DAG3DCMBCC0 REV C cpu shorted?
  • mauareju
    • Oct 2019
    • 17
    • mexico
    hi everyone
    as the title says i got this board with a possible short in cpu
    when i connect the power supply the laptop draws 0.015 amps and when press the power button the light in the same button turns on and quickly turn off at the same time that power input ligth do the same
    its a hp omen dc1003la with a i7 9750h and a 1660 ti
    when push the button the laptop max amp draw is 0.120 amps and turn off
    measurement near the cpu show me a full short ill attach the image
    how can confirm that cpu is shorted
    i tried injecting 1volt and 1 amp limited but nothing get hot even cpu still cold , should inject more current?
    the only low measurement is near the cpu other parts on the board sems to be fine
    thanks in advance
  • myth77
    • Feb 2017
    • 380
    • Croatia
    Re: DAG3DCMBCC0 REV C cpu shorted?
    What is exact ohm reading on that cpu coils relative to ground?
    • mauareju
      • Oct 2019
      • 17
      • mexico
      hi
      relative to ground is 0.2 ohm
      • myth77
        • Feb 2017
        • 380
        • Croatia
        I would remove those vcore coils and check on which side resistence is 0.2 ohm
        • mauareju
          • Oct 2019
          • 17
          • mexico
          is on cpu side?
          all hopes are lost?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            0.2 Ohms is too low even for a 9th gen cpu though i'm not 100% sure.
            • mauareju
              • Oct 2019
              • 17
              • mexico
              yes i measured an i5-8300h wich was functional and in the same line in that laptop has an 2.9 ohm value
              the strange thing here is that i inject 1v and 1.6a to this i7-9750h and doesnt get hot, any component, should inject more cutrrent or volt?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                More current, not volt. You can pump upto 5Amp. If SOC is shorted it will consume almost 1A or higher current and u cant feel the heat so easily. U leave with current injected for 10 mins and then it may be slightly warm.
                • mnciks11
                  • Aug 2019
                  • 345
                  • south Africa
                  Originally posted by mauareju
                  hi
                  This is not shorted, i've seen even0.1 ohm and the machine was working 100%
                  • mnciks11
                    • Aug 2019
                    • 345
                    • south Africa
                    Totally agree with you, if the PCH is intergrated within the CPU, then we can conclud that the cpu is shorted but believe me guys ive seen 0.1 ohm and the machine was working 100%
                    • mnciks11
                      • Aug 2019
                      • 345
                      • south Africa
                      hi everyone
                      thanks in advance
                      I think that board is missing 1.05v please check
                      • myth77
                        • Feb 2017
                        • 380
                        • Croatia
                        What was the cpu?
                        And did you meassure ohm right after you unplug the power or after when it was cooled and power drained?
                        • mnciks11
                          • Aug 2019
                          • 345
                          • south Africa
                          What was the cpu?
                          Obvious you can't measure for ohms while plugged in, it was unplugged...
                          I can't really remember but I know for sure that it was the latest
                          • myth77
                            • Feb 2017
                            • 380
                            • Croatia
                            I didn't mean you measure it while power on..There is difference in ohm resistance if you measure it few seconds after the power cord unplugged and let's say half hour after power cord unplugged...
                            • mauareju
                              • Oct 2019
                              • 17
                              • mexico
                              yes 1.05v is mising
                              is this voltage always?
                              where i can find the source of this voltage? there is no scheme of this board
                              There is more photos of the board
                              • mauareju
                                • Oct 2019
                                • 17
                                • mexico
                                yes the pch is on another chip is not in the cpu
                                • mauareju
                                  • Oct 2019
                                  • 17
                                  • mexico
                                  ok guys so...
                                  i decided to turn up these coils that gives power to cpu and now the cpu measurement is 2.3 ohm so thats normal
                                  in the image that i attached see in black one coil tha gives full ground and in the blue these coils give 511 each in diode mode so i think that the mosfet or something in that line is causing the short
                                  ill inject some voltage and i will keep you update
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Not shorted likely. Meter will buzz in diode mode as its supposed to be very low resistance. Measue in ohms mode and not in diode mode.
                                    • mauareju
                                      • Oct 2019
                                      • 17
                                      • mexico
                                      yes this measurement was in diode mode an resistance an resistance shows 0.002 ohm i think is full short
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        For sure.
                                        Become a Badcaps supporter
                                        Thanks to all supporters.
                                        • reessi
                                          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                          by reessi
                                          Hello:
                                          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                          I started on the ACER:
                                          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                          10-29-2024, 11:31 AM
                                        • Yanleb
                                          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                          by Yanleb
                                          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                          D608, good
                                          D618 RF101L4S, good (See warning 1 below)
                                          D619 RF101L4S, good (See warning 1 below)
                                          D865 RF101L4S, shorted (See warning 1 below)
                                          IC464 Inverter HA MC74HC1G14, shorted...
                                          03-09-2020, 12:00 AM
                                        • modtool
                                          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                          by modtool
                                          Hi to all,
                                          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                          04-01-2025, 08:22 AM
                                        • BalkanBoy
                                          Dead Razer Blade 14 2022, shorted CPU?
                                          by BalkanBoy
                                          today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                                          Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                                          I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                                          Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                                          I removed coil and injected 0.7V, it draw around...
                                          09-27-2024, 12:44 PM
                                        • guizmo1967
                                          Dell Latitude 5501 LA-H181P shorted power rail
                                          by guizmo1967
                                          This is my problem:
                                          Laptop: Dell Latitude 5501
                                          Motherboard: EDC51 LA-H181P
                                          I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
                                          I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
                                          I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
                                          I injected +1.05V - 2A...
                                          07-25-2023, 06:56 PM
