MacBook Air a1466 820-00165-a doesn’t start
  • kalilinux25
    • Mar 2018
    • 2069
    • ZAMBOANGA SIBUGAY
    #81
    Re: MacBook Air a1466 820-00165-a doesn't start
    PPVRTC_G3H- 3.3v
    RTC_RESET_L - 3.3v
    PCH_SRTCRST_L - 3.3v
    PCH_INTVRMEN_L- 3.3v
    PCH_DSWVRMEN_L- 3.3v
    SYSCLK_CLK32K_RTCX1 -0v
    PP3V3_S5- 3.3v
    PM_DSW_PWRGD- 3.4v
    PP3V3_SUS- 3.3v
    PM_BATLOW_L- 3.3v
    PM_RSMRST_L- 3.3v
    PM_PWRBTN_L- 3.4v
    • kalilinux25
      • Mar 2018
      • 2069
      • ZAMBOANGA SIBUGAY
      #82
      Originally posted by mon2
      Post the voltage readings of U6100 SPI flash rom.
      hi sir hope you can still help me
      • jamesp
        • Mar 2017
        • 55
        • philippines
        #83
        NEED help with my a1466 macbook with mb 820-00165-a
        problem is no voltage reading both pins of R7551 to send enable signal for pin 4 and will result to PP5V_S4RS3, measured L7520 indcutor for possible short to gnd but none have found. i watch yt videos of louiss rossman and he said before replacing U7501 we must check first PM_SLP_S4_L , and i did check but nothing i measured. is it correct to conclude that U0500 chip is the culprit? i checked also the PM_SLP_S4_L line and no short found. pls. help thanks
        • mon2
          • Dec 2019
          • 13834
          Review this flow chart:
          https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
          • jamesp
            • Mar 2017
            • 55
            • philippines
            #85
            yes thanks, i am at S4 stage where i can get no voltage reading that will enable the u7501 chip, and that PM_SLP_S4 comes from U0500 chip
            • mon2
              • Dec 2019
              • 13834
              Is PM_SLP_S4 pulsing or stuck at 0v?
              What is the voltage to ground of PPBUS_G3H? Is it stable?
              Do you have a stable PP3V42_G3H @ 3v42?
              Be sure to use the original OEM power adapter suitable to power this logic board. This is important.
              • jamesp
                • Mar 2017
                • 55
                • philippines
                #87
                i am stuck at 0v on PM_SLP_S4_L , PPBUS_G3H is stable, i also have reading of 3.42 on OO3V42_G3H, And yes i am using oem pwr adapter
                • mon2
                  • Dec 2019
                  • 13834
                  Confirm the PM_PWRBTN_L voltage when you press the power button. Test again when the power button is released.
                  Also review this video:
                  https://www.youtube.com/watch?v=GZz8WtEZBEU
                  • jamesp
                    • Mar 2017
                    • 55
                    • philippines
                    #89
                    PM_PWRBTN_L has a reading of 3v and pulled down as i press the pwr switch button on keyboard, when released it goes high again
                    • mon2
                      • Dec 2019
                      • 13834
                      What is the history of this unit? Any liquid damage? What is the exact voltage of PPBUS_G3H? This voltage will confirm if the SMC is working or not. If PPBUS_G3H is not the higher value, study the voltage to ground of the SCL / SDA lines on the battery which are shared by the battery pack, the SMC and the charger chip @ U7100.
                      • jamesp
                        • Mar 2017
                        • 55
                        • philippines
                        #91
                        PPBUS_G3H reads 8.4vdc and both SCL AND SDA line on battery connector are logic high 3v , my friend who owns this laptop said there is accedental water spill on this long time ago but wait a week before trying to power up, and voila...problem occurs. through my scope theres no visible water damaged observed. i only stuck at the PM_SLP_S4_L signal. btw....letter L in signal name means Low?? if it does, maybe i should not expect a high logic value on this pin, am i wrong ? whats your idea on this? if this signal comes from CPU U0500, what other signal that triggers this cpu to give a logic high on this output PM_SLP_S4?
                        • mon2
                          • Dec 2019
                          • 13834
                          Review the steps 1-12 here for this signal:
                          https://www.it-tech.com.au/pm-slp-s4-l-timing/
                          • jamesp
                            • Mar 2017
                            • 55
                            • philippines
                            #93
                            wow, thank you very much for the link, its very informative, i might sleep now and do this tomorrow morning. its past midnight here in our place. i will share some update as quickly as i can. thanks again.
                            • jamesp
                              • Mar 2017
                              • 55
                              • philippines
                              #94
                              here is an update....@Mon2 and others
                              i followed this link https://www.it-tech.com.au/pm-slp-s4-l-timing/
                              i have stopped at no.11 ​...PM_RST_L is low , reading of 0v but pull-up resistor is ok at 100k and PP3V_SUS has 2.7 volts.
                              pls. see attached diagram with my readings
                              also checked for shorted to gnd on that signal PM_RST_L but ok not shorted. so probably i should jump to conclusion that it is the chip U8130 is the culprit as datasheet tells us that MR pin is high and threshold voltage is within the design....PIN 6 SHOULD have a high reading and not zero. can you guys confirm
                              • mon2
                                • Dec 2019
                                • 13834
                                Working on my beauty sleep but 3v3 rails are too low. Remove all power and measure the resistance to ground. Should not be at 2v7 unless a shorted part on the rail.
                                • jamesp
                                  • Mar 2017
                                  • 55
                                  • philippines
                                  #96
                                  thats also i thought eventhough the chip has a minimum working voltage. the only correct voltage reading is PM_DSW_PWRGD which is i measured @ 3.42 v. all items in 11+1 checklist on the link that you gave me is 2.7v and the item no.6 i got a correct32khz clk. i will give another update, sorry o disturbed your sleep.
                                  • jamesp
                                    • Mar 2017
                                    • 55
                                    • philippines
                                    #97
                                    latest....found out PPDCIN_G3H_ISOL only has 15.5v but i can measure though a 3.42v on PP3V42. SAD i dont have other magsafe for verification. note that it is a original magsafe that i used. maybe this causes my 3.3v rail to have 2.7volt only of reading
                                    • mon2
                                      • Dec 2019
                                      • 13834
                                      Remove all power. What is the resistance to ground on C8130? This rail is being pulled down from the expected 3v3 value.
                                      U8130 is looking for a threshold value of 3v or more before releasing the reset line else parked the output to be low.
                                      • mon2
                                        • Dec 2019
                                        • 13834
                                        From Rossmann forum..
                                        15V on DCIN is fine and will not affect anything, schematic is lazy and states voltage for a 60W charger instead of 45W
                                        • jamesp
                                          • Mar 2017
                                          • 55
                                          • philippines
                                          #100
                                          SORRY I have just read your reply just this time, good news, i have replaced U8130 with a part from donor board. confirmed that U8130 is pulling my PM_RSMRST_L down. now after replacement, the voltage of all that i mention with 2.7v reading still same, macbook now running.
                                          L7560 = 2.8V
                                          L7520 = 5.1 V PP5VRS3
                                          PM_SLP_S4 = 2.8 V
                                          USB port has power, camera is working, wifi is ok. battery is charging. sleep mode is ok.
                                          i will update again if there is a problem that will manifest.
                                          thanks mon2 for the link. that helps a lot, i almost threw my mac
