NP-350V5C-S0AIT blackscreen
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    Already tryed bios flash but no lucky.
    I have power led on , fan spinning but no video no beep noting.
    LA8861P rev 2.0.
    after about 2 minutes it boot
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: NP-350V5C-S0AIT blackscreen
    First flash bios with clean me so that it boots instantly. Do you get display on external monitor?? If the problem is no display on internal monitor only, then you need to measure the LVDS pins for voltage.
    • lordgeny
      • Apr 2016
      • 223
      • Italia
      thats my dump , can you remove me ?
        • 20374
        bios requests go here: https://www.badcaps.net/forum/forumdisplay.php?f=40
        • lordgeny
          • Apr 2016
          • 223
          • Italia
          any idea??? the black screen lag time it not same every time,
          But when boot if i reboot , it boot fast
          • ekozeko333
            by ekozeko333
            🧠 What I’ve Done So Far
            Flashed...
            06-21-2025, 02:48 AM
          • corrize
            Nikon D800 camera - flash don’t work and capacitor don’t charge
            by corrize
            Hello, I'm stuck in troubleshooting…
            The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
            In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
            When I press the flash button, it's detected by the system, flash icon appear on LDC display....
            10-01-2022, 10:02 AM
          • abajor
            Canon VIXIA HF S10 A read data from inernal flash memory.
            by abajor
            Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
            Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
            The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
            I think my best shot is to figure out a way to read the internal flash memory outside...
            07-20-2024, 12:04 AM
          • Ihandyrepair
            4 red flash led 65X950G boot Sony and android logo but then black
            by Ihandyrepair
            HI guys
            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
            here is the issue
            I have Sony and android logo. but then 4 led red flash lights front of the tv
            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
            but then I get black screen and 4 red flash light at the front LED
            but I get 3 led flash on the LED driver board.
            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
            so I tried...
            07-11-2024, 01:45 AM
          • abhorsen
            Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
            by abhorsen
            Hey guys,
            Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
            Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
            Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
            07-06-2023, 10:22 AM
