HP DV6 cannot turn on
  • mielta
    • Apr 2015
    • 368
    Re: HP DV6 cannot turn on
    Another way is do one Pin from PL805 desolder and then messure both sides
    • mielta
      • Apr 2015
      • 368
      go on page 45
      after PL805 in the near of PC100
      • mielta
        • Apr 2015
        • 368
        Or simple remove CPU and try to power on
        • String2016
          • Nov 2015
          • 2229
          • philippines
          tried removing cpu and power on still same from 0.004 pressing power button goes to 0.007, i will try removed pl805 and measure each pin
          • String2016
            • Nov 2015
            • 2229
            • philippines
            removed cpu and removed 1pin of PL805 one side which desolder has 26.5k othe side has 0.565
            • String2016
              • Nov 2015
              • 2229
              • philippines
              #26
              if cpu is plugged in one side lifted pin 30.1k and 0.560 other side
              • mielta
                • Apr 2015
                • 368
                which side has the 0.56 ohm
                • mielta
                  • Apr 2015
                  • 368
                  pin11 from ic or near the capacitors
                  • String2016
                    • Nov 2015
                    • 2229
                    • philippines
                    #29
                    the side of coil pl805 0.56ohm connected to pin11 of the ic
                    • mielta
                      • Apr 2015
                      • 368
                      check pc857 otherwise the ic is defective
                      i think so
                      • String2016
                        • Nov 2015
                        • 2229
                        • philippines
                        #31
                        PC857 is ok and pin 11 of pu805ic is beeping to the ground
                        • String2016
                          • Nov 2015
                          • 2229
                          • philippines
                          #32
                          anyone can help on this please
                          • mielta
                            • Apr 2015
                            • 368
                            you must change the ic
                            • String2016
                              • Nov 2015
                              • 2229
                              • philippines
                              #34
                              @mielta thanks for the response is there compatible replacement for this ic TPS51461?i cannot find same ic on scrap board
                              • mielta
                                • Apr 2015
                                • 368
                                No sorry
                                you can it order by Ebay or Aliexpress it is not expensive
                                • mon2
                                  • 13829
                                  Where and if possible, purchase the part from real distributors or the manufacturer of the component.
                                  This part appears to be available directly from TI (guessing Asia distribution for you):
                                  https://www.ti.com/store/ti/en/p/pro...p=TPS51461RGER
                                  Confirm the package is the same as yours and recommend that you buy it from TI directly so that you have a 100% new and original part.
                                  The prices on Aliexpress are incredibly low but may be ok. The Aliexpress prices are 1/10th the prices on the ti.com webstore. They must be dumping these in Asia or are surplus from closed builds.
                                  https://www.aliexpress.com/item/3289...archweb201603_
                                  • String2016
                                    • Nov 2015
                                    • 2229
                                    • philippines
                                    #37
                                    @mielta i found on scrapboard same tps51461 replacing it still same issue pin 11 is beeping to ground and 0.007 up0n pressing power button
                                    • String2016
                                      • Nov 2015
                                      • 2229
                                      • philippines
                                      #38
                                      I lifted the pins on PL805 that is connected to pin 11 short is gone
                                      • mielta
                                        • Apr 2015
                                        • 368
                                        Then the short is on other side check PC84/88/91/100/78
                                        • String2016
                                          • Nov 2015
                                          • 2229
                                          • philippines
                                          #40
                                          removed pc84/88/91/100/78 tested outside the board all caps are good even all removed still pin 11 is beeping once pl805 coil soldered back the pin
                                          • nikolayu
                                            Dell Latitude 5420 wont turn on when charger is connected
                                            by nikolayu
                                            I have Latitude 5420 that it's working fine on battery but when it's plugged on USB C charger it wont turn on.
                                            Battery is charging fine. Also, if I connect the charger while laptop is on, everything is fine, it will charge.
                                            The same thing if I connect to other USB C port.
                                            Charger is OEM
                                            03-13-2024, 12:34 PM
                                          • vdrokko99
                                            MBP wont turn on Only green light on charger
                                            by vdrokko99
                                            I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
                                            SMBUS_SMC_BSA_SCL 3.5V
                                            SMBUS_SMC_BSA_SDA 3.5V
                                            12-01-2024, 12:18 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
