macbook pro 820-3437
  • mortito
    • Jul 2020
    • 7
    • España
    I have a problem with an 820-3437 the pp5v_s4rs3 signal varies between 5v and 0v, it is not stable in the same integrated system, it generates pp3v3_s5_reg_r of 3v3 that if they are stable with what the computer does not start the fan is seen to rotate a little and it stops. Green light that turns to orange making measurements I see that q8150 does not have 4 ALL SYS PWRGD in its output due to the instability of PP5V S0 while medium voltages I saw that the measurement of leg 5 saw how the tension was fructifying and in a method it is set to 0.67 V and the fan begins to rotate faster and faster and by measuring I see that the 5V voltage of pp5v_s4rs3 has stabilized and I have tension in the memory and cpu coils I do not know why this occurs
    I hope your help thanks.
  • MobileXT
    • Oct 2012
    • 196
    Re: macbook pro 820-3437
    also check the current sensing resistors value at ISL6259
    • mortito
      • Jul 2020
      • 7
      • España
      thank you very much i will try them
      • envym
        MacBook Pro 2018 with Activation Lock
        by envym
        Hi everyone!
        I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
        I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
        06-27-2025, 08:54 AM
      • tobeend
        Bypass mdm macbook m2 ventura
        by tobeend
        1. RESET MACOS WITH IPSW
        a. Power off MacBook, press and hold the power button to enter Recovery
        b. Open Disk Utility, remove Macintosh HD
        c. Reboot, connect to the network to Activate Mac.
        d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
        d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
        e. Release the other keys, but keep holding the Power key for another 10 seconds
        f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
        05-26-2023, 07:18 AM
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • obelix24
        A2941 Macbook air 15” - 5V 0a
        by obelix24
        I’m working on one macbook air 15” m2 that was water damaged.
        keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
        i’ve put macbook in shelf and order new screen so i can fully repair it.
        Now i got the screen and macbook stays at 5v 0a.
        i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
        i don’t have schematics so i don’t know where to start can someone help me?...
        03-27-2025, 01:19 PM
      • Kush679
        MacBook Pro M1 Activate Mac
        by Kush679
        Sorry,I'm using my phone right now and couldn't find any search bar to search on the topic of macbooks.
        Few weeks back(mid may),I had bought a MacBook pro m1 A2338. It belonged to my friend's younger brother who was a graphic designer,he gave me this MacBook without any icloud account linked to it and I had so much work during that times that I only used it for storage while traveling for shoots (I'm a photographer). So long story short,his brother got involved in a bad accident and was in coma and then fairly recently they pulled out his life support. I mistakenly did an erase Mac and...
        06-20-2025, 09:43 AM
