macbook pro 820-3115
  • mortito
    • Jul 2020
    • 7
    • España
    good morning
    I need help I have this motherboard the charger light turns green it turns off and turns on again in a few seconds
    and so constantly the motherboard does not boot
    I did the following measurements in u7000
    in DCIN I have oscillating values 18.1 18.3V
    ACOK 3.2V
    ACIN 4.4v
    CSIN OSCILLATION BETWEEN 18.1 AND 20v
    CSIP OSCILLATION BETWEEN 18.1 AND 20v
    BOOT OSCILLATION BETWEEN 14.1 AND 20v
    SGATE OSCILLATION BETWEEN 17 AND 20V
    AGATE 004.2mV
    VDD 5V
    VDP 5V
    R7020 OSCILLATION BETWEEN 18.1 AND 20 V
    Q7085 SOURCE 18.6v DRAIN 18.6v
    thanks in advance greetings
  • mon2
    • 14592
    Re: macbook pro 820-3115
    Hi.
    1) study page 3 of the schematics to note the power on sequence shown in the circles.
    2) voltage @ D6990 pin 1 ? pin 2 ? pin 3 ?
    3) voltage @ L6995, pin 2 ? Must be 3v42 volts here.
    4) if L6995 is not @ stable 3v42 volts then power down, remove the battery. Place your meter in resistance mode and check the resistance to ground for L6995, pin 2. What is the reading ?
    5) If the reading is not super low, review the resistance to ground on each coil on the logic board.
    Often the symptoms you are noting are related to bad / shorted caps. Usually the polarized tantalums. This is assuming there was no liquid damage that may be still on the logic board.
    • mortito
      • Jul 2020
      • 7
      • España
      Thanks for the help I measured what you recommend and these are the measurements what I think is because q7080 does not have the gate in 7 v more or less I see that u7000 does not send pin 26 to ground to make the divider of the gate of q7080 I see that it is not switching
      d6990
      pin 1 has 15.14 and decreases to 11.24 and rises again to 15.14
      pin2 18.54
      pin3 18.26
      L6995, pin 2 3.42 ok stable
      • mon2
        • 14592
        Not good. Remove F7040 = SMD fuse and then check the voltage rail as output from U7000. Check on F7040, pin # 1. What is the voltage reading ?
        This rail must remain to be stable.
        If not stable, power down and use the meter in resistance mode and check the resistance to ground on F7040, pin # 1. What is the resistance reading ?
        Will be a good idea to remove the battery off the logic board and then test the voltage on F7040, pin # 1.
        Also,
        voltage reading @ R6905, pin # 1 ?
        voltage reading @ R6905, pin # 2 ?
        we need to be sure that R6905 is not defective and causing these fluctuations.
        • mortito
          • Jul 2020
          • 7
          • España
          Thank you and sorry for not giving them to you before that machine I left it aside for the client when I touch it again I will communicate the tensions
          thanks anyway for your help
          • judamex
            Active Member
            • Jan 2021
            • 185
            • Mexico
            I have the same problem, remove the fuse F7040 and pin 1 gives me 4V I think this voltage is not normal. replace U7000, check resistors and all seems fine.
            • mon2
              • 14592
              Check the voltage of PP3V42_G3H_REG @ L6995, pin # 2.
              What is the measurement ?
              Remove all power. Meter in resistance mode.
              Check the resistance to ground of the pin # 1 @ F7040 pcb pad for the fuse.
              What is the resistance ?
              • judamex
                Active Member
                • Jan 2021
                • 185
                • Mexico
                voltage of PP3V42_G3H_REG @ L6995, pin 2= 3.49v
                Voltage of F7040 pin 1= 3.58v
                Measurement on F7040 pin 1 resistence mode is unstable = 1.1M to 600k and return to 1.1M
                i check measurement whit the red to GND and black to pin 1
                • mon2
                  • 14592
                  Resistance is fine. Voltage at fuse is too low.
                  Confirm the input voltage to the high side mosfet for this circuit.
                  What is the voltage?
                  Check the resistance across the same 2x mosfets on this u7000 ppbus_g3h leg.
                  Check each mosfet with the usual
                  Source & drain
                  Source & gate
                  Gate & drain
                  • judamex
                    Active Member
                    • Jan 2021
                    • 185
                    • Mexico
                    Source & drain
                    Source & gate
                    Gate & drain
                    i remove F7040 and voltage its the same, mosfets are ok
                    resistence on F7040 pin2 1.1M ppbus_g3h
                    • mon2
                      • 14592
                      Post the resistance values for these 2 x mosfets.
