Input MOSFETS, a bit of theory
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Hello guys,
    I recently watched a new repair yt video from Sorin and in the comments there were a lot of discussion about whether or not he made a mistake of not checking the second input MOSFET (after DC IN).
    I have found here, also a very interesting description of one repair where 2nd MOSFET was faulty.
    Now the thing that interests me is the claim that bridging the first input MOSFET when actually second MOSFET is shorted is actually a dangrous practice, because this will create situation for battery to overcharge.
    Can this be true? I mean if battery charging IC chip really prevents battery from overcharging by controling input MOSFETs. I believ not because, DC IN power would be cut down that way. I think that there must be some other protection method to prevent battery from overcharging like protection circuit on the battery itself.
    Can you please explain this in a bit more details? I really wonder what stops battery to charging, when capacity is 100%?
    Thanks!
    P.S: I have alreday found and read on this forum about battery charging circuit and why 2nd MOSFET should be checked, but wonder how overcharging battery is prevented.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3572
    • slovakia
    Re: Input MOSFETS, a bit of theory
    1. Sorin is maybe worst repairman i know. injecting 19V, putting powered board on metal keyboard case and lots of other DOGGY shit stuff he do and say
    2. if u have shorted second mosfet laptop will not charge battery
    3. charging is controlled by charging ic with comunicating with SIO and battery IC.
    • Sametbey
      • Jan 2021
      • 229
      • Turkey
      The notebook battery charge controller allows charging after receiving the AC_IN input (AC_OK signal). The charge control chip communicates with the battery via the SDA and SCL line. If there is a short circuit in the + B 19V line, 1 MOSFET circuit will not last. However, if you jamp 1 mosfet, it will cause bigger malfunction.
      I'm not happy to be so strong. because it's not humanly
      • Askic
        • Sep 2018
        • 187
        • BIH
        That is understandable. In case 2nd Mosfet is shorted then ACP input of IC (positive leg of input current sensing resistor) will be either shorted to some other leg of the same chip or resistance will be changed between the legs and battery will not be charged.
        When 2nd Mosfet is shorted, IC chip sense that and turns off input MOSFETs. That is why 1st Mosfet is switched off even if it is correct.
        • Adenitz
          • Jan 2021
          • 122
          • Congo
          Thank you for the replies, but still don‘t understand how ic stops battery charging when battery reaches 100 %. It does not shut down input mosfets for sure. I want to know how this works when everything is okay
          • Sametbey
            • Jan 2021
            • 229
            • Turkey
            For example, an 11.8v battery goes up to a maximum of 13V. The charge controller stops charging when it reaches this value.
            • piernov
              • Jan 2016
              • 4435
              • France
              As seen in the topologies described here: https://www.badcaps.net/forum/showthread.php?t=90356 , the battery is charged through a DC-DC converter (Buck or Buck-Boost), not directly after the DC-in MOSFETs. The DC-DC converter regulates the voltage going to the battery.
              Additionally the battery itself has another set of MOSFETs as a protection to prevent any overvoltage to get across the cells.
              • Adenitz
                • Jan 2021
                • 122
                • Congo
                Thank you very much for the reply piernov. I was look at your guidelines and there is a schematic: https://www.badcaps.net/forum/attach...5&d=1605469300
                This IC chip PU14 is actually IC (BQ247...) charging chip. I was confused because on the article I read that jumping first MOSFET can led to battery overcharge, but I don't see how that is possible based on this schematic.
                If everything is OK, I guessthat BQBATDRV signal to gate of MOSFET PQ54 will stop charging the battery.
                • jasko_jacker
                  • Oct 2014
                  • 1137
                  • italy
                  I personally always recommend reading the component datasheet carefully and studying the recommended circuit. It is important not to underestimate: the host (depending on the circuit) could involve other components and the A_D_DOCK_IN line (on asus mainboard)
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3572
                    • slovakia
                    it is not only about voltage. charging ic controls voltage and current. battery ic cut power to battery when something is not right too. like u have higher voltage by maybe 3V than actual battery voltage and if current is higher than max chaging current for battery. charging is difficult circuit because of many involved ic
                    • Mart202
                      • May 2021
                      • Nederland
                      3. charging is controlled by charging ic with communicating with SIO and battery IC.
