A1278 820-3115-B PCB layers damaged?
  • drscoot
    • Dec 2020
    • 44
    • Belgium
    I've been working for while on this Macbook Pro LB.
    On the bare board with power adapter plugged in, no green light. So far I noticed that there is no PPBUS_G3H. I removed F7040 and I measure 2,1Ohm on pin2 there. So I conclude there is a short. I went to voltage injection on that pin2: 2,2V is drawing 1,1A. I found the board is warming at C7553, c7555 and C7556, so I removed those, but still the board is drying the alcohol at that spot. There are no more components there!
    Can it be that the trace in the layers of the PCB are damaged? It is an board with older water damage that I digged up again. I see a strange marking at the top side.
    So does that mean the board becomes a 'donor board' or are there more things to try?
    I have a google video, not sure if that is working like that? here
    Also I noticed that the boardview and schematic I use for that B-revision board like I have 2 of, is also showing C7560 & C7530 in the (AXG) Phase section, but the 2 are not on my 2 boards (1 is working), as seen in the video. Not sure if I have the right BV and Schematic? Most parts are correct.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: A1278 820-3115-B PCB layers damaged?
    Post high resolution pictures.
    C7560 and C7530 are no stuff.
    • drscoot
      • Dec 2020
      • 44
      • Belgium
      Here are some photos
      Oh yes, I see it now too, it says Critical and No stuff at the same time.
      • piernov
        • Jan 2016
        • 4439
        • France
        Layers are clearly burnt and shorting here. You need to dig up all the burnt material.
        • drscoot
          • Dec 2020
          • 44
          • Belgium
          I'm not sure if this board is worth it, I have no experience with that kind of repair. You can find lots of video of board repairs, but layers repairs video's are not so common.
          Do you know of an example repair like that?
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Rezendes
            Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
            by Rezendes
            Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
            I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
            The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
            05-10-2024, 02:18 PM
          • karto95
            Repairing a Seagate hard drive with damaged logic board
            by karto95
            I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
            I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
            If anyone has any suggestions or experience with this...
            03-21-2023, 04:05 AM
