Anybody can help me with some details,have an hp840g3 and dont have backlight,the system can open if inser external monitor,i change lvd cable even the screen,19v is present,and 3.3v,i dont understand what voltage is missing,please if anyone have this problem before and solved share please!
	Tags: None
 Re: hp840g3 and dont have backlight
 check video chipset ..Anybody can help me with some details,have an hp840g3 and dont have backlight,the system can open if inser external monitor,i change lvd cable even the screen,19v is present,and 3.3v,i dont understand what voltage is missing,please if anyone have this problem before and solved share please!Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
			by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
			by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
 This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
			by Comp_ProHello all,
 Am trying to figure out this backlight issue with this A1990 Macbook Pro.
 Tests performed:
 There is no backlight even with a good screen.
 Backlight IC is receiving the correct support voltages.
 Fuse F8400 ok
 Current sense resistor R8400 ok
 Backlight IC is receiving 3.3V on enable pin.
 Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
 Backlight IC receiving 5V from PP5V_G3S
 Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
 I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
			by EazyBoneHad another one of these 70 inchers from onn and was same problem as others. The picture shows but no backlight. The backlights test fine. The issue is the 450v 10uf capacitor by the backlight connector. Usually the cap bulges, the cap I replaced today for fix was NOT bulging. Replaced anyway and fixed.
 Hope this helps someone....
			by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
 Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
 Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
 The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
 Anyone...
- Loading...
