Dell E5550 No charge (charger unidentified)
  • Andreasbest
    • Aug 2014
    • 1137
    • Hellas ( Greece )
    hello.
    I have a Dell E5550 that doesn't recognize the charger, the usual Dell problem, i tried multiple chargers that charge fine other Dell laptops so the issue is clearly in mainboard.
    I replaced the PQ2 and PQ3 but no luck, so i need your help on what to do next.
    Schematics attached.
    Thank you in advance
    • 20339
    Re: Dell E5550 No charge (charger unidentified)
    Check PR9 resistance and voltage
    • Andreasbest
      • Aug 2014
      • 1137
      • Hellas ( Greece )
      5v in both pins of PR9
        • 20339
        Measure the voltage on PU1 next
        • Andreasbest
          • Aug 2014
          • 1137
          • Hellas ( Greece )
          Goodmorning, sorry for the delay i was away from lab.
          PU1
          pin1 0v
          pin2 0v
          pin3 0.66v
          pin4 0v
          pin5 5v
          pin6 0v
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            PU1
            pin1 0v
            pin2 0v
            pin3 0.66v
            pin4 0v
            pin5 5v
            pin6 0v
            Pin3 is directly connected to PR9, so check again - I mean the voltage on PR9 and pin3 of the PU1 must be the same. Also check resistance to ground in the line.
            ----> Look here. The diode marking for your board is PD5, the rest is the same.
            Become a Badcaps supporter
            Thanks to all supporters.​
            • Andreasbest
              • Aug 2014
              • 1137
              • Hellas ( Greece )
              To avoid any confusion please show me which one is PR9 as there is no writing, just to be 100% i'm measuring correctly
                • 20339
                Just posted the boardview - https://www.badcaps.net/forum/showthread.php?t=67214
                • Andreasbest
                  • Aug 2014
                  • 1137
                  • Hellas ( Greece )
                  Can't open it, boardviewer and openboardview crash when i attempt to open it
                    • 20339
                    It opens ok for me with BoardViewer, make sure you have the latest version -
                    http://boardviewer.net/
                    • Andreasbest
                      • Aug 2014
                      • 1137
                      • Hellas ( Greece )
                      Yes i do (version 1.2)
                      Probably the problem is in my Windows 7, perhaps NET framework is missing or something, i'll try on Windows 10 laptop.
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        Look the arrows.
                        • Andreasbest
                          • Aug 2014
                          • 1137
                          • Hellas ( Greece )
                          Originally posted by Vesko356
                          Look the arrows.
                          Yes i can confirm pin 3 and 5 have both 5v. (not sure why i measured 0.66 before @ pin3)
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            Just ignore the voltage,Check continuity between NB_PSID and PS_ID.
                            Multimeter in resistance or diode mode, one probe to point1, and with the other probe check continuity between point1 and poin2, and point1 and point3.
                            Also check resistance in ohms between point1 to ground, and point3 to ground.
                            • Andreasbest
                              • Aug 2014
                              • 1137
                              • Hellas ( Greece )
                              No continuity between PL3 and pin 3 and 4 of PU1.
                              PU1 pin 4 to ground ~1Ω
                              PL3 to ground ~115kΩ
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                PU1 pin 3 to ground is...?
                                Pin 4 to ground 1Ω...? So PU1 is most probably defected, unsolder PU1 from the board, and repeat the measurements (with and without the charger connected).
                                • Andreasbest
                                  • Aug 2014
                                  • 1137
                                  • Hellas ( Greece )
                                  PU3 to ground ~3kΩ
                                  Desoldered pin4 to ground ~45MΩ
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    PU3 to ground ~3kΩ
                                    Desoldering now
                                    OK, waiting for new data.
                                    • Andreasbest
                                      • Aug 2014
                                      • 1137
                                      • Hellas ( Greece )
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        Excellent, so PU1 is defective 100%, take new measurements and reply.
                                        -----> PL3 countinuity to PU1 pin3 with, and without charger????
                                        • Johndill
                                          Dell Inspiron 7567 LA-D993P odd charger issue
                                          by Johndill
                                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                          Here are the tested scenarios:
                                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                                          11-16-2022, 10:55 PM
                                        • exerion5000
                                          DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                                          by exerion5000
                                          Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                                          below normal, as if it were operating in an extreme energy...
                                          10-15-2023, 02:12 PM
                                        • Thomasraud
                                          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                          by Thomasraud
                                          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                          QUOTED
                                          -It works on charger (without battery connected-only charger)
                                          -It works on battery (without charger connected-only battery)
                                          -& it also works when plugged in battery & charger, but it's not charging the battery
                                          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                          and..
                                          QUOTE
                                          The IC cannot maintain the input current level
                                          06-28-2022, 06:47 PM
                                        • MahmoudNasser
                                          Dell Vostro 3400 battery does not charge beyond 55%
                                          by MahmoudNasser
                                          I have a Dell Vostro 3400 battery does not charge beyond 55%
                                          I tried another file... the battery charge exceeded 55%, but it entered manufacturing mode and it did not count from it.
                                          - I rebuilt the basic BIOS and Clear Me, but without results
                                          What if the same situation does not charge the battery more than 55%?
                                          Can someone help me?
                                          The original BIOS file is attached
                                          Device Data
                                          Model Dell Vostro 3400
                                          CPU:i5-11th
                                          SN 7G4BRF3
                                          MP PartNumper:LA-K032P REV 1.0 (A00)
                                          Bios Chips:XM25QH64A...
                                          10-09-2023, 03:58 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
