HP G62 star reverer - missing +V5A rail
  • mhd_mahad
    • Jun 2016
    • 54
    • egypt
    hello friends,
    I have hp g62 Wont turn on.
    Some corrosion around PU850 (SN0608098RHBT)
    +V3.3AL OK
    +V5A is 0 volt.
    I've replaced PQ850 and PU850, no change.
    There is no short to ground on the +5VA rail.
    Measurements I've taken:
    PU850 pins:
    Pin 26 (DRVH2 +V3.3AL_UG_20) = 3.5V
    Pin 25 (LL2 +3_3V_AL_PHASE_20) = 3.3V
    Pin 24 (VBST2 +3_3V_AL_VBST_20) = 8.4V
    Pin 23 (DRVL2 +V3.3AL_LG_20) = 0.9V
    Pin 15 (DRVH1 DHI) = 0V
    Pin 16 (LL1 +V5A_PHASE_20) = 0V
    Pin 17 (VBST1 +5VA_VBST_20) = 4.8V
    Pin 18 (DRVL1 +V5A_LG_20) = 0V
    EC_ALW_EN missing
    IT8502 vcc= 0v
    +V3.3S=0v
    can any one help me urgently
  • Tom_avia
    • Jan 2020
    • 26
    • Lithuania
    Re: HP G62 star reverer - missing +V5A rail
    Did you try to use laboratory power supply? How much Amps the motherboard is consuming?
    Also do some elements are heating?
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      In this motherboard the +5alw are present only after pushing the power button.
      • mhd_mahad
        • Jun 2016
        • 54
        • egypt
        thanks all
        No elements are heating or shorting.
        IT8502 IO vcc= 0v how can i check missing volt?
        • Tom_avia
          • Jan 2020
          • 26
          • Lithuania
          I would check this area of board. I think this is an origins of +v3.3s voltage.
          • Tom_avia
            • Jan 2020
            • 26
            • Lithuania
            SN0608098 (PU11) is forming +v3.3al and then +v3.3s. Check there.
            • Sametbey
              • Jan 2021
              • 229
              • Turkey
              Do you have 7 pin LDO, 14 pin and 27 pin ENL voltages. System does not start without 13 and 28 PWGOD signals.
              I'm not happy to be so strong. because it's not humanly
              • mhd_mahad
                • Jun 2016
                • 54
                • egypt
                pin 14 EN1=0v
                pin 27 EN2=5v
                13&28=0vi only have enable and signals for 3.3v
                • Tom_avia
                  • Jan 2020
                  • 26
                  • Lithuania
                  Originally posted by mhd_mahad
                  pin 14 EN1=0v
                  pin 27 EN2=5v
                  EC_ALW_EN to pin 14 is going from EC.
                  • Sametbey
                    • Jan 2021
                    • 229
                    • Turkey
                    AD_ID activates the charge control chip when the adapter is installed. Then the charging chip generates the signal AC_OK + 19V is supplied to the system. PU850 STBY chip generates +3.3 V LDO voltage. IO works, BIOS gets the program. It sends the signal to PU850 and output 3.3 VALW to 5VALW. PU850 pwrgood sends signal to IO. IO waits, the SYS opens when the POWER button is pressed.