                      The man him self thinks the same check out this video where he mentions it:
                      https://youtu.be/YPBE8dXIzGc?t=3477
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3572
                        • slovakia
                        So he make crap work because of no time?
                        i have one friend with me in shop. our shop works ok with good revenue without needing of crap work.
                        check northridgefix. HE make epic soldering work 10x faster than sorin with epic quality
                        • Oldi59
                          • May 2021
                          • United Kingdom
                          Sorin works at a totally different financial level that's called cheap and cheerful he probably charged sub £50 for that job and the owner gets a bit more use. The logic behind the repair is covered in several of his earlier videos. so basically speaking its horses for courses.
                          • Askic
                            • Sep 2018
                            • 187
                            • BIH
                            Totally agree. In more than one occasion he mentioned that repair shop charges for motherboard repair about £50 or £60. The costs are the same for PC laptops and Macbooks. On the other end, "high level" repair specialists like Louis or Paul Daniels charge about 300 USD for macbook motherboard repair.
                            Therefore, I think that Sorin's work is the best you can get for such amount of money.
                            • piernov
                              • Jan 2016
                              • 4435
                              • France
                              Driving the whole market down with such practices does nothing good to anyone.
                              It is exactly why we have garbage laptops, TVs and even worse printers in the first place: they are built to extreme cost reduction because 1/ people expect to buy these products for pennies 2/ as a result the competition drives the prices down instead of driving the quality up.
                              Even worse here is when you spread this low quality work by making so-called "educational" videos that everyone takes as the one and only truth.
                              And yes, both the orator and the auditor are at fault here. One for spreading misinformation and bad practices, the other for not using critical sense and understanding the implications.
                              I fight everyday against this kind of practice in the hope of seeing less randomly reflowed BGAs, less randomly bridged MOSFETs and fuses, less randomly injected 19V that only help in increasing the number of non-repairable devices. Or just in general fight for some better quality work across the board.
                              As long as I'm here I'll personally not tolerate such practices.
                              Btw, I'm not saying that £50 or $300 is either cheap or expensive. The labor cost will vary depending on your location and situation. I'm saying that you should not sell yourself short and do garbage work as a result. You should take pride in your work and aim at doing the best for you and your customers.
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3572
                                • slovakia
                                In one video he "repair" poor wifi signal by switching antena cable to AUX connector and charge 90pounds. I think thats more like RIPoff. or "repair" bad solder ball by super light reheat and call it fixed.
                                • kotel studios
                                  Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                  by kotel studios
                                  Finally got time to fix this board up.
                                  At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                  Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                  04-22-2025, 05:08 AM
                                • Jane
                                  How do you test MOSFET in laptops ?
                                  by Jane
                                  I tried to use this method:
                                  Testing an N-channel MOSFET:
                                  Step 1: Discharge the Gate (turn off the MOSFET)
                                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                  Step 2: Charge the Gate (turn on the MOSFET)
                                  Now, place the red probe on the Gate (G) and the black probe on the
                                  09-27-2024, 03:31 AM
                                • c_corr
                                  Asus P4C800-E VRM issues
                                  by c_corr
                                  This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
                                  This board uses mext ICs and Mosfets in VRM:
                                  - ADP3180 PWM controller - in 3 phase mode
                                  - ADP3418 as Modfet drivers
                                  - High side Mosfets STD38NH02L (from ST)
                                  - Low side Mosfets STD90NH02L
                                  Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
                                  I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
                                  02-08-2025, 11:59 PM
                                • ugamazing
                                  820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                  by ugamazing
                                  So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                  1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                  2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                  04-10-2024, 08:06 AM
                                • madjid911
                                  Acer Predator GH51M LA-K862P NO POWER
                                  by madjid911
                                  Hi, I have a laptop acer N20C2 (motherboard : GH51M LA-K862P ) that won't turn on, no signs of life.
                                  I checked the motherboard, there is no short circuit, no liquid damage, just the graphics card which is only 2 ohms (procesor 4ohms and mosfet are ok), so in doubt I disconnected its coil of the graphics card. I checked all the mosfets, all are good.
                                  The 19v arrives on the first mosfet PQB11, but does not come out, the mosfets have good resistance, even at the exit of the input mosfet PQB12 I have 270 ohms. So no shorts, I don't understand why BQ24781 does not give the...
                                  01-14-2024, 12:27 PM
