Dell E5550 No charge (charger unidentified)
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #41
    Re: Dell E5550 No charge (charger unidentified)
    Originally posted by SMDFlea
    Just to clear up the mystery,continuity should only be checked when the board is unpowered .See the attached picture,the board is an LA-9591P ,ive soldered wires to PQ2 pin 1 and 3, the board isn`t powered. PR7 isn`t populated and as theres no voltage at PQ2 pin 2 there`s no flow between D/S S/D and no continuity
    With the board powered and PQ2 active then there will be continuity,you just can`t check it with a meter,you know its there though as it has voltage on pins 1 and 3.
    Havn`t found my passport yet..
    Please check again the readings for me, set the meter to Ohm reading at the lowest scale (200Ohm). I just get readings from the same as Andreasbest board (ZAM80 LA-A911P Rev1.0 (A00)) and the readings are follows:
    1. Unpowered board - no continuity (of course) between PL3 and PU1 pin3
    2. Powered board - between pin1 and 3 of PQ2 - 21 Ohms, and 51.5 Ohms between PL3 and PU1 pin3 (this is a plus ~30 Ohms which is the resistance of the PR9 itself), so everything is as expected.
    Become a Badcaps supporter
    Thanks to all supporters.​
      • 21692
      2. Powered board. No,its not the way to test resistance,it should be tested unpowered. The meter puts out a small ammount of current, and any other current from a live circuit will interfere with the readings and you can damage your meter with enough current.
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #43
        I agree, but in thins case there is no other way, without power PQ2 is off. Another indirect way to see continuity here is to measure voltage on pin3 of PU1.
        Yes it's true in general, but here we don't measure resistance to ground but resistance in the line, and second it's a low voltage signal line with very small current, powered by ALW low current source through a 2.2K resistor, so I don't see any problems here.
        • Ussovak
          • Jan 2020
          • 5
          Resistance measurements are always done with power OFF. Basic electronics.
          • Inforgalaxie
            • Apr 2023
            • 39
            • Portugal
            #45
            The SIO need to send the GPIO_PSID_SELECT in PU1 PIN6 correct?
            I have the same problem on a dell but pin3 and pin 4 have 3.3v but pin6 0V...
            It can be a SIO defect correct?
            • mon2
              • Dec 2019
              • 14636
              Attach the official power adapter. Measure the voltage to ground at PL3. Meter in dc volts scale of 20v or higher.
              What is the reading?
              • Sailman
                • Aug 2020
                • 12
                • Alaska
                #47
                Remove pd5 and check if the laptop identify the charger (with an original Charger)
                if it does replace pd5 (Common Problem)
                • Johndill
                  Dell Inspiron 7567 LA-D993P odd charger issue
                  by Johndill
                  Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                  There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                  I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                  Here are the tested scenarios:
                  1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                  2. With the laptop off, plug in charger (LED says on) & the front charging...
                  11-16-2022, 10:55 PM
                • PowerAmpFreak
                  Dell Latitude 7280 does not recognize charger
                  by PowerAmpFreak
                  I have a Dell Latitude 7280 which complains during boot-up that the charger wattage cannot be determined. Tested with two different chargers.
                  Any common faults that could be fixed?
                  I replaced the DC jack, the original DELL LATITUDE 7280 DC30100Z300 0DP4VC.
                  How does the communication between the charger and the PC work?...
                  07-28-2025, 07:18 AM
                • exerion5000
                  DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                  by exerion5000
                  Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                  below normal, as if it were operating in an extreme energy...
                  10-15-2023, 02:12 PM
                • Thomasraud
                  Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                  by Thomasraud
                  i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                  QUOTED
                  -It works on charger (without battery connected-only charger)
                  -It works on battery (without charger connected-only battery)
                  -& it also works when plugged in battery & charger, but it's not charging the battery
                  //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                  and..
                  QUOTE
                  The IC cannot maintain the input current level
                  06-28-2022, 06:47 PM
                • MahmoudNasser
                  Dell Vostro 3400 battery does not charge beyond 55%
                  by MahmoudNasser
                  I have a Dell Vostro 3400 battery does not charge beyond 55%
                  I tried another file... the battery charge exceeded 55%, but it entered manufacturing mode and it did not count from it.
                  - I rebuilt the basic BIOS and Clear Me, but without results
                  What if the same situation does not charge the battery more than 55%?
                  Can someone help me?
                  The original BIOS file is attached
                  Device Data
                  Model Dell Vostro 3400
                  CPU:i5-11th
                  SN 7G4BRF3
                  MP PartNumper:LA-K032P REV 1.0 (A00)
                  Bios Chips:XM25QH64A...
                  10-09-2023, 03:58 PM
