MacBook A1466 820-165-A No power Missing PM_SLP_S4_L
  • AlexVG
    • Apr 2022
    • 138
    • SPAIN
    It's me again!
    Another issue, I am not too lucky.
    I have MacBook A1466 820-165-A after another service. Most of parts have rough traces of soldering (I guess they had been troubleshooting without success)
    Missing PM_SLP_S4_L
    because absent PM_SLP_S5_L
    What processor needs to form PM_SLP_S5_L signal?
    I tried to connect U8000 and U8180 to run directly but it doesn't want to run.
    All of these signals are present:
    1. PPVRTC_G3H (VCCRTC) 3.3
    2. RTC_RESET_L (RTCRST#) 3.3
    3. PCH_SRTCRST_L (SRTCRST#) 3.345
    4. PCH_INTVRMEN_L (INTVRMEN) 3.2
    5. PCH_DSWVRMEN_L (DSWVRMEN) 3.23
    6. SYSCLK_CLK32K_RTCX1 (RTCX1) 0.6 pulsing
    7. PP3V3_S5 (VCCDSW3-3) 3.3
    8. PM_DSW_PWRGD (DPWROK) 3.4
    9. PP3V3_SUS (VCCSUS3) 3.3
    10. PM_BATLOW_L (BATLOW#) 3.3
    11. PM_RSMRST_L (RSMRST#) 3.3
    +1. PM_PWRBTN_L (PWRBTN#) 3.4
    Would you help me please!
    Thank you in advance.
  • reformatt
    • Feb 2020
    • 1534
    Re: MacBook A1466 820-165-A No power Missing PM_SLP_S4_L
    Eliminate the simple stuff first. Measure resistance to ground of all rails, especially that of the PCH (L7630). Usually this is 200 ohms or more, but I've had some measure 150ohms and working.
    U1900 generates the clock, and is a common issue from liquid damage. Use a scope to ensure you get ~1V p-p 32khz signal here (pin12 or test pad near U7600). If everything in the sequence is good, you need to usually look at the SMC. Is the edge bonding still intact? Is there evidence of rework around it?
    My first step is to remove the bonding and reflow the SMC with PM_SLP_x faults, especially if there is evidence of liquid damage around it. Then also ensure you don't have any pulsing going on. This can be quite rapid and easy to miss without a scope.
    The board I just fixed had extensive liquid damage, needed a reflow of the SMC to at least get the board pulsing, and a jumper to bridge an open circuit track from the U6100 to the CPU. I mention this one as this had no PM_SLP_S5_L either, and everything was good to that point.
    • AlexVG
      • Apr 2022
      • 138
      • SPAIN
      Thank you
      -L7630 is OK (230 Om)
      -There are no ground on all rails.
      U1900 is working perfectly - generates the clock 32khz signal
      And when I put 3.2 and 1.2 V directly to 6 and 14 pins it generates SYSCLK_CLK25M_CAMERA and SYSCLK_CLK25M_TBT pulses
      - SMC looks well, the edge bonding compound at there places. Without rework traces.
      - As for the SPI request - I can watch exchange. But it is strange- pretty short.
      Will check SPI tomorrow.
      • reformatt
        • Feb 2020
        • 1534
        You need to establish whether you're getting PM_SLP_x at all, or if it's starting up and shutting down. This is pretty important as far as not wasting a lot of time on these.
        • AlexVG
          • Apr 2022
          • 138
          • SPAIN
          Thanks.
          It's very interesting - I have two attempts to run.
          All signals and main voltages appear twice shortly and then everything is disabled.
          What it means? Short circuit? How I can find where is?
          • AlexVG
            • Apr 2022
            • 138
            • SPAIN
            Looks like I found possible cause.
            It's very interesting case.
            While the main part of board was plowed with a 60 watt iron, the U4600 switch had removed very carefully and has not trace at all.
            I didn't notice the U4600 switch missing.
            So, will put it at place and check.
            NO, It's my mistake.
            FAULT (pin 8) is pull up to 3.3 and the absence of switch U4600 cannot affect the running.
            (of course I put it back in place, but didn't change anything)
            • reformatt
              • Feb 2020
              • 1534
              So I do have a couple of double pulse boards in my donor pile. Every time I've looked at them, they take up too much time and I put them back in as I've other stuff to do. Today being quiet, I went through all the SMC inputs, and virtually ruled everything out. Pretty sure on this board I've replaced the SMC to rule it out.
              What makes this fault quite frustrating is that everything appears ok from a signal and voltage point of view. I'm thinking it may be a PPBUS_G3H issue. Noted a slight sag during startup, but not enough that it should make a difference.
              • AlexVG
                • Apr 2022
                • 138
                • SPAIN
                Have you checked SPI?
                Maybe SPI is the cause?
                • reformatt
                  • Feb 2020
                  • 1534
                  The SPI traffic is normal. In fact, if you remove U6100, the board will pulse every few seconds (which is normal). There is SPI data activity on all the lines to the CPU, even traffic on the SVID lines to U7200.
                  Where it seems to stop is there is no activity on the LPC lines from the PCH back to the SMC. The lines go high, reset line goes high, and there is a clock, but there doesn't seem to be any data activity. It's hard to tell, as the line only goes active for a short period before the SMC shuts down (my scope doesn't have data capture capabilities). AFAIK, the PCH itself is the host for LPC comms, so.....
