Hp 840 G3 board no: 6050A2822301-MB-A01 5V, 3V missing
  • Zilicon
    • Nov 2020
    • 142
    • Nigeria
    Please I need assistance in resolving the issue with this motherboard. At first, the ACDRV was absent which did not allow voltage present in the system. Gladly, the voltage is present now but the system did not turn on. I notice 5V and 3V are absent. Please how can I go about this problem. No schematics nor boardview seem to be available for this board.
    thanks
  • Sephir0th
    • Oct 2020
    • 1282
    Re: Hp 840 G3 board no: 6050A2822301-MB-A01 5V, 3V missing
    If DC-IN Circuit is fine now and Main Power Rail after Second DC-IN Mosfets present you need to find and check the 3V/5V Controller, usually it has 20 - 24 Pins.
    If you need Help for this, you have to Share HQ Pics of both Sides of the Board.
    FairRepair on YouTube
    • Zilicon
      • Nov 2020
      • 142
      • Nigeria
      Thanks a lot for your response.
      Attached are the board pictures
      • Sephir0th
        • Oct 2020
        • 1282
        You're Sure 19V is present at the Current Resistor (See Red circle of attached Pic)?
        What exactly do you have done in this area?
        • Zilicon
          • Nov 2020
          • 142
          • Nigeria
          I did nothing to the resistor. I changed the spider that is beside it.
          Yes the IC produces the 25V for the gate FETs. I've also replaced it with a donor board. Same thing.
          The reason I changed the spider was that it was pulling the ACDET to 2.4V, hence other side of ACOK didn't get 3V. But everything becomes normal after I changed it.
          But FET beside the circular resistor does not open, gate absent, I'm not sure if it will be open after the system turns on
          • Sephir0th
            • Oct 2020
            • 1282
            If i Understand it right, you replaced the Charging Controller. Replacement is exactly the Same model?
            At the circled Point has to be 19V present as soon as the Adapter is plugged in. So is it present there or isn't it?
            • Zilicon
              • Nov 2020
              • 142
              • Nigeria
              Yes 19V is present.
              And yes I replaced it with the exact type, I have a donor board with me. But it still remain the same with 19V present.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                You should atleast mention the marking on your 3V/5V regulator IC. Measure the pins of this regulator and post here.
                • Zilicon
                  • Nov 2020
                  • 142
                  • Nigeria
                  I'm having problem identifying ffg ying the IC itself, and markings on the ICs have faded out somehow.
                  I'm not sure if they use buck converters to achieve the power rails. No schematics or boardview that I can use for tracing.
                  • dspok
                    • Jan 2014
                    • 553
                    • Nepal
                    It is quite easy to figure out 3v/5v regulator because it same as on other board. You can take any board for reference.
                    • Zilicon
                      • Nov 2020
                      • 142
                      • Nigeria
                      Ok thanks.
                      I will try this out
                      • thema979@yahoo.it
                        • Sep 2022
                        • 10
                        • Italia
                        Hi i have a hp zbook 15u g3 with 6050A2822301-MB-A01 MB trouble. No power, no led lits. Power supply is ok and power connector is ok. Can help me?
                        • mrwab
                          Banned
                          • Jan 2014
                          • 83
                          • morocco
                          fist check 19v line and 3v and 5v
                          • thema979@yahoo.it
                            • Sep 2022
                            • 10
                            • Italia
                            I don't have a schematics for notebook. can you help me understand where to check the 19v 3 and 5v?
                            • thema979@yahoo.it
                              • Sep 2022
                              • 10
                              • Italia
                              Thank you 🙏🙏
                              • viktinho
                                • Oct 2022
                                • Mozambique
                                Thank you 🙏🙏
                                Here is the controllers of of 3v and 5v.
                                • thema979@yahoo.it
                                  • Sep 2022
                                  • 10
                                  • Italia
                                  i have nothing, 5v and 3v is absent.
                                  these are normal in short?
                                  what do you think could be the problem?
                                  thank you
                                  • mon2
                                    • Dec 2019
                                    • 14220
                                    After some detective work - the 840 G3 appears to be almost identical for the charger + DCin mosfet area in all models:
                                    840 G1
                                    840 G2
                                    840 G3
                                    Based on this detail, download the schematic & boardview files from here:
                                    https://www.badcaps.net/forum/showth...ghlight=840+g1
                                    The schematic and part numbers match across the logic boards. The boardview files may be different but for now, it does not matter.
                                    Review the attached.
                                    1) Connect the external power adapter.
                                    2) Start with mosfet @ Q6011 -> confirm the voltage on pins 1-2-3 = Source pins.
                                    Meter in 20v DC or higher voltage scale.
                                    Red meter probe on pins 1-2-3 and black meter probe to ground.
                                    What is the voltage reading ? It should be ~19 volts. Confirm it.
                                    3) Next, check the voltage on pin # 4 = GATE pin for this mosfet.
                                    What is the voltage ?
                                    Voltage on DRAIN pins 5-6-7-8 -> what is the voltage ?
                                    In each case, red probe to pin to test & black probe to ground.
                                    We are interested to review the voltage readings of each mosfet (Q6011 & Q6012).
                                    Post all measurements.
                                    The voltage @ Q6012, pin # 5-6-7-8 will power the logic board.
                                    • thema979@yahoo.it
                                      • Sep 2022
                                      • 10
                                      • Italia
                                      840 G1
                                      840 G2
                                      840 G3
                                      now the situation is really strange. at first on Q60010 I had 19v, now not anymore. the situation is like in the video and Q60010 is hot. I have no voltage on Q60011 and Q60012.
                                      I do not know what to think
                                      • mon2
                                        • Dec 2019
                                        • 14220
                                        Locate L6035 which will be near the dcin connector (JACK6000).
                                        What is the voltage on each side of L6035?
                                        If required, remove L6035 with flux and hot air to confirm that the adapter voltage is present.
                                        It is very possible that the first mosfet is defective.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • mferna14
                                          Logic Board 820-01987-A missing PP3V3_S5
                                          by mferna14
                                          Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from...
                                          06-07-2025, 05:07 PM
                                        • mferna14
                                          Logic Board 820-00840-A Missing EDP_BKLT_EN
                                          by mferna14
                                          Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
                                          07-10-2024, 05:18 PM
