Macbook A1466 820-00165 PPBUS Missing
  • Instafixx
    • Jul 2022
    • 374
    • India
    Hello, I have a Macbook A1466 80-00165 which is not turning on. It is taking 0 ohms and the PPBUS_G3H is at 0v at F7140.
    Tried Injecting 1V but nothing gets hot.
    Removed the F7140 fuse and the Pin#2 is still short to ground.
    Can anyone suggest where the issue is ?
  • mon2
    • 14587
    Re: Macbook A1466 820-00165 PPBUS Missing
    What is the exact resistance in ohms to ground of pin #2?
    Remove all power before measuring resistance.
    Are you using the original magsafe adapter?
    3v42 rail is ok and stable?
    • Instafixx
      • Jul 2022
      • 374
      • India
      Found C7434 PPBUS_S5_HS_COMPUTING_ISNS short. Replaced it. Replaced the Fuse to check and getting 8.6V now on both pins but the device wont turn on. No Fan Spin as well.
      Removed the Fuse and Removed Power.
      Resistance at F7140
      Pin#1 133 Ohms
      Pin#2 475 ohms
      Magsafe Charger is Original.
      PP3v42 is stable.
      • mon2
        • 14587
        Resistance at F7140
        Pin#1 133 Ohms
        Pin#2 475 ohms
        Both of these are too low of a resistance value.
        Can you confirm the readings? Test with another meter.
        Do you have a thermal camera?
        • Instafixx
          • Jul 2022
          • 374
          • India
          Visual Inspection showed that U6100 seemed burned out. Replaced that. It is working fine now.
          • Instafixx
            • Jul 2022
            • 374
            • India
            So i have an issue on this Mac, was sick so was away from office these days.
            After replacing the U6100, the macbook has become very slow. If it goes to sleep it would take a very very very long time to come back awake as if it had shut. So i went ahead and did an internet recovery to go back to a faster MacOS. But after that it doesnt boot up. The loading bar comes with the apple logo, it goes upto the end but wont boot up.
            Have i installed the wring U6100 version chip or is it something else.
            • BMCappelletti
              Macbook Air A1466 EMC 3178 missing power and liquid damaged
              by BMCappelletti
              Hi everyone.
              Macbook Air A1466 EMC 3178 (board 820-00165 A) not turning on and no charging light. Completely dead. With no battery connected it would power up and I could hear the chime, but nothing on the screen and then a sudden turn off. Sometimes during the chime. Opened it up and found some liquid damage. The flat that connects both boards has damage in one side (with a missing pin already). The connectors on the boards are fine, though.
              Also, there was liquid damage on the included picture area, which are R8111 and C8111. A quick and soft brush on it made the resistor be gone....
              04-15-2024, 01:24 PM
            • AlexVG
              MacBook A1466 820-165-A No power Missing PM_SLP_S4_L
              by AlexVG
              It's me again!
              Another issue, I am not too lucky.
              I have MacBook A1466 820-165-A after another service. Most of parts have rough traces of soldering (I guess they had been troubleshooting without success)
              Missing PM_SLP_S4_L
              because absent PM_SLP_S5_L
              What processor needs to form PM_SLP_S5_L signal?
              I tried to connect U8000 and U8180 to run directly but it doesn't want to run.
              All of these signals are present:
              1. PPVRTC_G3H (VCCRTC) 3.3
              2. RTC_RESET_L (RTCRST#) 3.3
              3....
              01-29-2023, 05:50 PM
            • psdavid65
              Macbook Air A1466 820-3437-B Booting Problem
              by psdavid65
              I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
              06-20-2024, 12:27 AM
            • Adogabriel100
              Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
              by Adogabriel100
              Hey! This is a A1278 macbook 2011.
              Problem: Not turning on / No green light
              Im using by3200s charger.
              Voltajes:
              PPBUS_G3H = 12.26v
              SMC_RESET_L = 3.3v
              PP3V42_G3H = 3.42v
              U7000 =
              Pin 1 CHGR_AGATE = 0v
              Pin 2 CHRG_DCIN = 19v
              Pin 3 CHRG_ACIN = 4.6v
              Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
              Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
              Pin 12 PP3V42_G3H = 3.42v
              Pin 13 CHRG_RST_L = 3.3V
              Pin 14 SMC_BC_ACOK = 0.8V
              Pin 19 PP5V1_CHRG_VDD = 5.05V
              Pin 20 PP5V1_CHRG_VDDP = 5.03V...
              04-01-2024, 01:02 PM
            • echothegamer
              Macbook A1466 dies when charger disconnected
              by echothegamer
              Hello all,
              Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
              Details:
              Macbook 13' A1466
              Board (820-3209-A)
              Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
              Pictures below of Boardview and schematic...
              I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
              It's an older model and it is very likely that battery has become...
              10-28-2023, 12:00 PM