                      Also measure when in dc volts mode, the voltage that is going into the high side mosfet.
                      It is possible that this regulator is not soldered properly.
                      • judamex
                        Active Member
                        • Jan 2021
                        • 185
                        • Mexico
                        Resistance value for Q7030 pin 5 - 3.5M / pin 1,2,3 - 1.4M / If I check pin 4 of the mosfet it shows me a short circuit with respect to GND, but if I check pin 4 with the test point it tells me 1.4M
                        resistence value for Q7035 pin 5 - 1.3M / pin 1,2,3 GND .25 ohms / pin4 - 0.0
                        Voltage mode value for Q7030 pin 5 - 16.5V / pin 1,2,3 - 3.38v / pin 4 direct on mosfet 0.0V testpoint 4.5V
                        voltage mode value for Q7035 pin 5 - 3.37v / pin 1,2,3 - GND / pin 4 - 0.0V
                        • judamex
                          Active Member
                          • Jan 2021
                          • 185
                          • Mexico
                          i resold Q7030 and check pin 4-gate now have 4.5V but pin 1,2,3 still same 3.4V
                          • mon2
                            • 14592
                            What is the resistance to ground of pin # 4 of Q7030?
                            On the resistance checks for these mosfets -> remove all power -> meter in resistance mode.
                            Check:
                            source (1-2-3) & drain (5-6-7-8)
                            source (1-2-3) & gate (4)
                            gate (4) & drain (5-6-7-8)
                            Post each measurement and the meter scale used for these tests.
                            • judamex
                              Active Member
                              • Jan 2021
                              • 185
                              • Mexico
                              Check:
                              Meter on auto scale for resistance, model of meter "aneng AN8008"
                              resistence on Q7030 pin#4 - 2.1M
                              pin#1,2,3 - 2.7M
                              pin#5 - 3.3M
                              source (1-2-3) & drain (5) - 2.7M
                              source (1-2-3) & gate (4) - 2.6K
                              gate (4) & drain (5-6-7-8) - 1.5M unestable up and down
                              • mon2
                                • 14592
                                Source and gate resistance looks very low.
                                Confirm it again.
                                Mosfet looks to be defective.
                                • judamex
                                  Active Member
                                  • Jan 2021
                                  • 185
                                  • Mexico
                                  Confirm it again.
                                  Source and gate resistance(RED terminal on gate, black terminal on Source) 21K
                                  (Black terminal on Gate, RED terminal on source) 20.8K
                                  • judamex
                                    Active Member
                                    • Jan 2021
                                    • 185
                                    • Mexico
                                    Confirm it again.
                                    i remove Q7030 and check measurement, source (1-2-3) & gate (4) - 3.3M.
                                    And check measurement on motherboard without Q7030 Pin#1-2-3 & Pin #4 - 2.3K
                                    • judamex
                                      Active Member
                                      • Jan 2021
                                      • 185
                                      • Mexico
                                      Confirm it again.
                                      i replace the mosfet and it still gives the same measurements
                                      • mon2
                                        • 14592
                                        Is this line pulsing between the 2 voltage values ?
                                        • envym
                                          by envym
                                          Hi everyone!
                                          06-27-2025, 08:54 AM
                                        • Flasman90
                                          Macbook Pro DFU Restore Issues
                                          by Flasman90
                                          I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                          - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                          - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                          08-30-2025, 10:27 AM
                                        • tobeend
                                          Bypass mdm macbook m2 ventura
                                          by tobeend
                                          1. RESET MACOS WITH IPSW
                                          a. Power off MacBook, press and hold the power button to enter Recovery
                                          b. Open Disk Utility, remove Macintosh HD
                                          c. Reboot, connect to the network to Activate Mac.
                                          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                          e. Release the other keys, but keep holding the Power key for another 10 seconds
                                          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                          05-26-2023, 07:18 AM
                                        • SarcasticOP
                                          General question about MacBook power rails for repair.
                                          by SarcasticOP
                                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                          • PPBUS_G3H (12.6V-12.8V)
                                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                          • PP3V42_G3H (3.42V)
                                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                          • PPVRTC_G3H (3.3V)
                                            • This
                                          12-12-2024, 05:50 PM
                                        • obelix24
                                          A2941 Macbook air 15” - 5V 0a
                                          by obelix24
                                          I’m working on one macbook air 15” m2 that was water damaged.
                                          keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
                                          i’ve put macbook in shelf and order new screen so i can fully repair it.
                                          Now i got the screen and macbook stays at 5v 0a.
                                          i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
                                          i don’t have schematics so i don’t know where to start can someone help me?...
                                          03-27-2025, 01:19 PM
