Is RT8223M compatible with RT8223P?
  • orientalsniper
    • Apr 2013
    • 461
    I'm working on a 11078-SA and my 3V and 5V are not being generated by U31, I also notice my low side mosfets (Q59 and Q60) drains go short when I plug in the adapter.
    I replaced RT8223M with RT8223P and replaced low side mosfets Si4172DY with APM4826K.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: Is RT8223M compatible with RT8223P?
    what resistance u have on that rails?
    • orientalsniper
      • Apr 2013
      • 461
      On diode mode unplugged: 0.428 and 0.465 on 3D3V_PWR and 5V_PWR, but go short when I plug in the adapter, the shorts are gone once I remove the low side mosfets or wait a few minutes until the mosfets close.
      Is RT8223M compatible with RT8223P? If they are, I can look for the problem elsewhere.
        • 21971
        RT8223M compatible with RT8223P? They seem ok to me.
        Measure the exact resistance to ground, not in diode mode
        • orientalsniper
          • Apr 2013
          • 461
          6.7K ohms (and rising) for 3D3V_PWR and 50K ohms (and rising) for 5V_PWR.
          Both rails go short when I plug in the adapter.
          So it can't be RT8223P because I tried 3 in new packaging.
          • orientalsniper
            • Apr 2013
            • 461
            Applying 2V to 3D3V_PWR, it's drawing about 0.50A and PCH heats up a bit, this one can't be saved right?
            • Sametbey
              • Jan 2021
              • 229
              • Turkey
              U31 stb chip Do you have 8 pin 3.3v LDO and 17 pin 5v LDO voltages. Is there 13 pin 3D3V_PWR activation (Enable). It is not normal that the PCH chip draws 0,50mA when it is idle.
              I'm not happy to be so strong. because it's not humanly
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3628
                • slovakia
                "the shorts are gone once I remove the low side mosfets or wait a few minutes until the mosfets close."
                did u apply power with low side mosfet removed?
                • Sametbey
                  • Jan 2021
                  • 229
                  • Turkey
                  do not do such a thing.
