hello, dear community. NEED A DIAGRAM of the HDD/SSD connector contacts as an example (a screenshot from the diagram of another laptop on which I have already done this and a photo of the patient's board) Maybe someone can make a screenshot of the diagram with the pinout? Or does someone have a diagram of the motherboard schematic?
                I am asking, because not find the information myself anywhere. I have a PANASONIC CF19 MK2 laptop (Any revision will do, I do not think that the contacts in the connector are located differently) but finding a basket for it at reasonable prices is a problem....
                08-26-2025, 09:07 AM
              • eukal
                Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
                by eukal
                Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
                I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
                I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
                I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
                07-01-2023, 01:00 PM
              • Nedim Merdan
                Panasonic toughbook CF-D1DW200FZ motherboard DL3UP1969CAA schematic
                by Nedim Merdan
                Does anyone have the schematic for toughbook cf-d1 mk1 motherboard model is DL3UP1969CAA thanks in advance
                12-07-2024, 02:22 PM
              • David Smedley
                Panasonic FZ-55 Toughbook main board schematic request
                by David Smedley
                I've been working on this awful project with a Panasonic FZ-55, basically I'm trying to intercept the eDP signal from the main board, and replace it with my own eDP signal connected from an lcd driver. The problem is, for some reason the 30 pin ribbon pinout is really unusual and not playing nice with my LCD controller. Long story short, I managed to fuck up my board and pull off some pads on the eDP out port, I'm hoping to find either another eDP out source somewhere else on the laptop, or figure out this goddamn pin layout so I can just replace the whole native display complex with my controller...
                09-04-2024, 02:57 PM
