HP DV6 cannot turn on
  • String2016
    • Nov 2015
    • 2229
    • philippines
    I need help on this hp dv6 11A39-2
    48.4RH08.021, the problem is pressing power button nothing happens,but plugged in the charger lights is present on the charging,I check Cn_PBTN6 pin 5 DB_PWRBTN# there is 3.3v and on U10 kbc PIN 125 there is 3.3v, Ive noticed there is no RSMRST# pin96 on kbc,pressing the power button voltage response 3.3v to 0 then 3.3v but laptop is not spinning, anyone can help on this please
  • lapfix
    • Mar 2020
    • 2714
    • my workshop
    Re: HP DV6 cannot turn on
    First , try with another original charger
    • String2016
      • Nov 2015
      • 2229
      • philippines
      @lapfix i already tried 2 original hp charger
      • String2016
        • Nov 2015
        • 2229
        • philippines
        current drawn on lab bench 0.005 amps
        • mon2
          • Dec 2019
          • 14002
          Post any schematics/boardview files if you have them.
          Any liquid damage?
          If not, post clear close up pix for the logic board near the dcin connector.
          Power down and check the resistance to ground on all coils.
          • String2016
            • Nov 2015
            • 2229
            • philippines
            thanks attached is the schematic and picture
            • String2016
              • Nov 2015
              • 2229
              • philippines
              i check pc78 pc88 pc84 pc100 for short pc 100 is shorted i will try to replaced if the prob is gone
              • String2016
                • Nov 2015
                • 2229
                • philippines
                Replacing pc 100 still same issue cannot turn on
                • String2016
                  • Nov 2015
                  • 2229
                  • philippines
                  Anyone can help on this please
                  • mon2
                    • Dec 2019
                    • 14002
                    1) Study page 40 of your posted schematics. Any chance you have the boardview file for this logic board? Please post it if you do.
                    2) post the voltage readings with your external adapter attached. Check if the power switch is working or not on location 4.
                    3) With the reported 5 mA current draw from your power supply, your DCIN to logic board is not working. Issue is most likely on page 40 of the schematics.
                    • String2016
                      • Nov 2015
                      • 2229
                      • philippines
                      all that mentioned at page 40 have voltages, i flashed the bios not the amps is drawing 0.003 and when i press the power button it goes to 0.007
                        • 20656
                        have you checked the power jack and the AD_ID circuit
                        • String2016
                          • Nov 2015
                          • 2229
                          • philippines
                          @smdflea pin 5 on the dc in ADP_ID has 0.965v
                          • String2016
                            • Nov 2015
                            • 2229
                            • philippines
                            Ive checked PU9 3v5v chip tps51125 ON PIN 8 VGEG3 has 3.3v on pin16vin has 19v but on pin 23 PGOOD has 0v, I noticed also the two resistor PR68 AND PR69 on PR68 resistance has only 14.5k supposed to be 22k on schematic, on PR69 resistances has only 25.5k supposed to be 32k on schematic, and there is no standby 5v but pressing power button amps draw on bench lab 0.008 on Pr69 other side has 5v but other has 2v only on PR 68 other which ground 0v and other side is 2v only.could this chip or resistor is faulty?
                            • lapfix
                              • Mar 2020
                              • 2714
                              • my workshop
                              DV6 has a common fault : Graphic...if you have a graphic chip try to converted and see it your problem is solved
                              • String2016
                                • Nov 2015
                                • 2229
                                • philippines
                                @lapfix this board has no graphic chip non graphic version uma
                                • mielta
                                  • Apr 2015
                                  • 368
                                  Hi
                                  open PJP12 Jumper and messure resistance on both side
                                  • String2016
                                    • Nov 2015
                                    • 2229
                                    • philippines
                                    @MIELTA pjp12 no component on the board
                                    • mielta
                                      • Apr 2015
                                      • 368
                                      right it is only an solderjoint
                                      • String2016
                                        • Nov 2015
                                        • 2229
                                        • philippines
                                        on the image where is the soldere joint?
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • nikolayu
                                          Dell Latitude 5420 wont turn on when charger is connected
                                          by nikolayu
                                          I have Latitude 5420 that it's working fine on battery but when it's plugged on USB C charger it wont turn on.
                                          Battery is charging fine. Also, if I connect the charger while laptop is on, everything is fine, it will charge.
                                          The same thing if I connect to other USB C port.
                                          Charger is OEM
                                          03-13-2024, 12:34 PM
                                        • vdrokko99
                                          MBP wont turn on Only green light on charger
                                          by vdrokko99
                                          I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
                                          SMBUS_SMC_BSA_SCL 3.5V
                                          SMBUS_SMC_BSA_SDA 3.5V
                                          12-01-2024, 12:18 PM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                          Narrow VDC applications where the system power source is
                                          either the battery pack or the regulated output of the charger.
                                          This makes the max voltage to the system equal to the max
                                          battery voltage instead of the max adapter voltage. Operating
                                          at lower system voltage can improve...
                                          11-05-2024, 04:43 PM
