820-00165 A1466 MacBook Air missing PPBUS_G3H
  • techstar85
    • May 2021
    Hi guys,
    I'm working on an 820-00165 which had encountered fluid damage, mainly around U7100. Replaced U7100 and a couple of resistors that had corroded off the board, flux and boiled the crap away from a couple of other areas which do not appear to have any lasting damage.
    Initially had no green light, diagnosed as a failed D7012, now have green light on the magsafe, but still not getting PPBUS_G3H and no fan spin. No short on PPBUS and fuse is fine.
    PP5V_S5 is only 0.8v and PPDC_IN is 16.4v. Tried to decipher the scematic to work out where the rail is being pulled down but getting stuck
    Can anyone point me in the right direction?
  • mon2
    • 14667
    Re: 820-00165 A1466 MacBook Air missing PPBUS_G3H
    hi.
    1) voltage @ D7005, pins 1, 2 and 3 ? (PPVIN_G3H_P3V42G3H)
    2) voltage @ R7095, pin # 2 (P3V42G3H_FB) ?
    3) voltage @ PP3V42_G3H = L7095, pin # 2 ?
    4) Power down, meter in resistance mode.
    Black lead to ground; red lead on L7095, pin # 1 - reading in ohms ?
    Black lead to ground; red lead on L7095, pin # 2 - reading in ohms ?
    5) voltage of PPDCIN_G3H ?
    6) voltage of PPDCIN_G3H_INRUSH ?
    7) voltage of CHGR_UGATE ?
    8) voltage of CHGR_LGATE ?
    9) voltage of PP5V1_CHGR_VDD ? This rail powers U7100 which creates the PPBUS_G3H voltage.
    • techstar85
      • May 2021
      Hi mon2, thanks for responding:
      1. pin1 = 0v , pin2 = 16.3v, pin3= 16.0v
      2. 1.24v
      3. 3.38v
      4. Pin1= 50k but appears to jump up and down between 48-52k
      Pin2 = 87.6k
      5. 16.44v
      6. 0v
      7. 0v
      8. 0v
      9. 0v
      I had identified that PP5V1 wasn't present (therefore U7100 most likely not powering up) but thats where I got stumped by trying to interpret the schematic - I'm still learning!
      • mon2
        • 14667
        1) voltage @ PPDCIN_G3H_ISOL ?
        2) voltage @ CHGR_ACIN ?
        3) voltage @ PPCHGR_DCIN_D_R ?
        4) voltage @ CHGR_DCIN ?
        Also, my bearings for U7100 may be incorrect. This regulator is powered, I believe through CHGR_DCIN, pin # 2.
        This regulator, U7100 from Intersil (now Renesas) does not have public datasheets available for our review. However, based on assorted youtube videos, most likely U7100 is damaged but do post the above details to rule out any support component causing this issue.
        U7100 = ISL6259HRTZ
        https://www.aliexpress.com/premium/I...psort=1&page=1
        • techstar85
          • May 2021
          1. 16.44v
          2. 4.32v
          3. 16.41v
          4. 16.41v
          U7100 has already been replaced with new (not from donor) prior to onewire circuit being fixed to restore green light
          • BMCappelletti
            Macbook Air A1466 EMC 3178 missing power and liquid damaged
            by BMCappelletti
            Hi everyone.
            Macbook Air A1466 EMC 3178 (board 820-00165 A) not turning on and no charging light. Completely dead. With no battery connected it would power up and I could hear the chime, but nothing on the screen and then a sudden turn off. Sometimes during the chime. Opened it up and found some liquid damage. The flat that connects both boards has damage in one side (with a missing pin already). The connectors on the boards are fine, though.
            Also, there was liquid damage on the included picture area, which are R8111 and C8111. A quick and soft brush on it made the resistor be gone....
            04-15-2024, 01:24 PM
          • AlexVG
            MacBook A1466 820-165-A No power Missing PM_SLP_S4_L
            by AlexVG
            It's me again!
            Another issue, I am not too lucky.
            I have MacBook A1466 820-165-A after another service. Most of parts have rough traces of soldering (I guess they had been troubleshooting without success)
            Missing PM_SLP_S4_L
            because absent PM_SLP_S5_L
            What processor needs to form PM_SLP_S5_L signal?
            I tried to connect U8000 and U8180 to run directly but it doesn't want to run.
            All of these signals are present:
            1. PPVRTC_G3H (VCCRTC) 3.3
            2. RTC_RESET_L (RTCRST#) 3.3
            3....
            01-29-2023, 05:50 PM
          • Instafixx
            Macbook A1466 820-00165 PPBUS Missing
            by Instafixx
            Hello, I have a Macbook A1466 80-00165 which is not turning on. It is taking 0 ohms and the PPBUS_G3H is at 0v at F7140.
            Tried Injecting 1V but nothing gets hot.
            Removed the F7140 fuse and the Pin#2 is still short to ground.
            Can anyone suggest where the issue is ?
            05-20-2023, 06:42 AM
          • psdavid65
            Macbook Air A1466 820-3437-B Booting Problem
            by psdavid65
            I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
            06-20-2024, 12:27 AM
          • Adogabriel100
            Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
            by Adogabriel100
            Hey! This is a A1278 macbook 2011.
            Problem: Not turning on / No green light
            Im using by3200s charger.
            Voltajes:
            PPBUS_G3H = 12.26v
            SMC_RESET_L = 3.3v
            PP3V42_G3H = 3.42v
            U7000 =
            Pin 1 CHGR_AGATE = 0v
            Pin 2 CHRG_DCIN = 19v
            Pin 3 CHRG_ACIN = 4.6v
            Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
            Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
            Pin 12 PP3V42_G3H = 3.42v
            Pin 13 CHRG_RST_L = 3.3V
            Pin 14 SMC_BC_ACOK = 0.8V
            Pin 19 PP5V1_CHRG_VDD = 5.05V
            Pin 20 PP5V1_CHRG_VDDP = 5.03V...
            04-01-2024, 01:02 PM
