A1390 820-3332-A No Backlight
  • philo
    • Oct 2015
    • 14
    • Argentina
    Hey guys, i received this 15" MBP Retina previously touched by other messy hands. They previously attempted to disable graphics card but i removed the jumpers and took everything back as it was, I resoldered U8900 and got video output through the screen and loaded to operating system (throught HDMI it does give picture but somewhy it crashes before it can even load the progress bar, gray screen appears with "Your computer restarted because there was a problem").
    Getting back to the issue, the chime sounds distorted, and still don´t have backlight (the water indicator on the backlight zone is red, client says it never got liquids spilled ).
    No voltage at Pin 1 of J9000, PPVOUT_S0_LCDBKLT.
    Backlight diodes, and filter caps are not shorted to GND neither show low resistance. I´ve got this readings on the Backlight IC:
    U9701:
    Pin 2 (LVDS_BKL_PWM_RC) :1,44v
    Pin 4 (BKLT_EN): 0v
    Pin 6 (BKL_FET_CNTL): 0v
    Pin 8 (PP3V3_S0): 3.3v
    Pin 10 & 11: (BKL_SDA & BKL SCL): both 3.3v
    Pin 22 & 23(PP5V_S0): 5v
    Pin 24(BKL_SW): 0.3v
    D9701: 0v
    Q9706:
    Pin 1: 12.57v
    Pin 2: 12.57v
    Pin 3: 4.11v
    Pin 4: 12.57v
    Pin 5: 12.57v
    Pin 6: 12.57v
    Appreciate any clue or help, I suspected of backlight IC but unluckly havent got any to test
  • mon2
    • Dec 2019
    • 14001
    Re: A1390 820-3332-A No Backlight
    hi.
    1) I think that 820-3332-A = A1398
    2)
    U9701:
    Pin 4 (BKLT_EN): 0v
    So backlight will be disabled.
    Review and post the voltage values for the referenced locations.
    3) voltage on PPBUS_S0_LCDBKLT_PWR = L9710, pin 1 ?
    4) voltage on R9731, pin 1 = PPBUS_S0_LCDBKLT_PWR ?
    • philo
      • Oct 2015
      • 14
      • Argentina
      Originally posted by mon2
      hi.
      2)
      Hey!
      1) right
      2) Reference voltages;
      1> 12.56v / 2> 0.023v / 3> 3.33v / 4> 12.201v / 5> 0.001v / 6> 12.56v
      3) 0v on L9710
      4) 0v on pin 1 R9731
      • philo
        • Oct 2015
        • 14
        • Argentina
        hi.
        2)
        If it helps I previously attempted this: I jumped (LCD_BKLT_EN) to PP3V3_S0 in the U9100 area, and at pin 1 of LCD connector (PPVOUT_S0_LCDBKLT) I got 12.54v.
        • philo
          • Oct 2015
          • 14
          • Argentina
          Anyone?
          • mon2
            • Dec 2019
            • 14001
            PPVOUT_S0_LCDBKLT - I got 12.54v
            With the bypass trick, this rail is still too low for the backlight.
            Perhaps consider to replace U9701 (LP8545SQX-EXTJ).
            From assorted other posts, the backlight will enable only if the LCD is detected. However, if you are bypassing the turn on logic with your own external logic levels then this boost power supply should just enable and generate the much higher boosted voltage.
            Suggest to continue to try your bypass method but remove the LCD display till the backlight voltage is deemed to be a safe and 'normal' value. In my opinion, U9701 is only a boost power supply that should operate as designed once the enable and supporting components are functional.
            https://www.aliexpress.com/item/4000...archweb201603_
            I think you can source the same part (different suffix) directly from TI.com webstore:
            https://www.ti.com/store/ti/en/p/pro...-findchips-wwe
            Not sure if Apple had a custom version of this component manufactured for them but confirmed through the datasheet that at least the I2C slave address for this device matches the Apple schematics. Perhaps someone in the forum has sourced the original TI to replace this component with success ? It is worth a try and may be easily available through your local electronic parts resellers.
            • philo
              • Oct 2015
              • 14
              • Argentina
              Hey! Once again thanks for your help, really appreciate it. I also have the idea that the IC is bad, just want to make 100% it is before I can order it (it would take aprox 45 days to arrive to my country).
              My new update: having those 12.54v on the backlight rail I decided to hook up and external PSU of 45Volts to the rail, but still the same result: no backlight. It stays in stable 45v with the external PSU
              Last edited by piernov; 06-09-2021, 02:57 PM. Reason: remove full quote of previous post
              • philo
                • Oct 2015
                • 14
                • Argentina
                Btw keyboard doesn't work (except for power key), and touchpad neither. Maybe it's all an SMC issue?
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • DanPoka
                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                  by DanPoka
                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                  02-15-2025, 05:05 AM
                • Comp_Pro
                  No Backlight Macbook A1990 820-01041
                  by Comp_Pro
                  Hello all,
                  Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                  Tests performed:
                  There is no backlight even with a good screen.
                  Backlight IC is receiving the correct support voltages.
                  Fuse F8400 ok
                  Current sense resistor R8400 ok
                  Backlight IC is receiving 3.3V on enable pin.
                  Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                  Backlight IC receiving 5V from PP5V_G3S
                  Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                  I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                  05-06-2024, 10:23 PM
                • cheebster
                  iPad Pro 12.9 5th Gen Backlight Issue
                  by cheebster
                  Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                  Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                  Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                  The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                  Anyone...
                  05-20-2025, 09:17 AM
                • canadaboy25
                  LG Flatron 24EN33TA No Backlight When Cold
                  by canadaboy25
                  I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                  I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                  03-07-2023, 12:23 AM
