I am currently learning to repair laptop motherboard and I need some advice/help.
I have a MSI GE62-6PQ laptop that didn't boot. It's an old laptop that got a glass of coke :/
I have cleaned the motherboard with isopropyl alcohol and a brushteeth.
The motherboard is a MS-16J51. I put the schematics attached.
I also attach high res pictures of the board.
Symptoms :
When I connect it to the power supply, it goes into protection.
What I have done :
Checked the fuse : OK
Visual check OK : No burned components
I have measured the resistance between PWR_SRC (main rail) and GND : 0.2 Ohm
The main rail is shorted, but where
The resistance between PWR_SRC and CHOKE9 (5V rail) was very low (<1ohm), so I have measured the resistance betweend source and drain of MOSFETs PQ13 and PQ15, both shorted. So i removed them. But the short is always here
You can look at page 40 of the schematics
I have tested the MOSFETs separatly, they seems OK.
The resistance between PWR_SRC and PL4 and PL5 are very low too. I think there is also a short near the CPU power. But I want to resolve the short on the 5V rail first
The others mesurement seems OK
What can I check to find this ***** short ? Any help/advice appreciated
Symptoms :
What I have done :
