MSI GE62 Laptop Motherboard with Short on main power rail
  • mon2
    • Dec 2019
    • 14216
    Re: MSI GE62 Laptop Motherboard with Short on main power rail
    Post a clear pic of the usb port connector. Top and bottom side.
    If the port is usb 2.0 style = black plastic insulator, there will be 4 connector pins.
    Vbus
    Data+
    Data-
    Ground
    Remove all power. Meter in DIODE mode.
    Red meter probe, yes RED to ground.
    Black meter probe to Data+.
    What is the measurement?
    Repeat for Data- pin.
    Repeat for Vbus pin.
    Post all measurements.
    • Krilan1990
      • Jan 2023
      • 37
      • Poland
      the power supply works ok, date- to ground is 10 ohm, date + to ground is 60 kohm
      • mon2
        • Dec 2019
        • 14216
        So D- is shorted on this leg of the circuit.
        Near this USB connector should be a current limit load switch or ESD TVS diode (3 legs).
        Share pics of the area. Very likely, that part needs to be replaced. Common fault.
        • Krilan1990
          • Jan 2023
          • 37
          • Poland
          there are diagrams on the forum and there are no rare protections in the diagram
          • Krilan1990
            • Jan 2023
            • 37
            • Poland
            when I get thermopads, I will still look for elements on the board, I will have my computer dismantled. I know it's on the album but I don't know where. Of course, if they planned such a thing, but the scheme does not confirm it
            • Krilan1990
              • Jan 2023
              • 37
              • Poland
              #26
              unfortunately there is no boardview anywhere
              • mon2
                • Dec 2019
                • 14216
                What is the insulator color of the defective USB port ?
                Is it BLACK = USB 2.0 or BLUE = USB 3.0 / 3.1 ?
                Perhaps it is BLUE = USB 3.0/3.1 ? Then there is a USB charger IC that mates with the D- and D+ line @ U22.
                Remove all power. Meter in resistance mode.
                Use the 2 meter probes to confirm if U22 is linked to the defective USB port connector.
                One meter probe to D-, the other meter probe to USB_P9N_RR (pin # 11 of U22).
                What is the measurement ? If it ~0 ohms, then this charger IC is involved with this connector and likely is the fault.
                From the v1.0 schematics, USB_CON3 makes use of the USB charger IC @ U22.
                • Krilan1990
                  • Jan 2023
                  • 37
                  • Poland
                  #28
                  Black usb 2.0
                  • Krilan1990
                    • Jan 2023
                    • 37
                    • Poland
                    #29
                    I have damaged USB 2.0
                    from the side of the power sockets, there is a date-10ohm indication
                    • Krilan1990
                      • Jan 2023
                      • 37
                      • Poland
                      #30
                      all usb 3.0 ports work fine
                        • 20933
                        all the available schematics have been posted already https://www.badcaps.net/forum/showthread.php?t=67619
                        • Krilan1990
                          • Jan 2023
                          • 37
                          • Poland
                          #32
                          I know
                          • mon2
                            • Dec 2019
                            • 14216
                            You will need to post more details of this connector to have a chance to fix the fault.
                            The connector will have a silk screen marking on the pcb.
                            From the board and schematic you have, find the exact connector.
                            Without you jumping in to share the requested details, the usb port cannot be fixed.
                            • Victor Moreira Silva
                              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                              by Victor Moreira Silva
                              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                              Well, my decice specs are the following:
                              Model: Acer Nitro 5 AN517-54-55T5
                              CPU: Intel Core i5-11400H
                              GPU: NVIDIA GeForce GTX 1650
                              Motherboard: GH51G LA-L181P Rev:1c
                              The symptom:
                              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                              05-26-2025, 10:49 AM
                            • grimacelord
                              Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                              by grimacelord
                              Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                              After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                              I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                              10-24-2024, 12:31 PM
                            • nagkiller
                              Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
                              by nagkiller
                              Hello everyone!
                              This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
                              After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
                              Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
                              The attached boardview file is very similar to this grafic card, which I am basing the repair on.
                              I would like some...
                              05-10-2025, 09:19 AM
                            • joshAU
                              Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                              by joshAU
                              Hi all.
                              This notebook was showing no signs of life.
                              I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                              However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                              If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                              I tried replacing the MOSFET with a new one, but again no voltage on the...
                              05-29-2024, 12:33 AM
                            • techrepairheide
                              Gaming laptop Clevo NH79EP with short on 5VS-rail
                              by techrepairheide
                              first of all I want to apologize for my bad English, but I try to give my best.
                              Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
                              For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
                              10-13-2024, 02:49 PM
