HP G62 star reverer - missing +V5A rail
  • mhd_mahad
    • Jun 2016
    • 54
    • egypt
    hello friends,
    I have hp g62 Wont turn on.
    Some corrosion around PU850 (SN0608098RHBT)
    +V3.3AL OK
    +V5A is 0 volt.
    I've replaced PQ850 and PU850, no change.
    There is no short to ground on the +5VA rail.
    Measurements I've taken:
    PU850 pins:
    Pin 26 (DRVH2 +V3.3AL_UG_20) = 3.5V
    Pin 25 (LL2 +3_3V_AL_PHASE_20) = 3.3V
    Pin 24 (VBST2 +3_3V_AL_VBST_20) = 8.4V
    Pin 23 (DRVL2 +V3.3AL_LG_20) = 0.9V
    Pin 15 (DRVH1 DHI) = 0V
    Pin 16 (LL1 +V5A_PHASE_20) = 0V
    Pin 17 (VBST1 +5VA_VBST_20) = 4.8V
    Pin 18 (DRVL1 +V5A_LG_20) = 0V
    EC_ALW_EN missing
    IT8502 vcc= 0v
    +V3.3S=0v
    can any one help me urgently
  • Tom_avia
    • Jan 2020
    • 26
    • Lithuania
    Re: HP G62 star reverer - missing +V5A rail
    Did you try to use laboratory power supply? How much Amps the motherboard is consuming?
    Also do some elements are heating?
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      In this motherboard the +5alw are present only after pushing the power button.
      • mhd_mahad
        • Jun 2016
        • 54
        • egypt
        thanks all
        No elements are heating or shorting.
        IT8502 IO vcc= 0v how can i check missing volt?
        • Tom_avia
          • Jan 2020
          • 26
          • Lithuania
          I would check this area of board. I think this is an origins of +v3.3s voltage.
          • Tom_avia
            • Jan 2020
            • 26
            • Lithuania
            SN0608098 (PU11) is forming +v3.3al and then +v3.3s. Check there.
            • Sametbey
              • Jan 2021
              • 229
              • Turkey
              Do you have 7 pin LDO, 14 pin and 27 pin ENL voltages. System does not start without 13 and 28 PWGOD signals.
              I'm not happy to be so strong. because it's not humanly
              • mhd_mahad
                • Jun 2016
                • 54
                • egypt
                pin 14 EN1=0v
                pin 27 EN2=5v
                13&28=0vi only have enable and signals for 3.3v
                • Tom_avia
                  • Jan 2020
                  • 26
                  • Lithuania
                  Originally posted by mhd_mahad
                  pin 14 EN1=0v
                  pin 27 EN2=5v
                  EC_ALW_EN to pin 14 is going from EC.
                  • Sametbey
                    • Jan 2021
                    • 229
                    • Turkey
                    AD_ID activates the charge control chip when the adapter is installed. Then the charging chip generates the signal AC_OK + 19V is supplied to the system. PU850 STBY chip generates +3.3 V LDO voltage. IO works, BIOS gets the program. It sends the signal to PU850 and output 3.3 VALW to 5VALW. PU850 pwrgood sends signal to IO. IO waits, the SYS opens when the POWER button is pressed.
                    • Nagy Daniel
                      Lowest possible resistance on laptop motherboard rail - Guide Table request
                      by Nagy Daniel
                      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                      So, I generated a table with AI so I can...
                      03-04-2025, 08:24 AM
                    • BC_TechForum_drb
                      Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                      by BC_TechForum_drb
                      Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                      Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
                      Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
                      2/ Figure 1 Gfx-D500-B Front Facing
                      3/ Figure 2 +5v supply (zoom-in)
                      Intro:
                      While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
                      12-07-2023, 09:55 PM
                    • theflyingsquirrel
                      Samsung Chromebook Pro missing 1.2V power rail and no boot
                      by theflyingsquirrel
                      I am trying to repair my Samsung Chromebook Pro. There is no boot. Upon turning on, the screen is blank and there is no backlight. Power LED is blue. I tried refresh with power and esc refresh with power with no avail.
                      When I measure the 1.2V rail, it is pulsing. It will jump from 0 to 1.2V then 0 again. I replaced the 2 MOSFET and even power management IC and it is the same. Resistance from midpoint between mosfet to ground is 0.5 kOhm but it will show 250 Ohm first before jumping to 0.5 kOhm. So it feels like it was charging up some capacitor. Since MOSFET and IC was replaced, I...
                      06-11-2025, 08:11 AM
                    • Grucha98
                      Zotac gtx 1060 3gb missing one rail
                      by Grucha98
                      Hello everyone, i have zotac gtx 1060 3gb, and it has missing one rail. I think its 1v but I'm not sure. This rail has 34 Ohms, but after test on on my testbench, it drops to 2ohm, after some time it back to 34 Ohms. Next to this coil is up1727q. And there are 3,3 on vin pin and 5v on vdd pin. I changed this chip with another one but it didnt help. When i tried Short circuit test, core didnt heat up so maybe its still alive. I dont have thermal camera :/. I dont have boardview and schemstic for this GPU too. What should i check next? Or maybe its just dead core?
                      04-11-2024, 08:09 AM
                    • noflux
                      Surface pro 5 (Model 1726) missing 3.3V power rail
                      by noflux
                      Hello All
                      Have a Surface pro 5. Main board model; M1007506-015. Main 15v power rail is present.
                      1st image;
                      Missing 8v rail at inductor (circled in blue). Suspect main cause is power is being drawn at dead short on C4517.
                      2nd image;
                      3.3v rail was measured at 0.17v (at top most capacitor with red cross in 1st image).
                      Capactors crossed out in red are shorted.
                      Are the 5v and 3.3V rails tied in somehow e.g. generated at a single IC?
                      2nd and 3rd image;
                      C4517 circled in red is shorted at pin...
                      06-18-2023, 03:45 PM
