Repair missing pad under smd ic
  • NConstantinou
    • May 2017
    • 334
    • Cyprus
    Dear all
    I am facing a problem with a laptop motherboard.
    2 pads under ic 739 pins 31 and 32 are burned under the ic and 2mm away from it.
    Is there any way to fix it!!!
    I tried to use solder ball but no luck.
    If I solder wire under the is when I heat it up to solder it Wii the wires remove!
  • mon2
    • 14088
    Re: Repair missing pad under smd ic
    Yes, there is a new solution out that is being streamed often lately.
    See here:
    https://www.youtube.com/watch?v=mIdvfn-7h5w
    * this video is likely more relevant for your repair
    https://www.youtube.com/watch?v=2gZLWUZScyI
    https://www.aliexpress.com/wholesale...psort=1&page=1
    If you do proceed, please post your results from this repair. Very fascinating and looking forward to purchasing this for the shop.
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      Originally posted by NConstantinou
      Dear all
      if u can post a picture would be goot so we can see the problem.
      https://www.badcaps.net/forum/showthread.php?t=95204
      i was talking about new method on this thread . ill get them in the next days.
      • NConstantinou
        • May 2017
        • 334
        • Cyprus
        i managed to fix it after a lot of effort and very carefully.
        Thanks to everyone
        • Jim Farid
          Steam Deck: how to solder 3 pin POWER BUTTON with one missing (ripped-off) solder pad?
          by Jim Farid
          The middle pad (B) on my steam deck's power button got ripped off. I want to bridge the middle pin to a via or another pad but don't know which one. Do you guys know any?
          The pads with the stars are all ground.
          In case there's no pad I can bridge to, do you know how to turn my deck on without using the power button? Thanks a lot 🙏....
          06-09-2024, 02:38 PM
        • corrize
          Best way to solder LVDS connector for beginner (and qfn) ?
          by corrize
          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
          See the test :
          https://youtu.be/bNAzC-EvqHs?t=1767
          With hot air from bellow the board, that's...
          03-09-2023, 02:57 AM
        • ugamazing
          820-02020 PPBUS_AON missing
          by ugamazing
          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
          02-05-2025, 04:21 PM
        • jpreza
          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
          by jpreza
          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
          Looking at the card, it appears to be missing the following:
          1x 1.0uH inductor - orange square
          2x...
          11-01-2024, 10:54 PM
        • Geeker007
          Friend messed up my laptop motherboard while working on my bench
          by Geeker007
          Hi All,
          So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
          So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
          I have not tried putting...
          06-16-2025, 01:40 PM
