MSI GE72 2QC Schematic plz
Re: MSI GE72 2QC Schematic plz
Its available on some paid sites. MS-16J2/1792Comment
Dunno if it's close enough.Attached Filesif you find these attachements useful please consider making a small donation to the site
OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
I found it .Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello, I am looking for a schematic for msi ge62 2qd (ms-16j21 ver.1.0 in version 4.5mb). i will be grateful for any help.Comment
I'm not sure if the schematic is complete or if there are some gaps in the pages. I saw that there is a diagram on vinafix but it takes up more space so I am asking if anyone has such a file and can upload it to the forumComment
In my laptop there was a damage to the usb2.0 socket, after initial measurements it turned out that between the mass and the date - there is 10 ohms and between the date + and the mass is about 60 kohm. there is also a high impedance between vcc (5V and ground. The laptop is msi ge62 2qd motherboard ms16j21 ver1.0. is it possible that there is some element between the bridge and usb that could be damaged and ground date-. I found a diagram on the vinafix website but it is a bit too expensive for me to download it. and the free versions of the schematics may not be complete. generally the laptop works fine, the temperatures oscillate between 40-50 degrees and the other components work. Please advise what could be done with it, how to save these usb and is it profitable and how much can it cost.Thanks in advance for all suggestionsComment
usb 2.0 , this laptop has only one usb 2.0 port, next to the sd card slot and the power adapter portComment
thank you i found it. but I do not know if this socket has a system between the bridge that could be damaged?? did he break the bridge?Comment
after connecting the mouse, the computer does not see the device, it does not recognize it. when I measure the signal pins with a multimeter, on the data pins I have 60kohm and 10 ohm. as one pin was shorted to ground. I do not know if there is a pullup resistor or some esd element between the socket and the bridge, there is no burn mark on the board and the computer works normally. only the usb2.0 port does not work.Comment
I measured on a turned off laptop. when the 16j12 board is disconnected, it is out of range and when I connect the tape to the motherboard and measure on the pins, it has this valueComment
by TinkerTronHey everyone,
I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
Instead, here's what's been bugging me so far:
The schematic...3 Photos-
Channel: Troubleshooting Audio Equipment
by atunguydIi wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...-
Channel: Schematics and Boardviews
by SdhjmI'm asking if anyone has a schematic for the dag3pmb18b0 rev:b g3p board. I found a schematic of the board, but I don't have the component numbers. If anyone needs a schematic, I can send it to you, but I don't have the numbers....
Channel: Schematic Requests ONLY!
11-26-2025, 03:43 AM -
by ThetechdudeHi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
Thanks.-
Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
06-26-2025, 02:41 PM -
- Loading...
- No more items.
