macbook pro 820-3115
  • judamex
    Active Member
    • Jan 2021
    • 185
    • Mexico
    Re: macbook pro 820-3115
    Originally posted by mon2
    Is this line pulsing between the 2 voltage values ?
    Value voltage pin #2 16.7V pin#3 16.7V pin 1# 0V
    Measurement pin#2 43K and UP pin#3 365K pin#1 1.4M
    • mon2
      • Dec 2019
      • 14597
      Which part are you measuring for these values ?
      Is it Q7030 ? If yes, this part has pins 1-2-3 connected together.
      • judamex
        Active Member
        • Jan 2021
        • 185
        • Mexico
        sorry I measured D6990, this value are from D6990 pin #1,2,3.
        • mon2
          • Dec 2019
          • 14597
          What are the voltage readings on the replaced mosfet @ Q7030 ?
          Pin 5-6-7-8 (Drain)
          pin 4 (gate)
          pins 1-2-3 (Source)
          • judamex
            Active Member
            • Jan 2021
            • 185
            • Mexico
            Pin 5-6-7-8 (Drain)
            pin 4 (gate)
            pins 1-2-3 (Source)
            Same voltage
            Pin 5-6-7-8 (Drain) 16.7V
            pin 4 (gate) 4.6V
            pins 1-2-3 (Source) 3.4V
            • mon2
              • Dec 2019
              • 14597
              Remove all power. Meter in DIODE mode. Fuse F7040 remains off the board.
              Test ppbus_g3h line in diode mode.
              You should get 0.400-500 at L7030, with red probe on ground; OL with black on ground.
              • judamex
                Active Member
                • Jan 2021
                • 185
                • Mexico
                #27
                Meter in diode mode red on GND. Black on points
                L7030 0.501
                PPBUS_G3H .481 i test all points on the board
                • mon2
                  • Dec 2019
                  • 14597
                  Now reverse the meter leads and measure the readings on L7030. Still in DIODE mode and no power.
                  • judamex
                    Active Member
                    • Jan 2021
                    • 185
                    • Mexico
                    #29
                    Meter on Diode mode measurement red on L7030 pin#1,2 0.0L (No conection)
                    • mon2
                      • Dec 2019
                      • 14597
                      Check / Replace R/C7025.
                      Check all traces and solder connections around U7000.
                      • envym
                        MacBook Pro 2018 with Activation Lock
                        by envym
                        Hi everyone!
                        I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                        I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                        06-27-2025, 08:54 AM
                      • Flasman90
                        Macbook Pro DFU Restore Issues
                        by Flasman90
                        I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                        - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                        - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                        08-30-2025, 10:27 AM
                      • tobeend
                        Bypass mdm macbook m2 ventura
                        by tobeend
                        1. RESET MACOS WITH IPSW
                        a. Power off MacBook, press and hold the power button to enter Recovery
                        b. Open Disk Utility, remove Macintosh HD
                        c. Reboot, connect to the network to Activate Mac.
                        d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                        d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                        e. Release the other keys, but keep holding the Power key for another 10 seconds
                        f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                        05-26-2023, 07:18 AM
                      • SarcasticOP
                        General question about MacBook power rails for repair.
                        by SarcasticOP
                        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                        • PPBUS_G3H (12.6V-12.8V)
                          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                        • PP3V42_G3H (3.42V)
                          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                        • PPVRTC_G3H (3.3V)
                          • This
                        12-12-2024, 05:50 PM
                      • obelix24
                        A2941 Macbook air 15” - 5V 0a
                        by obelix24
                        I’m working on one macbook air 15” m2 that was water damaged.
                        keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
                        i’ve put macbook in shelf and order new screen so i can fully repair it.
                        Now i got the screen and macbook stays at 5v 0a.
                        i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
                        i don’t have schematics so i don’t know where to start can someone help me?...
                        03-27-2025, 01:19 PM