                  This leads me to conclude that this is either a bad PCH or more likely it needs to be reballed or reflowed. I don't have the right gear to do this on such a large chip currently.
                  • Simplebeans
                    • Sep 2021
                    • 135
                    Originally posted by AlexVG
                    Thank you
                    Did you check the signals around the SPI rom circuit to make sure there all ok? i.e the SPI_MLB_CS_L etc?
                    • AlexVG
                      • Apr 2022
                      • 138
                      • SPAIN
                      Thank you.
                      I came from TV repairing, I have reballing station. Will try.
                      • AlexVG
                        • Apr 2022
                        • 138
                        • SPAIN
                        Is it possible download video here?
                        I made video my SPI exchanging, but don't know how put it.
                        • mon2
                          • 14715
                          I think you should be able to do this but zip / rar it and then attach it.
                          • AlexVG
                            • Apr 2022
                            • 138
                            • SPAIN
                            Yes of course, I watch exchanging, but it is too short in time. Short length duty.
                            • AlexVG
                              • Apr 2022
                              • 138
                              • SPAIN
                              Faulty main board exchange here.
                              • AlexVG
                                • Apr 2022
                                • 138
                                • SPAIN
                                Working main board exchange
                                • AlexVG
                                  • Apr 2022
                                  • 138
                                  • SPAIN
                                  Yes
                                  LPC_AD<0>
                                  LPC_AD<1>
                                  LPC_AD<2>
                                  LPC_AD<3>
                                  HIGH without any activity during 400 ms. Then down.
                                  LPC_CLK24M_SMC
                                  has fluctuation 400 ms. Then down too.
                                  • reformatt
                                    • Feb 2020
                                    • 1534
                                    We don't have access to source code or flow charts/state diagrams for the SMC, which I think would be needed to debug that further. What we know about how it reacts to certain faults are mainly from reverse engineering and observation, than anything provided by Apple.
                                    For example, a shorted power rail results in cycling of all rails. As does failure to load the BIOS from U6100. Absent PP3V3_S5_SMC_VDDA results in it only working in SMC bypass. So the double pulse of rails then off to date has no solution. And it's a common enough failure on these boards for me to think it's CPU related rather than anything else. So reball or replacement of the CPU would be the next step if I had the gear to do it, and the patience.
                                    • AlexVG
                                      • Apr 2022
                                      • 138
                                      • SPAIN
                                      I Try to find BGA Reballing Stencil for this CPU.
                                      • AlexVG
                                        • Apr 2022
                                        • 138
                                        • SPAIN
                                        Don't miss me.
                                        I bought stencils and waiting for delivery.
                                        Let you know...
                                        • BMCappelletti
                                          Macbook Air A1466 EMC 3178 missing power and liquid damaged
                                          by BMCappelletti
                                          Hi everyone.
                                          Macbook Air A1466 EMC 3178 (board 820-00165 A) not turning on and no charging light. Completely dead. With no battery connected it would power up and I could hear the chime, but nothing on the screen and then a sudden turn off. Sometimes during the chime. Opened it up and found some liquid damage. The flat that connects both boards has damage in one side (with a missing pin already). The connectors on the boards are fine, though.
                                          Also, there was liquid damage on the included picture area, which are R8111 and C8111. A quick and soft brush on it made the resistor be gone....
                                          04-15-2024, 01:24 PM
                                        • Instafixx
                                          Macbook A1466 820-00165 PPBUS Missing
                                          by Instafixx
                                          Hello, I have a Macbook A1466 80-00165 which is not turning on. It is taking 0 ohms and the PPBUS_G3H is at 0v at F7140.
                                          Tried Injecting 1V but nothing gets hot.
                                          Removed the F7140 fuse and the Pin#2 is still short to ground.
                                          Can anyone suggest where the issue is ?
                                          05-20-2023, 06:42 AM
                                        • psdavid65
                                          Macbook Air A1466 820-3437-B Booting Problem
                                          by psdavid65
                                          I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                                          06-20-2024, 12:27 AM
                                        • Adogabriel100
                                          Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                                          by Adogabriel100
                                          Hey! This is a A1278 macbook 2011.
                                          Problem: Not turning on / No green light
                                          Im using by3200s charger.
                                          Voltajes:
                                          PPBUS_G3H = 12.26v
                                          SMC_RESET_L = 3.3v
                                          PP3V42_G3H = 3.42v
                                          U7000 =
                                          Pin 1 CHGR_AGATE = 0v
                                          Pin 2 CHRG_DCIN = 19v
                                          Pin 3 CHRG_ACIN = 4.6v
                                          Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                                          Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                                          Pin 12 PP3V42_G3H = 3.42v
                                          Pin 13 CHRG_RST_L = 3.3V
                                          Pin 14 SMC_BC_ACOK = 0.8V
                                          Pin 19 PP5V1_CHRG_VDD = 5.05V
                                          Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                                          04-01-2024, 01:02 PM
                                        • echothegamer
                                          Macbook A1466 dies when charger disconnected
                                          by echothegamer
                                          Hello all,
                                          Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                                          Details:
                                          Macbook 13' A1466
                                          Board (820-3209-A)
                                          Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                                          Pictures below of Boardview and schematic...
                                          I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                                          It's an older model and it is very likely that battery has become...
                                          10-28-2023, 12:00 PM
