MSI GE62 Laptop Motherboard with Short on main power rail
  • worlor
    • Oct 2020
    • 28
    • France
    I am currently learning to repair laptop motherboard and I need some advice/help.
    I have a MSI GE62-6PQ laptop that didn't boot. It's an old laptop that got a glass of coke :/
    I have cleaned the motherboard with isopropyl alcohol and a brushteeth.
    The motherboard is a MS-16J51. I put the schematics attached.
    I also attach high res pictures of the board.
    Symptoms :
    When I connect it to the power supply, it goes into protection.
    What I have done :
    Checked the fuse : OK
    Visual check OK : No burned components
    I have measured the resistance between PWR_SRC (main rail) and GND : 0.2 Ohm
    The main rail is shorted, but where
    The resistance between PWR_SRC and CHOKE9 (5V rail) was very low (<1ohm), so I have measured the resistance betweend source and drain of MOSFETs PQ13 and PQ15, both shorted. So i removed them. But the short is always here
    You can look at page 40 of the schematics
    I have tested the MOSFETs separatly, they seems OK.
    The resistance between PWR_SRC and PL4 and PL5 are very low too. I think there is also a short near the CPU power. But I want to resolve the short on the 5V rail first
    The others mesurement seems OK
    What can I check to find this ***** short ? Any help/advice appreciated
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: MSI GE62 Laptop Motherboard with Short on main power rail
    When power supply goes into protection, its your +19V rail which is shorted. Locate the CLR after 2 dc-in mosfets and remove it from the mb. Measure resistance on both pads of CLR(after removing it. One side will show short to Ground. Inject +1V/1A with dc supply and gradually increase AMP(not Voltage) upto 5Amp and find out what is getting hot. However, if you inject more then 1V/5A , then there is risk of onboard CPU/GPU getting shorted if one of the high side mosfet is leaky/shorted on cpu/gpu rail. So try the above steps and report back.
    • worlor
      • Oct 2020
      • 28
      • France
      Hello, thanks for help
      I am not sure about the CLR you talking about. Is it PR17 ? 0.005Ohm resistor
      See image attached
      • mon2
        • Dec 2019
        • 14239
        Yes, PR17.
        CLR = current limiting resistor.
        • worlor
          • Oct 2020
          • 28
          • France
          Originally posted by mon2
          Yes, PR17.
          OK, thank you, gonna desold and try with a power supply
          • worlor
            • Oct 2020
            • 28
            • France
            OK I have injected current on main rail. 1.1V but with 3A because supply can't do more.
            I have searched for hot zone on the mainboard.
            I have found one place that became very hot near +VCCSA mosfet PQ24.
            The mosfets from +VCC_Core were hot too.
            I think to desold choke and capacitor on these rails to see if the short gone.
            Am I right ?
            Any better idea ?
            • worlor
              • Oct 2020
              • 28
              • France
              Hello
              After removal of chokes, I have found the PQ20 MOSFET was shorted.
              I have removed it, and I have now 3kOhms between pwr_src (19V) and gnd.
              I will replace it and see what happens when I put DC IN
              • worlor
                • Oct 2020
                • 28
                • France
                But I have measured 0.4ohm between GND and +VCC_Core. Do you think it's good ? Or CPU is shorted ?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  0.4 Ohms is bit low and likely cpu is shorted.
                  • coffinsupply
                    • Dec 2021
                    • usa
                    did it fix?
                    • mosfetratus
                      Sure Not
                      • Feb 2019
                      • 174
                      • Resistron
                      Mosfet can cause cpu to be shorted.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Yes as long as it is high side mosfet as there is 19V on its drain and when shorted 19v will reach to cpu-damaging it.
                        • worlor
                          • Oct 2020
                          • 28
                          • France
                          Originally posted by coffinsupply
                          did it fix?
                          No I have the new mosfet but I didn't took the time to solder it :/
                          mcplslg123 killed my hope of saving it
                          • deathtob
                            • Mar 2022
                            did you ever end up soldering the mosfet to see if it worked?
                            • reformatt
                              • Feb 2020
                              • 1413
                              Absolutely no point since the CPU is shorted. It's a common enough failure mechanism that I personally wouldn't even bother. High side FET goes short, allows full rail into CPU/GPU etc, killing the silicon.
                              • worlor
                                • Oct 2020
                                • 28
                                • France
                                Hello
                                Just to give news :
                                Yes I have replaced the mosfet
                                Yes the CPU was shorted
                                I have bought a new mainboard, non-shorted CPU report 2.4 ohms on same VCC line.
                                • Krilan1990
                                  • Jan 2023
                                  • 37
                                  • Poland
                                  In my laptop there was a damage to the usb2.0 socket, after initial measurements it turned out that between the mass and the date - there is 10 ohms and between the date + and the mass is about 60 kohm. there is also a high impedance between vcc (5V and ground. The laptop is msi ge62 2qd motherboard ms16j21 ver1.0. is it possible that there is some element between the bridge and usb that could be damaged and ground date-. I found a diagram on the vinafix website but it is a bit too expensive for me to download it. and the free versions of the schematics may not be complete. generally the laptop works fine, the temperatures oscillate between 40-50 degrees and the other components work. Please advise what could be done with it, how to save these usb and is it profitable and how much can it cost.Thanks in advance for all suggestions
                                  • mon2
                                    • Dec 2019
                                    • 14239
                                    The USB port is not working ?
                                    • Krilan1990
                                      • Jan 2023
                                      • 37
                                      • Poland
                                      I do not recognize devices, I have the impression that one line is shorted to ground
                                      • Krilan1990
                                        • Jan 2023
                                        • 37
                                        • Poland
                                        I do not know if the bridge or some element before the bridge is damaged, after measurements I noticed that the date pin is shorted - it is on the motherboard
                                        maybe someone on the forum has schematics from the vinafix website and could share
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
                                        • grimacelord
                                          Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                          by grimacelord
                                          Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                          After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                          I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                          10-24-2024, 12:31 PM
                                        • nagkiller
                                          Asus Geforce Cerberus GTX1050TI-O4G-DIS short circuit in the FBVDDQ rail
                                          by nagkiller
                                          Hello everyone!
                                          This grafic card came for repair, but when I connected it to the motherboard, the board would not start (short circuit in the 12V rail).
                                          After removing some PLs to isolate the short in the 12V rail, I got to PML1/PML2, according to the BoardView reference.
                                          Even injecting a voltage of 1V0 and a current of 3A in the FBVDDQ rail, for example, the voltage drops to 0V20 and none of the components heat up.
                                          The attached boardview file is very similar to this grafic card, which I am basing the repair on.
                                          I would like some...
                                          05-10-2025, 09:19 AM
                                        • joshAU
                                          Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                                          by joshAU
                                          Hi all.
                                          This notebook was showing no signs of life.
                                          I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                                          However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                                          If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                                          I tried replacing the MOSFET with a new one, but again no voltage on the...
                                          05-29-2024, 12:33 AM
                                        • techrepairheide
                                          Gaming laptop Clevo NH79EP with short on 5VS-rail
                                          by techrepairheide
                                          first of all I want to apologize for my bad English, but I try to give my best.
                                          Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
                                          For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
                                          10-13-2024, 02:49 PM
